Old 01-01-2012, 12:44 PM   #5236
cwoods34's Avatar
Originally Posted by cvlooper View Post
Is that 40wt shock oil in a rear gear diff?
Running on a 16-17 sec asphalt track with fairly high traction. Looking for a couple oils to try.
Yep, 40wt Associated shock oil!
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 01-01-2012, 02:51 PM   #5237
jvroffroadrc's Avatar
Originally Posted by Jim Frahm View Post
I had the same problem. I broke both left and right C-hubs while practicing and there were no big hits anywhere. I replaced them with TC6 4 degree hubs and no problems since then. I noticed an irregularity in the plastic at the break. It looks like the plastic in the center is granulated. I'm not a plastic's expert so I'm going to send them to AE so they can take a look.
Anyway, I plan on running the TC6 hubs until they offer a better hub, i.e. aluminum would be nice.
Jim
I noticed the same thing with the plastic that you did, it just seems pitted or bubble inside the hubs. Seems like the best way to go is just use the older 4 degree hubs.
jvroffroadrc is offline   Reply With Quote
Old 01-01-2012, 03:59 PM   #5238
Originally Posted by SkarTisu View Post
In Minnesota, we're one of the last redneck holdouts in the world running foam tires on carpet.
The big question mark we have right now is whether the TC6 will work out of the box in that configuration. We've seen some other rubber-specific cars act very strange on foam tires.
I'll find out when I get one and try it out. I'll have help from some experienced sedan guys here to set it up, especially if we find out it's too flexible.
We have 3 or 4 guys in Boise/Nampa Idaho, still running Foams.
I just got the 6.1, wonder if I can set it up to outrun my TC5F on foam?
Any inputs on set up?
red7fifty is offline   Reply With Quote
Old 01-01-2012, 04:15 PM   #5239
Trader Rating: 26 (100%+)
Anyone know what the pound ratings on yokomo blue and pink springs are.
eddie10 is offline   Reply With Quote
Old 01-01-2012, 04:51 PM   #5240
bhambrent's Avatar
Yok Pinks are 14.93 and Yok Blues are 12.12.
bhambrent is offline   Reply With Quote
Old 01-01-2012, 04:57 PM   #5241
mtbboy's Avatar
Orange=18.87
Green=16.06
Pink=14.93
Yellow=14.71
White=12.94
Blue=12.12
Team Associated Reedy factory team driver.
B5M Factory lite $ B44.3 Factory $ TC6.2 $ RC12R 5.1
Reedy 410 Speedos $ Reedy Mach Series motors
204 Raceway Winnipeg 1/10-1/8 Offroad. Owner.
mtbboy is offline   Reply With Quote
Old 01-02-2012, 06:04 AM   #5242
DrunkMike's Avatar
Trader Rating: 22 (100%+)
Just ordered a tc6.1 any recomedation on a set up for 17.5 blinky rubber tire carpet.
Mike
AE TC6 IM GIVING IN AND RUNNING RUBBER TIRE
CRC GEN XL
BRP
NORCARRACING.COM
DrunkMike is offline   Reply With Quote
Old 01-02-2012, 06:22 AM   #5243
slakr's Avatar
Trader Rating: 25 (100%+)
Try the Keven Hebert setup
http://www.teamassociated.com/pdf/ca...slam2_2011.pdf
XRAY XB2, XT2 ~ TLR 22-4 2.0 ~ Mugen MBX7TR Eco ~ JQ THE eCar WE, THE Car WE
AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 01-02-2012, 07:17 AM   #5244
DrunkMike's Avatar
Any idea what the yokoma springs equal. R they better then ghe associated.
CRC GEN XL
BRP
NORCARRACING.COM
Old 01-02-2012, 07:41 AM   #5245
slakr's Avatar
Originally Posted by mtbboy View Post
Orange=18.87
Green=16.06
Pink=14.93
Yellow=14.71
White=12.94
Blue=12.12
AE TC7.1
Old 01-02-2012, 10:45 AM   #5246
piper48
Guest
Posts: n/a
Default 1st run
Got the car build and went together fairly well. No slop on the caster blocks and a little deformity on the gear diff but at least it doesn't leak. I had the opportunity to give it's first shake down on our reconfigured technical 102'x 60's ozite carpet yesterday and I am very pleased on how the car performed. Car is very predictable. I went with box setup at first but over steered too much to my liking. Raised rear roll center and went up 2 holes on the rear shock and thats all it took to get me dialed in. Awesome car compared to my 415 MRE which was also a good car back in the day. Great car Associated has put out.
Old 01-02-2012, 11:47 AM   #5247
8KCAB's Avatar
What springs came in your 6.1 kits? The manual shows green and silver, but my box had 4 silver springs.
8KCAB is offline   Reply With Quote
Old 01-02-2012, 12:01 PM   #5248
Luke Hobson's Avatar
Send a message via MSN to Luke Hobson
same
Luke Hobson
Awesomatix - Xenon - Godzilla Paint - Moorespeed - ToniSport - MBmodels
http://luke-hobson.blogspot.com/
Luke Hobson is offline   Reply With Quote
Old 01-02-2012, 12:35 PM   #5249
8KCAB's Avatar
Great, thanks. Wanted to make sure before I called.
Old 01-02-2012, 07:47 PM   #5250
Default Belt tension/adjustments
Newb question- what tuning is there in changing belt tension? Since there are 31 positions for every cam type (tho some are redundant), what's the benefit for one or the other? Is tension directly based on trigger response? There is nothing in the manual. Thanks.
Seeds is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 07:34 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28937 01-14-2017 07:26 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 12:42 PM
SEO by vBSEO 3.5.0
