Old 12-06-2011, 04:15 PM   #4966
Trader Rating: 77 (100%+)
Originally Posted by jorgesimes View Post
here you go: New Parts for TC6.1
Nice. Thank you.
goin2drt is offline   Reply With Quote
Old 12-06-2011, 04:20 PM   #4967
YoDog's Avatar
Trader Rating: 25 (100%+)
Originally Posted by jekyll08 View Post
is there a firm release date for the tc6.1
Technically the kit has been released. It's just a matter of time before they are in the hands of the dealers. Rick mentioned we should see them start to show up in the next week or two. Just in time for Christmas! I think there is mention of it a page or two back.
Check post #4898
YoDog is offline   Reply With Quote
Old 12-06-2011, 11:01 PM   #4968
smedly's Avatar
I broke the kit servo horn in my tc6 this last weekend. I've had a tc5 and another tc6 before and never broke the servo horn on either one.
I dug in my 8th scale stuff looking for a plastic servo horn that came with my RC8 which is more stout. I used a body reamer to open up the second hole, but I did not go right through the center of the hole because it would be too short. (the outer hole is way too long) As I reamed it, I progressed slowly with just the tip of the reamer and basically oblonged the hole and it is the exact size needed. After I was done, i cut the end off the servo horn and shaped it with a dremel.
I run aluminum horns on my rc8 and rc8t, so these were just sitting around. I figured i could buy extra tc6 servo horns but risk breaking more of them. Also, when i built the tc6 kit I followed the servo saver set-up of 0.5mm between the c-clip and bottom of the servo saver nut, so I didn't feel like backing off the nut was the solution as some of my fellow racers have said.
Definitely should never break an 8th scale servo horn on a TC.
The f servo horn is 25 spline and is used for futaba and savox.
Originally Posted by zi032 View Post
can anyone help me find a replacement servo arm for my tc6. I used the f from the kit as I think was suggested somewhere in this thread the servo is savox 1251mg and i had trouble getting it to slide onto the servo anyway.
Brad "Smedly" Dodrill
Sponsors: GO-Engines-USA, Fantom Racing, Tekin, Upgrade, RC Sure-Start.
smedly is offline   Reply With Quote
Old 12-06-2011, 11:35 PM   #4969
Odin544's Avatar
Trader Rating: 93 (100%+)
Definitely shouldn't. But hit something hard enough and something is gonna break. If not the servo horn, maybe something more expensive. Something to think about.
I've stripped the ball stud out of mine once so far. But that's also one of the cheapest parts on the car. So I dont mind replacing it every once in a while.
Odin544 is offline   Reply With Quote
Old 12-07-2011, 07:21 AM   #4970
burgboyz's Avatar
Trader Rating: 70 (100%+)
Originally Posted by dennisV View Post
I have exactly the same "problem". But it seems that the diff is holding well. I havent raced with it yet, but will next Sunday.
I ran mine last night. Practice runs, 3 heats and a main with no leaks or issues with the diffs at all. Just the boards kept getting in the way of TQ runs!!
Very minor aesthetic mold flaw is all it is with mine. No big deal!!!
Got Droop???
Speed Passion....Speed Power....Serpent America/Desoto Racing.
burgboyz is offline   Reply With Quote
Old 12-07-2011, 07:33 AM   #4971
Spool or diff in the front? and why.
New to carpet racing i have the diff up front now.
Shortbusallstar is offline   Reply With Quote
Old 12-07-2011, 08:52 AM   #4972
Depends on driving style, which class and which track you run at
@burgboyz ah good. I can't wait to test it out Sunday.
株式会社 ヨコモ
dennisV is offline   Reply With Quote
Old 12-07-2011, 05:27 PM   #4973
Big Features's Avatar
Got to run my car today with the new diff and spool and I'm very impressed with the quality and smoothness. Its the smoothest gear diff I've found.
I didnt see any mold deformaties, mine must be newer.
Mike
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix
Big Features is offline   Reply With Quote
Old 12-08-2011, 03:08 PM   #4974
tr1kstanc3's Avatar
Trader Rating: 18 (100%+)
Default Arm reamers
Hi guys. What size arm reamers do I need for the TC6 suspension arms? Wondering if people use reamers and/or drill bits to accomplish this task.
tr1kstanc3 is offline   Reply With Quote
Old 12-08-2011, 03:16 PM   #4975
3mm if it is what I think you need to do, ie, inner hinge pins in wishbones.
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 12-08-2011, 03:16 PM   #4976
Chaz955i's Avatar
Have you tried fitting them yet? My kit went together without having to do any work on the arms.
At The Gate Bizzos
Chaz955i is offline   Reply With Quote
Old 12-08-2011, 03:24 PM   #4977
out of maybe 10 different arms between 2 cars, some were a little stiff and some fitted perfectly..luck of the draw
Old 12-08-2011, 03:50 PM   #4978
Trader Rating: 20 (100%+)
I found on my kit it was not the arms but the hinge pins so before reaming the arms check the pins by rolling them on a flat surface
trailblazer04 is offline   Reply With Quote
Old 12-08-2011, 05:30 PM   #4979
cwoods34's Avatar
I had an outer hinge pin that was machined about .50-.65mm too small, and caused a ton of play with the caster block. Otherwise, all of the arms in my kit were perfect!
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 12-09-2011, 07:07 AM   #4980
I replaced the plastic spacers with aluminum for the toe & wheel base to avoid the slopp havent tested yet but on the bench she feels smooth
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 07:34 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28937 01-14-2017 07:26 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 12:42 PM
SEO by vBSEO 3.5.0
