Like Tree1Likes
Old 01-21-2012, 09:17 PM   #5536
8KCAB's Avatar
Broke a caster block at our races Thurs night. Looks like it had a large void in the plastic where it broke. Don't have enough posts to upload the image link.
8KCAB is offline   Reply With Quote
Old 01-22-2012, 09:25 AM   #5537
rc pete's Avatar
The issue with the HB DCJ's in the 6.1 is the fit in the blades. You have to drill out the AE blades for the larger pins, and you end up with very little (read not enough imo) material left. I guess you could try to thin out the pins too.
Team Associated - Reedy - Pro-Line - RC Depot - OS Engines - 110% Racing - LD Graphics
rc pete is offline   Reply With Quote
Old 01-22-2012, 11:29 AM   #5538
Big Features's Avatar
Originally Posted by R1wurks View Post
does the kit come with the shims? or where can we get the shims & what kind of shims work?
can you elaborate more about how & why you boil them? temperature etc...
The kit does not come with extra shims. These are usually felt to the racer to source and tinker with. No car comes with them. I use Losi or Tamiya shims. Don't have any specific part #s.
As far as boiling goes, back in the day we used to boil plastic in off-road parts to make them less brittle (Read LOSI parts). This process removes air bubbles left in the plastic as a result of the injection mold process. They will fit tighter and require a little bit of sanding/fitment to be perfect. Just boil watch to a rolling boil. Drop in your parts and let them sit until the water is cool.
Mike
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix
Big Features is offline   Reply With Quote
Old 01-22-2012, 12:38 PM   #5539
Questions??
Why not just use the HB blades?
ChampRC is offline   Reply With Quote
Old 01-22-2012, 02:21 PM   #5540
Believe you have to sand them to fit
Mike Kling
Old 01-23-2012, 11:25 AM   #5541
roger999's Avatar
Does anyone know what car was using Juho Levanen on ETS? 6 or 6.1?
r o g e r g r a f i x . c o m
facebook.com/rogergrafix
roger999 is offline   Reply With Quote
Old 01-23-2012, 11:31 AM   #5542
Geberit's Avatar
The same car as at the ATS!
http://ats.redrc.net/gallery/?nggpage=3
Geberit is offline   Reply With Quote
Old 01-23-2012, 02:29 PM   #5543
Suspended
Trader Rating: 86 (100%+)
i recently bought a used 6.1 and just figured its using tc6 c hubs. does it effect any handling?
or i have to use 6.1 c hubs to make it drive it should be?
littlealex is offline   Reply With Quote
Old 01-23-2012, 03:06 PM   #5544
geeunit1014's Avatar
There is no geometry difference in the 2 hubs. The difference is the 6.1 hubs will fit an ECS driveshaft w/o dremeling it. You can run the old hubs on a 6.1 with no problem
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 01-24-2012, 12:37 AM   #5545
evochick's Avatar
Just fitted the tc6 caster hubs, huge improvement over the new ones, almost no movement in them at all,
not the same motorsport but couldnt resist when i painted my first shell
Beth.
UnRetired
evochick is offline   Reply With Quote
Old 01-24-2012, 01:59 AM   #5546
Luke Hobson's Avatar
Send a message via MSN to Luke Hobson
He was running an inbetween car, all the new plastics but still the old roll bars.
By the end of the weekend (final 3) we got the car down to 13.0 pace (pace fast enough for top 5 runs, but the track was pretty strange (very bumpy) so it was hard to find a balance between soaking up the bumps (more like jumps) and not traction rolling.
The main changes from the ATS set up were thinner shock oil, moved the front shocks to middle hole on arm, and thicker rear diff oil (up to AE 1k)
Hth
Luke
Luke Hobson
Awesomatix - Xenon - Godzilla Paint - Moorespeed - ToniSport - MBmodels
http://luke-hobson.blogspot.com/
Luke Hobson is offline   Reply With Quote
Old 01-24-2012, 07:48 AM   #5547
roger999's Avatar
Hth
Luke
Where can i find that setup? Sorry got it on AE web site
Old 01-24-2012, 07:53 AM   #5548
Would anyone give a try at some basic maintenance that the TC6 requires? Lets assume the car gets a solid practice & race in every week & is running 17.5T on high traction carpet.
Walter Johnson is offline   Reply With Quote
Old 01-24-2012, 09:01 AM   #5549
The Evicerator
I would recommend:
taking the shocks off, checking the suspension for free movement/excessive slop.
Check the shocks for air/similar pressure... refill/bleed if necessary
Checking the front and rear hub bearing for smooth operation
Checking blades for excessive wear.
Check diff(s)
Once that sort of stuff is ok I would usually put my car back together, unfasten the top deck and refasten to ensure the chassis is flat... then go through and reset ride height, camber, toe, droop, etc.
If you have more time you can obviously do more...check CVAs, completely rebuild diffs or shocks.
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- P1 BRAND -- TUNING HAUS -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 01-24-2012, 12:10 PM   #5550
Another thing to check if you are running on carpet are the pulleys. You can pick up a lot of fibers in the pulleys and it can clump up and in some cases cause your belt to skip. Clean with an exacto blade between races.
wcalaker is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28952 05-01-2017 04:47 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
