Like Tree1Likes
Old 11-24-2011, 01:26 PM   #4786
Originally Posted by hacker View Post
I have too much rear grip, especially off power. I've put on a harder rear roll bar, 14.5 rear spring, less front droop, more rear droop, moved rear shock out 1 hole, slightly stiffer rear shock oil, forward 1 hole ackermann. Goop the whole front tyre. Funny enough none of the changes made much difference, if any.
I do have 6 degree caster block on, only cos they were the only ones I have as spares at the time. Should I go back to 4's?
What would be my next step, regarding roll center changes or any other changes? I don't have the correct length turnbuckles for front link changes though....
lengthen rear camber link?
I'm bit dumb with car setup
Have you tried changing your wheelbase?
Team AME/ORCA
https://www.facebook.com/strawberryrcdesigns
http://www.strawberryrcdesigns.pt/
jorgesimes is offline   Reply With Quote
Old 11-24-2011, 01:45 PM   #4787
hacker's Avatar
Trader Rating: 140 (100%+)
Originally Posted by wtcc View Post
I think it would be better to just reduce the caster on the rear axle. Maybe a total of .5 - 1.0 mm less shims under the rear armmounts would make your car turn better.
oh yes sorry, forgot to mention I have reduced rear toe from the standard 4 degree arm mount shims to 3.5. Might need to reduce this even more.
hacker is offline   Reply With Quote
Old 11-24-2011, 01:49 PM   #4788
hacker's Avatar
no not yet, it's one of my next things to do also. Just need some track time
however there seems to be some conflicting opinions regarding rear wheelbase. According the tc6 manual, lengthening the rear wheelbase will decrease traction, which is what I want. However other car setups say lengthening the rear wheelbase will make the car more stable and promote rear grip.
But I will give it a go too. Thanks
Old 11-24-2011, 02:02 PM   #4789
Try 2mm rear and 1mm front wheelbase and make sure you have 2.5 rear toe. Or perhaps you want to give it a try: http://www.info-rc.net/wp-content/up...iorca_2011.pdf
Team AME/ORCA
Old 11-24-2011, 02:24 PM   #4790
burgboyz's Avatar
Trader Rating: 70 (100%+)
I think you will find when you reduce rear toe it will free up the rear end. Then you will need to find the balance you like for on power. I fall back to Hebert's latest super stock high grip carpet setup for a baseline. Alot depends on how much grip in the track of course.
I have too much rear grip, especially off power. I've put on a harder rear roll bar, 14.5 rear spring, less front droop, more rear droop, moved rear shock out 1 hole, slightly stiffer rear shock oil, reduce rear toe in, forward 1 hole ackermann. Goop the whole front tyre. Funny enough none of the changes made much difference, if any.
Got Droop???
Speed Passion....Speed Power....Serpent America/Desoto Racing.
burgboyz is offline   Reply With Quote
Old 11-24-2011, 09:03 PM   #4791
hacker's Avatar
Went to 2.5 rear toe but was too hard to drive. Ended up on 3degree rear toe in and car is much better now, thanks for help everyone!
Old 11-24-2011, 10:27 PM   #4792
bshookup's Avatar
Trader Rating: 18 (100%+)
Glad you got your car working better. One thing that I didn't see mentioned was front camber. On carpet I could feel the difference between 1 degree and 1.5 degrees of front camber on turn in. I haven't tried it on carpet, but on asphalt, raising the rear roll center by raising the rear hinge pins really woke the car up for me.
TEAM ASSOCIATED
REEDY
TEAM POWERS: www.teampowersusa.net/
bshookup is offline   Reply With Quote
Old 11-25-2011, 12:21 AM   #4793
Two-speed's Avatar
Trader Rating: 24 (100%+)
So will there be an upgrade kit for the 6 to a 6.1? Or will all of us recent tc6 purchasers be forced to cobble one together?
Two-speed is offline   Reply With Quote
Old 11-25-2011, 09:33 AM   #4794
I'd suggest second options if you want to do it soon, don't forget you do not need everything...
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 11-25-2011, 06:41 PM   #4795
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
I know this isn't the right section but I think I'm gonna sell my new tc6 I just picked up. If anyone wants it please pm me. I have decided to change hobbies for the mean time now.
TRF-417, KYOSHO SCR-SP
Mr.juarez is offline   Reply With Quote
Old 11-26-2011, 03:55 AM   #4796
Rick I have a question, did you or any other team drivers tried the new diff gear with only 2 satellite gears instead of 4, as used in the Serpent 411?
If so can you tell us what was the result?
I am a little surprise that only 2 are used in their car.(apparently for weight purpose)
Regards,
Old 11-26-2011, 08:51 AM   #4797
Geberit's Avatar
What's up with Juho's set-up from ATS?
Geberit is offline   Reply With Quote
Old 11-26-2011, 12:58 PM   #4798
Chaz955i's Avatar
I'm interested in Hebert's setup from the indoor champs. Just watched him through a couple rounds of qualifying and that car is dialed.
At The Gate Bizzos
Chaz955i is offline   Reply With Quote
Old 11-26-2011, 09:49 PM   #4799
rcguy48's Avatar
hi guys. How do you guys like the tc6. Do you think it will be better to get an xray or to just get a tc6. I have a tc5r now and i want to get a new tc.
Tamiya TRF417|Savox|Airtronics|Reedy|Tekin
Team Durango DEX410|Savox|Airtronics|Reedy|Castle Mamba Pro
Tc5r
Als Hobby Shop Elmhurst Phone: 1-630-832-4908
Team Durango
rcguy48 is offline   Reply With Quote
Old 11-26-2011, 11:28 PM   #4800
ScottyTC4NZ's Avatar
Send a message via MSN to ScottyTC4NZ
Hi Guys
Ran my TC6 today, First raceday out with it.
Very nice to run, a wee bit tailey coming out of the corners
Any fix for that?
basicly running stock setup
Jamie Scott
Onroad Race Director
O.R.C.C.C
Titan ARC R10 2013 / Blitz / Sweep / Team Titan
Titan ARC R10 Upgrade / Blitz / Sweep / Team Titan
ScottyTC4NZ is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28952 05-01-2017 04:47 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
