Old 12-29-2011, 07:52 PM   #5206
Originally Posted by bvoltz View Post
72 / 36 for 48P
96 / 48 for 64P
So 4.00 FDR is what I'm looking to achieve?
Seeds is offline   Reply With Quote
Old 12-29-2011, 07:54 PM   #5207
jrz93's Avatar
Originally Posted by Seeds View Post
Going to be running 17.5 blinky or not depending on class running. I have an 87 (stock spur) and was trying to figure out a starting size for pinion. What FDR should I be aiming for? 4.00? I searched thru a few pages here and there but no real luck. Thanks.
im running 69/39 and temp are 150 on 17.5 revtech n lrp sxx
edit on 42pitch
---NEMO RACING USA--BULLITT--BETA TIRES--CRITTERS HOBBYSHOP--HOBBYWING--TRINITY--TOBAMEISTER PAINT--NYRT--GMK Supply--
--Critters Raceway--Barnstormers Raceway--360v2 Raceway
jrz93 is offline   Reply With Quote
Old 12-29-2011, 08:02 PM   #5208
Default Wheel chatter
Hi just wanted to see that it is normal to have wheel chatter even at about 70% DR.
Cheers
Warbird is offline   Reply With Quote
Old 12-29-2011, 08:52 PM   #5209
Big Features's Avatar
Cheers
A bit of wheel chatter is normal for running a spool, nature of the beast. The inside wheel chatters because it is locked and puts strain on the drive coupling in the CVD. I use Tamiya Anti-wear grease and it helps a bunch. There are other alternatives, but I'm sure the AE Area 51 guys are up to something judging by the new, larger openings in the caster blocks on the TC6.1 suspension.
Mike
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix
Big Features is offline   Reply With Quote
Old 12-30-2011, 01:38 AM   #5210
Mike
Hi Mike
Thank you for your tips and info
Cheers
Old 12-30-2011, 07:59 AM   #5211
Two-speed's Avatar
Trader Rating: 24 (100%+)
Just got my 6.1 kit. The box is tiny! And no cool box art . Oh well, it's what inside that counts, right?
Two-speed is offline   Reply With Quote
Old 12-30-2011, 11:00 AM   #5212
Send a message via AIM to Jonesy112
I thought the box art was pretty cool myself. It said everything it needed to
Team Associated: 26 time World Champion.
Good enough for me lol
Michael Jones
RC America - X-Ray - Team EA Motorsports - RockStar Paint - Apex RC Proshop - ProOne Tires
Jonesy112 is offline   Reply With Quote
Old 12-30-2011, 03:37 PM   #5213
Trader Rating: 20 (100%+)
Default Gear diffs - fluid
I am running on a medium traction tight carpet track. I want to try the gear diff so would 1,000 wt be a good starting point? I will run it with the spool but also considering testing with a front diff as well so is 500,000 wt a good start for the front?
Thank you
trailblazer04 is offline   Reply With Quote
Old 12-30-2011, 04:59 PM   #5214
bvoltz's Avatar
Trader Rating: 44 (100%+)
17.5 blinky mode, yep... different motors will be a tooth or 2 up or down from 4.0, but make sure you temp the motor at 3 mins.... just to be safe....
If you are running open ESC 17.5 class, then depending on the track size, ESC setting and motor, but 6.5 FDR is a good starting point....
bvoltz is offline   Reply With Quote
Old 12-30-2011, 05:35 PM   #5215
jrz93's Avatar
well im new to onroad and running the spool front and bell diff rear what are the advantages to running different setups?
Old 12-30-2011, 05:36 PM   #5216
cwoods34's Avatar
Thank you
On our medium bite carpet track, I'm running 30wt AE shock oil rear, and 500k in the front. The car is dialed
My buddy is running a spool with 40wt in his with good results, also, but he is more point-n-shoot with his driving style.
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 12-30-2011, 06:22 PM   #5217
bvoltz's Avatar
Do you have a part number for the 500K for the front? Many thanks.... B
Old 12-30-2011, 06:33 PM   #5218
Very useful thank you! Tried (64 pitch) 88 spur and 43 pinion today. Doesn't fit. Bought it prior to checking the list in the manual. Oh well.
Old 12-30-2011, 06:37 PM   #5219
cwoods34's Avatar
TRA5039...... being Traxxas most hobby shops easily stock it!
Old 12-31-2011, 03:14 AM   #5220
Geberit's Avatar
We are driving on a high traction carpet. Tried spool vs. putty vs. front diff (600k, 500k, 300k). We all experienced the same thing leek of power out of corners and 0.4-0.5s slower times vs. spool. A lap is approx. 16s. Front diff is more easy to drive/consistent but the spool is faster and a little bit twitchy. Putty is somewhere in between.
This is our experience.
Regards
Geberit is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 07:34 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28937 01-14-2017 07:26 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 12:42 PM
SEO by vBSEO 3.5.0
