Like Tree1Likes
Old 12-31-2011, 05:19 AM   #5221
bjanzen's Avatar
Originally Posted by Geberit View Post
We are driving on a high traction carpet. Tried spool vs. putty vs. front diff (600k, 500k, 300k). We all experienced the same thing leek of power out of corners and 0.4-0.5s slower times vs. spool. A lap is approx. 16s. Front diff is more easy to drive/consistent but the spool is faster and a little bit twitchy. Putty is somewhere in between.
This is our experience.
Regards
I was having questions about this last night. I just got a TC6 a couple weeks back. Used to run TC3s back in the day. Never have run a spool..... If I understand the terms.
Can someone clarify the terms?
Spool = Front One-way??
Front diff = ball diff or Factory Slipper Spool??
PUTTY = New geared diff with very thick fluid?
How is the factory friction disks used? How is a Putty setup different?
Sorry for all the questions........ Just want to understand what I have and what I should still try.......
F
bjanzen is offline   Reply With Quote
Old 12-31-2011, 05:52 AM   #5222
JRXS_chris's Avatar
Spool = Locked front diff or solid pulley
Front Diff = Front Gear Diff
Putty = What you said but more like a gum than a fluid (plasma haha)
The factory friction disks allow you to change the ball diff into a spool by replacing the large diff balls with the pads.
JRXS_chris is offline   Reply With Quote
Old 12-31-2011, 06:12 AM   #5223
bjanzen's Avatar
So...... Is the term "spool" used for a locked front or one-way? IOW with spool setups do you have front brakes or just e-brake?
Old 12-31-2011, 07:26 AM   #5224
Buckaroo's Avatar
Spool means locked. One-ways haven't been used for a while.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 12-31-2011, 11:04 AM   #5225
cwoods34's Avatar
Regards
16-second laps? That is a good sized track! I've also noticed on bigger tracks that a spool is usually faster since you don't need the rotating characteristics of a front gear diff. Our typical laps are (layout dependent) 10's to mid 12's..... I've always preferred the gear diff on our track.
Putty is just tricky to build and get set right.... that's why you don't see it often. However, it is worth trying if you want that in-between as Geberit says.
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 12-31-2011, 09:56 PM   #5226
jvroffroadrc's Avatar
I broke a caster block tonight on my 6.1 does anyone know where i could find someone that has them in stock. Does anyone know if a tc6's caster block will work on the 6.1 just in case i cant find any, right now its not looking to good. Thanks for any help in advance.
jvroffroadrc is offline   Reply With Quote
Old 12-31-2011, 10:20 PM   #5227
Trader Rating: 88 (100%+)
Tower show's them in stock. How bad was the hit?
Shane W.
Everything for Sale - out of hobby
tcdrvr2 is offline   Reply With Quote
Old 12-31-2011, 10:20 PM   #5228
SLOWINSLOWOUT's Avatar
Trader Rating: 19 (100%+)
I broke one as well on Fri. night. The TC6 blocks fit just fine, as a matter of fact,they fit better. With the "new" design, there was so much slop that I could move the upper ball 2mm front to back. With the TC6 caster block in, all play was eliminated. Think I'll just stick with the "old" part.
SLOWINSLOWOUT is offline   Reply With Quote
Old 12-31-2011, 10:44 PM   #5229
To be honest i dont really know when it happened i dont remember any really bad hits. I got turned by another car trying to pass and then the guy behind him hit but not really hard that is the only thing i can think of. I glued it with CA glue but it didnt hold for the main but i was able to finish.
Old 12-31-2011, 10:46 PM   #5230
Thanks for the help i may just use some i have for my old tc5 until there are more to be had.
Old 12-31-2011, 11:04 PM   #5231
I was hoping you were going to say it was a very bad wreck and that's all that broke. I've trying to decide between running my 6.1 or my T3 '12 for snowbirds but if the hubs on the 6.1 are weak then that'll pretty much make the decision for me as I want to finish as many runs as I can. I got to drive mine for the first time Friday and it handled great, very smooth and easy to drive.
Shane W.
Old 01-01-2012, 12:23 AM   #5232
I have ran my car for 3 races and 3 nights of practice so far and this is the first break or problem i have had. I didnt brake anything else just the left front caster block. So far the car has been great other than this one problem. I have taken plenty of hard hits before this and had no damage at all so i think that this was just a fluke really. I have only driven a t3 10 so i can only compare it to that car not the 12 but so far i would say that i think the 6.1 is more durable than it was. Dont want to scare you off from running the 6.1 because i do think it is a great car.
Old 01-01-2012, 07:10 AM   #5233
jeppesen's Avatar
Have been racing me TC6.1 for a couple of nights now, and i'm not faster on my fastest lap, but i'm consistent 4-6 sec faster over a 5 min run.
The biggest different from the TC6, is that it is much easier to drive, has a much smoother feel, and i feel i can push the car harder, with out riskin it all every time.
I'm running a slight "modified" Juho ATS set-up, longer camber links rear, lower camber links front, and a spool.
I have been testing different locked gear diff methods, and found that when i use this
https://www.fg-onlineshop.de/ItemDet...=0&webi=0&pr=0
The diff is more consistent through out the hole race, it is made for Large Scale cars.
Greetings and happy new year.
Large scale racing with RS5 Touring car, Sanwa, Sav÷x, Modelsport engines and Shell V-Power
1/10th Racing with RGT R2, Hobbywing, Gens-Ace and Absima.
jeppesen is offline   Reply With Quote
Old 01-01-2012, 10:14 AM   #5234
Jim Frahm's Avatar
Trader Rating: 68 (100%+)
Send a message via Yahoo to Jim Frahm
I had the same problem. I broke both left and right C-hubs while practicing and there were no big hits anywhere. I replaced them with TC6 4 degree hubs and no problems since then. I noticed an irregularity in the plastic at the break. It looks like the plastic in the center is granulated. I'm not a plastic's expert so I'm going to send them to AE so they can take a look.
Anyway, I plan on running the TC6 hubs until they offer a better hub, i.e. aluminum would be nice.
Jim
Serpent S411 ERYX, Reedy 25.5, FLOW
AE 12R5.2, Trinity 17.5, ORCA
Jim Frahm is offline   Reply With Quote
Old 01-01-2012, 11:01 AM   #5235
Gear diffs - fluid
I am running on a medium traction tight carpet track. I want to try the gear diff so would 1,000 wt be a good starting point? I will run it with the spool but also considering testing with a front diff as well so is 500,000 wt a good start for the front?
Thank you
Originally Posted by cwoods34 View Post
On our medium bite carpet track, I'm running 30wt AE shock oil rear, and 500k in the front. The car is dialed
My buddy is running a spool with 40wt in his with good results, also, but he is more point-n-shoot with his driving style.
Is that 40wt shock oil in a rear gear diff?
Running on a 16-17 sec asphalt track with fairly high traction. Looking for a couple oils to try.
cvlooper is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28963 Today 05:20 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
