Like Tree1Likes
Old 01-16-2012, 05:15 AM   #5461
AM03GT's Avatar
Originally Posted by roger999 View Post
Thanks. So i think at the moment i can use only c hubs and arms?
You can't use the 6.1 c-hubs with the reg 6 steering blocks as the new c-hubs are wider. using this combo will restrict your maximum turning radius by a significant amount. you'll have to stick with the regular 6 c-hubs until you can make the full change with bearings and cvds...
Associated // Reedy // Radiopost // Integy // Parma PSE
AM03GT is offline   Reply With Quote
Old 01-16-2012, 07:13 AM   #5462
roger999's Avatar
Ok. Thanks a million.
facebook.com/rogergrafix
roger999 is offline   Reply With Quote
Old 01-16-2012, 07:27 AM   #5463
Trader Rating: 49 (100%+)
Also, are you guys using some type of battery strap to secure the lipos, or tape? I'd like to use a strap, so if you guys know of one that works well in this car, please link me to it, thanks
Edit: just used that little cool search tool and saw someone said the top photon strap works. Can anyone confirm this? Also looks as if the AE eco conversion straps may be long enough. Thanks again
cleblanc is offline   Reply With Quote
Old 01-16-2012, 08:37 AM   #5464
I use tape. I sanded the carbon "bars" and put some heat shrink around it, because my tape was snapping now and then, result: battery came loose
You could use a strap too, but i prefer tape.
株式会社 ヨコモ
dennisV is offline   Reply With Quote
Old 01-16-2012, 08:39 AM   #5465
burgboyz's Avatar
Trader Rating: 70 (100%+)
+1
Got Droop???
Speed Passion....Speed Power....Serpent America/Desoto Racing.
burgboyz is offline   Reply With Quote
Old 01-16-2012, 09:14 AM   #5466
roger999's Avatar
http://www.rcmart.com/rc-battery-str...h=595_747_1499
will do
Old 01-16-2012, 09:28 AM   #5467
AeRacer805's Avatar
I use the black Top Photon strap and it works great
"When you are not practicing someone else is and when you meet that person they will beat you."
TC6, Top Photon, B4.1, SC10 FT, Orion Motors and Servos, Tekin RS
AeRacer805 is offline   Reply With Quote
Old 01-16-2012, 09:39 AM   #5468
Thanks guys on the info for the battery straps!! No tape for me!
Old 01-16-2012, 09:46 AM   #5469
Wouldn't a battery strap cause tweak?
jordan.norwood@ is offline   Reply With Quote
Old 01-16-2012, 09:47 AM   #5470
jrz93's Avatar
i use the tekno rc strap available from great planes
only need the long one but small ones can be used as replacements for other cars
http://www3.towerhobbies.com/cgi-bin...battery+straps
---NEMO RACING USA--BULLITT--BETA TIRES--CRITTERS HOBBYSHOP--HOBBYWING--TRINITY--TOBAMEISTER PAINT--NYRT--GMK Supply--
--Critters Raceway--Barnstormers Raceway--360v2 Raceway
jrz93 is offline   Reply With Quote
Old 01-16-2012, 10:17 AM   #5471
rc pete's Avatar
In most cases, Yes. The issue with the strap is that you need to put more tention on it than tape to keep the battery in place. If you setup your battery stops such that the battery fits in perfect and has no wiggle room, then the strap can work fine without excessive tension.
Personally, I setup my battery fit so that it drops in freely and can't move at all. I also put a small strip of double sided tape on the bottom of the battery (thin clear scotch tape from any retail store), and then I use battery tape as per instructions, with very light tension to prevent any tweaking. That sucker doesn't move and hasn't come out yet (knock on wood).
Team Associated - Reedy - Pro-Line - RC Depot - OS Engines - 110% Racing - LD Graphics
rc pete is offline   Reply With Quote
Old 01-16-2012, 11:39 AM   #5472
STUBYSLAP31's Avatar
Trader Rating: 27 (97%+)
CAN SOMEONE TELL ME WHAT THE DISTANCE IS FROM MOUNT TO MOUNT ON THE SHOCKS FULLY EXTANDED AND FULLY COMPRESSED
ALSO DOES ANYONE HAVE 1 COMPLETE SHOCK THEY WOULD LIKE TO SELL
TEAM ASSOCIATED / REEDY / PRO-LINE RACING / SCHELLE RACING / SCS NISSAN
AE CARS / PRO-LINE BODIES & TIRES / REEDY ESC & MOTORS & BATTERIES / SCHELLE NOVA SLIPPER AND ACCESSORIES
ROCKY MOUNTAIN R/C RACEWAY / COLORADO FAST TRACK
STUBYSLAP31 is offline   Reply With Quote
Old 01-16-2012, 12:07 PM   #5473
Suspended
Trader Rating: 86 (100%+)
i have a set of new never used tcx shocks for $50 shipped
pm me if interested
littlealex is offline   Reply With Quote
Old 01-16-2012, 12:47 PM   #5474
wtcc's Avatar
Full extended it is around 63-64mm , depending on your build.
Compressed it is 50mm. Everything measured from end to end.
wtcc is offline   Reply With Quote
Old 01-16-2012, 02:45 PM   #5475
Thank you
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28975 10-20-2017 10:40 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
