Like Tree1Likes
Old 01-05-2012, 02:55 PM   #5311
Originally Posted by ChampRC View Post
Please redirect and forgive me if this has been answered already. I have a TC6 and came across this "whats needed to make it a TC6.1 site" http://www.petitrc.com/reglages/asso...6.1/index.html.
What parts are essential if trying to upgrade my TC6 to TC6.1?
Not really looking to by another car and just doing parking lot stuff.
Still want something competitive as I do face xrays and hb tcx cars.
Thanks!
NVM found the answer some post back.
A TC6 is well able to beat the pants of Xrays and TCXs
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 01-05-2012, 04:08 PM   #5312
mtbboy's Avatar
Haven,t bent a screw since going to the larger o.d. blue aluminum shims.
Team Associated Reedy factory team driver.
B5M Factory lite $ B44.3 Factory $ TC6.2 $ RC12R 5.1
Reedy 410 Speedos $ Reedy Mach Series motors
204 Raceway Winnipeg 1/10-1/8 Offroad. Owner.
mtbboy is offline   Reply With Quote
Old 01-05-2012, 04:09 PM   #5313
mesa80's Avatar
Originally Posted by Geberit View Post
I'm using the rc12r5 blue alu shims!
i would take the arm mount off and measure the distance from the whole to the end of shims or without beacuse an accurate caliber wont lie
mesa80 is offline   Reply With Quote
Old 01-05-2012, 05:07 PM   #5314
kman16jr's Avatar
Trader Rating: 53 (100%+)
Hey what is a good starting setup for an agressive driver for the tc6?I recently picked one up with a tekin 17.5 combo in it and just wanted to know whats a good starting setup such as shock oils,springs,shock positions,gear ratios for 48 pitch.Any help would be greatly appreciated.I currently run an xray t3 and know they are different in many ways so i came to you guys for some advice.Any replies would be greatly appreciatedOh i will be running this on crc carpet of course and use sxt tire sauce,and the course is very technical and flowing.
Kevin Welfley
AE rc8b3-AE rc8b3e-AE b64d-AE b6d-AE b6
Sponsors:|DDHrc|Team Trinity|Jconcepts|Rc Adiction Products|NitroPro Fuel|M2c racing|Ultimate racing engines|Highest servos|Bellgate Distibutors|
kman16jr is offline   Reply With Quote
Old 01-05-2012, 05:12 PM   #5315
Trader Rating: 26 (100%+)
The only problem using the aluminum washers are they don't rest against 100% of the mount. The plastics do and you can get them tighter and less prone to moving.
eddie10 is offline   Reply With Quote
Old 01-05-2012, 05:13 PM   #5316
Big Features's Avatar
I think you might have that backwards.
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix
Big Features is offline   Reply With Quote
Old 01-05-2012, 06:26 PM   #5317
Plastic arm mounts. Hold much better than a ride height washer or a plastic wheelbase washer.
Old 01-05-2012, 06:29 PM   #5318
Default CVA's
Sean/Rick,
Just want to know if the Tc5/6 cva kits will bolt straight in to the 6.1....
Are all the parts (bones, Stub axles, pins etc) the same?
They look identical to the eye but the part numbers have changed?
Cheers.
XPRESS| SMOKEM | MUCHMORE | SRT RACING | MONTECH
Lionel S is offline   Reply With Quote
Old 01-05-2012, 06:32 PM   #5319
Mike Kling
Old 01-05-2012, 06:34 PM   #5320
Originally Posted by Lionel S View Post
Sean/Rick,
Cheers.
The 6.1 uses larger ball bearings, so the axles are different
Mike Kling
Old 01-05-2012, 06:48 PM   #5321
Maybell's Avatar
Sean/Rick,
Cheers.
5x10 bearings
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 01-05-2012, 07:46 PM   #5322
Thanks dudes
Old 01-05-2012, 10:22 PM   #5323
Trader Rating: 18 (100%+)
anyone using guy droop tools to set droop on this car?
I'm having a hard time finding the spot on the front arms to reference my droop.
any input would be appreciated
johnny lee is offline   Reply With Quote
Old 01-06-2012, 04:11 AM   #5324
Part way through my build, I've come across a deal breaker problem.
One of my 4 Outter Hinge Pins is too fat!
I measured the diameter of all 4 hinge pins, 3 are 2.5mm and ONE is 2.6mm wtf?
I can't fit this into the arm hole at all, Arghhhh.
This is my first AE kit, and it feels terrible. The fit and finish is way below Tamiya kits. Some of my aluminium parts for instance have slight nicks in them (shock bodies, a few bulk heads). Also have 1 less than perfect bladder damper out of the 4 (slight half tear on the outside). The steering knuckles that sit into the front C hubs is also a tight fit, even with NO screws. it feels very tight to turn.
Also what the hell is with the springs? Isn't it meant to include 2 silver and TWO GREEN? I got 4 silver like some others have mentioned here. The manually certainly stipulates 2 green and 2 silver.
I'm not in USA, so i doubt AE will post me one 2.5mm outter hinge pin will they?
End Rage. What a shoddy kit.
Forgetful_Duck is offline   Reply With Quote
Old 01-06-2012, 04:19 AM   #5325
Contact AE they will send you a replacement Hinge pin, even if your not on US.
Team AME/ORCA
https://www.facebook.com/strawberryrcdesigns
http://www.strawberryrcdesigns.pt/
jorgesimes is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28972 Today 06:25 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
