Old 01-27-2012, 10:11 AM   #5566
91420l's Avatar
Thanks all.
Centering servo and place a horn 90deg were done and have been like that since I built TC6.
Steering has been adjusted by EPA and Trim and I have been happy
But since I am so OTAKU and start to look for some inperfections and am confused.
When steering angle are equal right to left, should servo horn travel right to left be equal as well?
When X=Y, should n=m like n:m=x:y ? otherwise steering angle is equal right to left but travel time could differ right to left in steering.
I probably should shut and practice but am quite busy n hard to find time to hit track so I have more time poking my car on desk
Thanks for all your help!
Takeshi
91420l is offline   Reply With Quote
Old 01-27-2012, 10:28 AM   #5567
bjanzen's Avatar
IMHO..... the servo horn needs to lean toward the rear of the car slightly to get equal throw. Just how i found my 6 to work best......
bjanzen is offline   Reply With Quote
Old 01-27-2012, 10:35 AM   #5568
Trader Rating: 18 (100%+)
Originally Posted by Rodrigo360 View Post
Hi,
I want to present my recently purchased TC6.1
I'm going to race on 10.5 Stock class on parking lot asphalt (medium grip).
I'm running on LOSI Xcelorin 10.5T, what do you recommend me?
thanks a lot.
woo that is a lot of wire back there!
yokomo blue springs front, pink springs rear maybe
johnny lee is offline   Reply With Quote
Old 01-27-2012, 10:55 AM   #5569
Jochim_18's Avatar
Ok guys I'm building a new TC6 from scratch since I got most of the parts to build a new roller without buying a new kit. I'm going to build it with all the parts that the TC6.1 has. Here's is my question.
1. Does the new Anti-roll bar set direct bolt fit on the TC6 bulkhead without any modification?
2. I'm also going to use all the new suspension components to this build.
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 01-27-2012, 11:10 AM   #5570
tr1kstanc3's Avatar
Default Parts compatibility
Are the TC6.1 caster blocks compatible with the TC6 front arms and steering blocks? I'd like to use the new caster blocks without having to purchase the other items if possible.
tr1kstanc3 is offline   Reply With Quote
Old 01-27-2012, 11:10 AM   #5571
off the top of my head, you will need:
the new anti-roll assembly front and rear
new front and rear arms
new chubs
new rear hubs
new driveshafts and axles?
gear differential
new spool assembly
Old 01-27-2012, 11:13 AM   #5572
they should fit. i know the tc6 hubs will fit in the tc6.1 arms.
i think you'll be a lot happier if you put the tc6.1 arms on the car rather than just the hubs. i don't think you will find any performance increase just changing the hubs. the new arms gives the car more corner speed and grip imo
Old 01-27-2012, 11:15 AM   #5573
A solution for the play between arms and Hubs.
Just use lunsforg pins. They are a little bit bigger.
I have listened that with this pins everything is perfect.
Regards.
PS: Vive la bourgogne libre.....
fredB is offline   Reply With Quote
Old 01-27-2012, 11:52 AM   #5574
Jochim_18's Avatar
Thanks guys that's all I need to know. I'm going to use just front and rear arms Of the TC6.1 and use the TC6 hubs since a lot of guys are having problem with too much play when TC6.1 hubs when use. I'm very happy with TC6 that's why I decided just to build another One with some minor upgrades instead of buying the new TC6.1 kit... I'm also upgrading the steering using tamiya 416 dual steering arm and serpent S411 servo holder to flip my servo 90 degree.
Old 01-27-2012, 12:18 PM   #5575
Rodrigo360's Avatar
I'm just finishing building it, and don't want to wait for order cables to test run. I'm just going to esthetic part of building.
Rodrigo360 is offline   Reply With Quote
Old 01-27-2012, 12:57 PM   #5576
geeunit1014's Avatar
I think you will need the new arms as well, the 6.1 hubs are a hair wider than the 6 ones. I know I need a .25mm (or so) shim when using the old hubs on the new arms
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 01-27-2012, 06:21 PM   #5577
Infinite 12th's Avatar
Need help please with gearing starting point. I have 17.5 stock blinky and 48 pitch 87. What pinion should I start off with. Everything is stock except I have yokomo rear gear diff
Do I have to change spur for stock?
Also does anyone know what servo tape is white that is easy to remove? Does associated make that?
12th scale - The Jedi class...
Infinite 12th is offline   Reply With Quote
Old 01-27-2012, 06:42 PM   #5578
You will need a much smaller spur for 17.5 blinky. We normally use a 96t 64p. Thats a 72 in 48p. For pinion, depends on what FDR you want (which depends on motor). With a sonic I like a 3.76 FDR, which is 96/51 for me. That means you will need around a 38t 48p gear.
Mike Gee
Old 01-27-2012, 07:28 PM   #5579
8KCAB's Avatar
I am running 34/72 48p on a Novak Ballistic 17.5. Runs great with decent temps.
8KCAB is offline   Reply With Quote
Old 01-27-2012, 07:40 PM   #5580
Bburns's Avatar
I race offroad pretty hardcore. This is my first venture to the on road side. I just bought a tc6.1 to run the vta class with a 25.5. What gearing should I start with.
Brandon
Bburns is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 07:34 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28937 01-14-2017 07:26 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 12:42 PM
SEO by vBSEO 3.5.0
