Like Tree1Likes
Old 11-27-2011, 12:03 AM   #4801
frenchchris's Avatar
Default RIGID FRONT AXEL
hy all
for the front rigid axel addict like myself you can do one on really simple way
start from a TC5 aluminium part you just trim the short side in order to take totally out the place where the ball bearing is fitted because the tc 5 is wider
the long one is the same
it is really easy you can fit you axel on a dremel or other and just turn it removing the aluminium
after you can use some little tube or other to craate the new place where you will apply the shim n the ball bearing + plastic parts
just try n let me know
have a nice rolling sunday
this way you got a hard spool in 10 mns
frenchchris is offline   Reply With Quote
Old 11-27-2011, 06:22 AM   #4802
Originally Posted by rcguy48 View Post
hi guys. How do you guys like the tc6. Do you think it will be better to get an xray or to just get a tc6. I have a tc5r now and i want to get a new tc.
Asking on a TC6 post that question is like answering yourself..
Wait to get the 6.1 if you buy new.
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 11-27-2011, 07:55 AM   #4803
YoDog's Avatar
Trader Rating: 26 (100%+)
It would be a good idea to go back about 15 pages and read up to here. You will get plenty of opinions on this subject. It get's a little redundant to answer the same questions over and over when the answers have already been given.
Your decision should be based on budget, parts availability and setup support at you track. The TC6.1 will be available soon so you may want to wait a bit or you could buy the car posted on the previous page. The TC6 is quite competitive.
YoDog is offline   Reply With Quote
Old 11-27-2011, 09:08 AM   #4804
rangerjkb's Avatar
Trader Rating: 39 (100%+)
Send a message via MSN to rangerjkb
+1, of course I am extremely pleased with the TC6. Easy to drive fast, setup and parts support everywhere with a relatively inexpensive price tag. The 6.1 is available soon, recommend that kit if you go with AE.
Jason Burks
Psycho Cells Racing~Hal's Hobby Warehouse~Murfdogg Products~Avid RC
rangerjkb is online now   Reply With Quote
Old 11-27-2011, 11:46 AM   #4805
For_the_win's Avatar
When does the tc6.1 come out, Ive been looking but nothing yet.
For_the_win is offline   Reply With Quote
Old 11-27-2011, 02:55 PM   #4806
rcguy48's Avatar
Idk i want to know too. I dont think they said a release date yet.
Tamiya TRF417|Savox|Airtronics|Reedy|Tekin
Team Durango DEX410|Savox|Airtronics|Reedy|Castle Mamba Pro
Tc5r
Als Hobby Shop Elmhurst Phone: 1-630-832-4908
Team Durango
rcguy48 is offline   Reply With Quote
Old 11-27-2011, 03:05 PM   #4807
Release date December 2011.
https://www.gofundme.com/ncontrol
Joe Maxey is offline   Reply With Quote
Old 11-27-2011, 03:07 PM   #4808
rcguy48's Avatar
Do you know when in december???
Tc5r
Team Durango
Old 11-27-2011, 05:38 PM   #4809
burgboyz's Avatar
Trader Rating: 70 (100%+)
Originally Posted by ScottyTC4NZ View Post
Hi Guys
Ran my TC6 today, First raceday out with it.
Very nice to run, a wee bit tailey coming out of the corners
Any fix for that?
basicly running stock setup
Adding rear toe is a quick and easy solution. I have found the difference of adding a .5mm shim is very noticeable for instance.
Got Droop???
Speed Passion....Speed Power....Serpent America/Desoto Racing.
burgboyz is offline   Reply With Quote
Old 11-27-2011, 06:05 PM   #4810
CREWMAN's Avatar
Trader Rating: 19 (100%+)
I dont know if this was asked or addressed already but what does the tc6.1 have that the tc6 does not?
D&K HOBBIES!!!!
Losi 8ight-T 2.0 Race Roller/Losi 350/JR 9100 Servos/Spektrum DX3R
BMI Copperhead 12/Thunder Power Lipo/Futaba Servo/Express 17.5/Spektrum DX3R
CREWMAN is offline   Reply With Quote
Old 11-27-2011, 07:01 PM   #4811
TedBull's Avatar
Features
•Updated suspension arms for increased stiffness and strength, as well as finer shock adjustments
•Hubs and caster blocks use integrated inserts for adjustable caster and toe angles
•H.D.R.C. (High Definition Roll Control) system
•Lightweight rear gear diff for maximum performance and minimal maintenance
•Front spool with replaceable composite outdrives
•Offset arm mounts help increase durability and minimize shims between mount and bulkhead
•Ultra-narrow chassis layout optimized for Lithium Batteries and Brushless Motors
•Symmetrical bulkhead layout minimizes spare part cost
•Multi-position steering system to fine-tune Ackermann/steering rates
•VCS3 Shock with hard-anodized threaded shock bodies
•Titanium turnbuckles with new ballcup eyelets for easy access to ball stud
•16 precision ball bearings
•Cross-compatibility with TC6 chassis components
TedBull is offline   Reply With Quote
Old 11-27-2011, 07:38 PM   #4812
Features of the TC6.1 that differ from the TC6:
JamesL_71 is offline   Reply With Quote
Old 11-28-2011, 05:29 AM   #4813
swimbikerun's Avatar
Trader Rating: 100 (100%+)
Also different axles (CVD's) and axle crush tube due to the larger bearings at the hubs (6x10 vs. 5x10).
-Xray T4 '16/Xray X12 '16
-2010 Cincinnati Beer Mile Champion
swimbikerun is offline   Reply With Quote
Old 11-28-2011, 09:08 AM   #4814
Rick Hohwart's Avatar
Originally Posted by olly986 View Post
Rick I have a question, did you or any other team drivers tried the new diff gear with only 2 satellite gears instead of 4, as used in the Serpent 411?
If so can you tell us what was the result?
I am a little surprise that only 2 are used in their car.(apparently for weight purpose)
Regards,
I have not tried this. When gear diffs were first introduced there were some concerns with their weight. If I remember correctly they were introduced by Serpent at a time when the minimum weight was hard to achieve. So making them as light as possible made sense.
Now even with two gear diffs (one filled with putty) the minimum weight is easy to achieve and the additional rotating mass of these diffs does not seem to be a problem.
Originally Posted by Geberit View Post
What's up with Juho's set-up from ATS?
It will be posted today hopefully.
Originally Posted by Chaz955i View Post
I'm interested in Hebert's setup from the indoor champs. Just watched him through a couple rounds of qualifying and that car is dialed.
I'll post it as soon as I receive it. My guess is tomorrow.
I think the TC6 is a better value.
Hi Guys
Any fix for that?
You can try slightly more toe-in. And make sure the slipper spool is TIGHT. Depending on the class you are racing, you can tone down the motor so that it does not spin the tires as easily.
Rick Hohwart is offline   Reply With Quote
Old 11-28-2011, 09:23 AM   #4815
Default New TC6 setup posted
I just added Andrew Abbott's setup from his second place finish at the Australian Nationals. Looks like a great low to medium traction setup.
Andrew Abbott - 2011 Australian Nationals
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28975 10-20-2017 10:40 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
