Like Tree1Likes
Old 12-09-2011, 08:07 AM   #4981
tr1kstanc3's Avatar
Trader Rating: 18 (100%+)
Originally Posted by olly986 View Post
3mm if it is what I think you need to do, ie, inner hinge pins in wishbones.
Thanks. I noticed some arms didn't move freely, some had slop, and some were fine. I'll double check the hinge pins too.
tr1kstanc3 is offline   Reply With Quote
Old 12-09-2011, 08:15 AM   #4982
Asharus's Avatar
Trader Rating: 42 (100%+)
Originally Posted by cwoods34 View Post
I had an outer hinge pin that was machined about .50-.65mm too small, and caused a ton of play with the caster block. Otherwise, all of the arms in my kit were perfect!
interesting, i had the same issue, but i figured the previous owner just used the wrong hinge pin
Angelo Padilla
Team Ballz Racin | PCR Bodies | Island Raceway & Hobby | Gilligan's Raceway
Asharus is offline   Reply With Quote
Old 12-10-2011, 06:52 PM   #4983
Default Pinion interference with belt problem
Hello,
I've read through about half of this thread and did a couple of searches. I was unable to find an answer to my problem
Im using Robinson racing pinions on a trinity revtec. My problem is the pinion hits the belt no matter which way I install it. Set screw toward the motor and set screw away from the motor.
When the set screw is away, the grub screw looks like it will catch the belt teeth, but the spur and pinion line up nice.
When the set screw is toward the motor it looks like the side of the belt will rub against the pinion. Also, the pinion does not line up very well with the spur. I think the reason is, the flat portion of the motors armature does go far enough toward the motor.
The only thing I can think to do is put some spacers or washers between the motor and the motor mount. But that doesnt feel like the right thing to do.
What am I missing. Any help would be greatly appreciated.
Anthony
AnthonyN is offline   Reply With Quote
Old 12-10-2011, 07:07 PM   #4984
Asharus's Avatar
I was going to get the Revtech for my TC6 as well, but Trinity's rotors do not have a flat spot all the way to the motor endbell. You can fix this by dremeling or filing the flat spot closer to the endbell.
I ended up getting a Reedy Sonic instead of doing this mod. So far I'm happy with the Sonic.
Angelo Padilla
Old 12-10-2011, 07:59 PM   #4985
smedly's Avatar
I had the same problem with my Fantom racing motors. What I found was the flat on the motor shaft was not machined far enough down the shaft. Using a dremel with a cut-off wheel, carefully continue the flat as close to the motor can as possible. This will allow the pinion to be installed with the set-screw toward the can, and will clear the belt and line up properly with the spur.
There is a hole in the chassis that allows access to the set-screw.
Originally Posted by AnthonyN View Post
Hello,
Anthony
Brad "Smedly" Dodrill
Sponsors: GO-Engines-USA, Fantom Racing, Tekin, Upgrade, RC Sure-Start.
smedly is offline   Reply With Quote
Old 12-10-2011, 08:33 PM   #4986
ScottyTC4NZ's Avatar
Send a message via MSN to ScottyTC4NZ
Originally Posted by Rick Hohwart View Post
You can try slightly more toe-in. And make sure the slipper spool is TIGHT. Depending on the class you are racing, you can tone down the motor so that it does not spin the tires as easily.
I'm running X-12 Stock Spec 13.5t
I tried adjusting the toe today with 2x2mm spacers on rear mount and 1x2mm front mount on the rear bulk head to create more toe in but it stillseem to be real tailey in rear, slipper is tight, only other thing is it's a low traction traction track, so i shorten the wheel base and dropping the arm mounts to the lower hole on bulk head.
HELP
Jamie Scott
Onroad Race Director
O.R.C.C.C
Titan ARC R10 2013 / Blitz / Sweep / Team Titan
Titan ARC R10 Upgrade / Blitz / Sweep / Team Titan
ScottyTC4NZ is offline   Reply With Quote
Old 12-11-2011, 01:48 AM   #4987
HELP
how much droop do you run Jamie ? also whats oil and springs do you run,
im wondering if my CMR/Feilding setup would work.
ed
Edwin Pibal is offline   Reply With Quote
Old 12-11-2011, 02:58 AM   #4988
and tyres? heat + treatment?
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 12-11-2011, 03:20 AM   #4989
ed
Droop is 5mm front and rear
Springs Gold front silver rear
40wt oil
Jamie Scott
O.R.C.C.C
Old 12-11-2011, 03:21 AM   #4990
Tyres are sorex 32r
and no treatment we dont run it here
Jamie Scott
O.R.C.C.C
Old 12-11-2011, 03:29 AM   #4991
You could try silver front and green rear, piston 2 with 40 front 35 rear.
or try the Reflex springs and either 1,1,1.5 reflex piston or Losi 56.
You could maybe raise the rear droop to 5.3/5.5
You could also move back to position 3 instead of 7 but you need a shorter link. (has it was on TC5)
Old 12-11-2011, 08:01 AM   #4992
cneyedog's Avatar
Send a message via AIM to cneyedog
Hello,
Anthony
just dremel a flat spot closer to the bearing on the same side of the exisiting flat spot and your all set. The material grinds down easily and makes life alot easier when your setting the gear mesh.
cneyedog is offline   Reply With Quote
Old 12-11-2011, 10:06 AM   #4993
cwoods34's Avatar
With a ReVtech motor and Trinity/Epic pinions, I didn't need to extend the flat spot on the shaft. They are shorter than the other brands of pinions I have. Keep that in mind plus the gold looks badass.
On low traction, I usually find softer springs with low roll centers to make the best grip, along with 2 gear diffs..... think 0B or 3A all around, with silver/green. Some guys are running blue/green here to keep the car a bit flatter, with about 2mm uptravel/droop all around. Gold/silver is a pretty stiff combination......
My friend has a "point and shoot" driving style, and he is typically as fast as me. He always makes a ton of grip on low bite (where as I'm usually faster on high bite). This is because all of his high-speed driving is in a straight line. I think he's running 1B/0B front, 1B/1B rear with 14.5/13.5 springs...... he likes a spool up front. Might be worth a shot......
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 12-11-2011, 01:00 PM   #4994
40wt oil
i run 45 up frount on silvers and 40 in the rear on silvers
with 5mm ride hight and 2mm droop on both ends.
works well up here
if you pm your email address i can send you my setup if you like
Ed
Old 12-11-2011, 01:45 PM   #4995
frenchchris's Avatar
Good evening
yesterday i want to my local track to end the setting of my new tc6
i run a low grip track n the car was really amazing
i use the down arm holes
i replace the plastic spacer fittings arms by the alloy spacers the car is really more pleasant on track
i run a ztw 120 A with xerun 4.5T
24 / 87 on 48 dp
here after some pics of my car
good evening
Team Associated TC6 Thread-11122011266.jpg   Team Associated TC6 Thread-11122011269.jpg   Team Associated TC6 Thread-11122011270.jpg   Team Associated TC6 Thread-11122011271.jpg   Team Associated TC6 Thread-11122011268_2.jpg
frenchchris is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28952 05-01-2017 04:47 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
