Old 12-16-2011, 10:55 PM   #5041
R Doyel's Avatar
Originally Posted by Two-speed View Post
Quiet in here. Guess everyone is busy building their new 6.1 kits .
Me too......... Having a good time doing it.
Question for you guys who have had the previous models. The bird's foot looking spacer between the supension mounts and the bulkhead......these seem pretty flimsy to me. When I install them, they crush a bit, and the mount ends up not being square. Has anyone else noticed this? I decided to put some metal suspension shims I had from another car in there. I'm curious to hear what you guys have experienced.
R Doyel is offline   Reply With Quote
Old 12-17-2011, 01:13 AM   #5042
Geberit's Avatar
There is an Error in the setup, the Steering Bellcranck and Steering Link values are swapped.
Geberit is offline   Reply With Quote
Old 12-17-2011, 05:06 AM   #5043
Originally Posted by Jim Frahm View Post
I'm almost finished with mine. I was just about to start building the shocks when I noticed most of the setup sheets list the shock piston as a 1,1,1.5. The kit pistons are 1 or 2 or 3. Which pistons and oil should I start with. My local track is medium grip carpet and it's small.
Thanks,
Jim
1,1,1.5 are Reflex pistons, usually AE #2 with 40 oil should be a good start.
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 12-17-2011, 05:08 AM   #5044
This was the case on TC6 manual, we talk about this a while back.
Was this not corrected on TC6.1 manual??
Old 12-17-2011, 05:45 AM   #5045
Chaz955i's Avatar
THose clips work ok up front when running no toe. any mismatch from the front to the back of the inner pin and the plastic clips just deform and do not hold a setting. Most of us have either done what you have done or switched to the 12r5 bulkhead washers.
Chaz955i is offline   Reply With Quote
Old 12-17-2011, 11:17 AM   #5046
S_fender's Avatar
YEs the TC6.1 manual is Ok.
S_fender is offline   Reply With Quote
Old 12-17-2011, 12:58 PM   #5047
Thanks Seb, did you get your yet?
Old 12-17-2011, 01:20 PM   #5048
Geberit's Avatar
http://www.teamassociated.com/pdf/ca...ndoor_2011.pdf
Steering Link in this setup is 7B and Steering Bellcrank 2B??? Look at the setup sheet closely or is something in my eye???
Old 12-17-2011, 01:46 PM   #5049
We are not talking about Keven setup sheet, but the TC6 manual had mistakes between the steering link/bellcrank.
Old 12-17-2011, 08:24 PM   #5050
Two-speed's Avatar
Trader Rating: 24 (100%+)
http://www3.towerhobbies.com/cgi-bin...&I=LXVSW0&P=7#
These?
Two-speed is offline   Reply With Quote
Old 12-17-2011, 08:52 PM   #5051
Chaz955i's Avatar
Yeah, I thought they were cheaper at Amain but I might be mistaken.
Old 12-17-2011, 10:59 PM   #5052
Default Servo
Just getting back into on road. What servo is recommended? Looking to stick with savox.
Seeds is offline   Reply With Quote
Old 12-17-2011, 11:14 PM   #5053
eds24's Avatar
Trader Rating: 56 (100%+)
Send a message via AIM to eds24 Send a message via Yahoo to eds24
This servo from Savox is recommended and many use them.. its low profile so it won't hang off the edge of the chassis and it is a good mix of speed and torque. Not a bad price either.
http://www.savoxusa.com/Savox_SC1251...avsc1251mg.htm
eds24 is offline   Reply With Quote
Old 12-18-2011, 02:01 AM   #5054
S_fender's Avatar
Not yet. But i've downloaded the manual.
I'm waiting january when it will be available in France at SMS.
Sébastien.
Old 12-18-2011, 05:12 AM   #5055
idbdoug's Avatar
Trader Rating: 33 (100%+)
Looking at the T6.1 manual,,how much rear toe-in can we set???
Also,are the rear hubs different from the T6??? I don't see 1 degree hubs for the rear on the parts list
idbdoug
idbdoug is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 07:34 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28937 01-14-2017 07:26 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 12:42 PM
SEO by vBSEO 3.5.0
