Like Tree1Likes
Old 11-22-2011, 02:03 PM   #4711
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Looks like A-Main has the TC6.1 on Pre-order for 399.99 Thats about $50 more than the TC6.
http://www.amainhobbies.com/product_...ouring-Car-Kit
YR4Dude is offline   Reply With Quote
Old 11-22-2011, 02:07 PM   #4712
Guess that the price will drop once the original TC6 kits are out of stock.
株式会社 ヨコモ
dennisV is offline   Reply With Quote
Old 11-22-2011, 02:25 PM   #4713
PadrinoNY's Avatar
Trader Rating: 58 (100%+)
Send a message via AIM to PadrinoNY Send a message via Yahoo to PadrinoNY
Originally Posted by JamesL_71 View Post
According to the parts list, the chassis has not been changed. It should be the same as the TC6 chassis.
The chassis is the same...
Ulysses AKA Pucho
PadrinoNY is offline   Reply With Quote
Old 11-22-2011, 02:36 PM   #4714
PadrinoNY's Avatar
This is the actual parts list needed to convert your TC6 to the 6.1. Of course this is MSRP:
31356 TC6.1 FRONT ARMS $7.99
31357 TC6.1 REAR ARMS $7.99
31358 TC6.1 CASTER BLOCKS $7.99
31359 TC6.1 REAR HUB CARRIER $6.99
31360 TC6.1 STEERING BLOCKS $5.99
31361 TC6.1 OFFSET ARM MOUNTS $8.99
31362 TC6.1 ANTI ROLL BARS $27.99
31363 TC6.1 ANTI ROLL BAR TUBE $8.99 x2 (possibly)
31364 TC6.1 ANTI ROLL BAR WIRE $9.99
31365 TC6.1 ANTI ROLL BAR MOUNTS $3.99
31366 TC6.1 CVA KIT $29.99 x4
31370 TC6.1 AXLE CRUSH TUBES $3.99 x2
25237 Bearing 5x10x4 $4.99 x2
1402 1.375" Turnbuckle $7.99 x2
31550 M3 Locknuts $7.99 x2
31399 TC6 Spool $34.99
31344 TC6 Gear Diff $44.99
The grand total again MSRP is looking like $356.75. Would like to see what the street prices will look like to see if it worth converting..... Keep in mind MSRP on the TC6 was $649.99 and so will this one I assume...
Ulysses AKA Pucho
Last edited by PadrinoNY; 11-22-2011 at 02:47 PM. Reason: changed amount based on kit....
Old 11-22-2011, 02:47 PM   #4715
Originally Posted by YR4Dude View Post
Anyone noticed in the pics that despite the narrow chassis design, they're still able to fit a full sized servo on the chassis.
Look at the posts, it has spacers to get the servo inside.
Team AME/ORCA
https://www.facebook.com/strawberryrcdesigns
http://www.strawberryrcdesigns.pt/
jorgesimes is offline   Reply With Quote
Old 11-22-2011, 02:59 PM   #4716
Jesus... Again, you guys are blowing this out of proportion.
The only thing that the TC6 owners really need to upgrade to the TC6.1, are the plastic suspension pieces and the rear gear diff(provided they don't have one already).
There is no real reason to spend $150 on the new CVAs and new bearings. The new units allow for the use of a slightly larger bearing, so odds are the bearings are more durable. It also allows for drop-in use of more of the DCJs on the market... But as it sits, there appears to be no functional difference between the CVs in the TC6 and TC6.1 kits.
I would put money on the "31362 TC6.1 ANTI ROLL BARS $27.99 " kit coming with the little parts listed below it, just like the current "Anti roll bar kit" comes with all the mounting blocks and turnbuckle pieces needed.
You have a TC6 and you want to have a 99.99% functionally identical car to the TC6.1??? This is what you need:
31362 TC6.1 ANTI ROLL BARS $27.99 ( x2, maybe?)
= $120-150... including the price of the gear diff, which 80%+ of the TC6 racers already seem to have.
And that is MSRP...
If you already own a gear diff, you are probably going to end up paying ~$80 to convert your car over with all the suspension pieces.
JamesL_71 is offline   Reply With Quote
Old 11-22-2011, 03:09 PM   #4717
YoDog's Avatar
Trader Rating: 26 (100%+)
The items above in RED are most likely by the pair or a complete set rather than per part. The spool is really unnecessary since the slipper is already good enough.
And YES the sway bar setup is a knock off of the TM E4 RS and FS which were not bearing raced.
I hope Santa brings me a new TC 6.1 ;-)
YoDog is online now   Reply With Quote
Old 11-22-2011, 03:23 PM   #4718
Santa will have to open an account at Team AE, if he doesn't has one already.
Team AME/ORCA
Old 11-22-2011, 04:11 PM   #4719
sosidge's Avatar
This HDRC system is an interesting (if over-named) approach to the anti-roll bar. Will be interesting to see how people get along with it.
Personally speaking, if I was to go down that hybrid-bar route, I would have made the levers solid and had a replaceable torsion section.
Old 11-22-2011, 04:20 PM   #4720
RAL
RAL's Avatar
Trader Rating: 59 (100%+)
Info about updates are posted:
http://www.teamassociated.com/cars_a.../Factory_Team/
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 11-22-2011, 06:40 PM   #4721
cherokee95's Avatar
Am I the only one that thinks this car has enough changes to justify it's own thread?
Sioux Falls RC Crawlers
*Futaba*Hitec*Savox*Tekin*Castle Creations*i-Charger*Team Brood*Holmes Hobbies*
~Axial~Tamiya~Locked Up RC~RC4WD~Rogue Element~
cherokee95 is offline   Reply With Quote
Old 11-22-2011, 06:59 PM   #4722
epowr_Racing's Avatar
well it seems that way , lol .. but have you guys notice the only parts that were used at the ATS were the gear diff/Spool and the new suspension arms upgrade, looking at the pictures of Levanen, the new sway bar was not use,
and it seems like Hot bodies spur gears,
Team Associated TC6 Thread-sun-levanentc6-3.jpg   Team Associated TC6 Thread-sun-levanentc6-4.jpg   Team Associated TC6 Thread-sun-levanentc6-6.jpg
Think, Feel, Operate: Control The Power Of Dreams...
Serpent 966TE,.21 Flash Novarossi, AE TC-6 ,17.5 R Speedpassion, Xray NT1 2011 Spec, .12 Novarossi, Ko Propo radio & Servos
epowr_Racing is offline   Reply With Quote
Old 11-22-2011, 07:02 PM   #4723
Timbulb's Avatar
Yeah probably.
Timbulb is offline   Reply With Quote
Old 11-22-2011, 07:03 PM   #4724
rangerjkb's Avatar
Trader Rating: 36 (100%+)
Send a message via MSN to rangerjkb
it is a .1 version of the TC6. I imagine alot of current TC6 owners will be interested to see the changover effects as parts become available.
Jason Burks
Murfdogg Products~Psycho Cells Racing~Hal's Hobby Warehouse~Avid RC~Kal-Gard~VP Powermaster
rangerjkb is offline   Reply With Quote
Old 11-22-2011, 07:15 PM   #4725
Yeah, it looked like Levanen was only using the plastic suspension pieces. Was still using the old arm mounts and swaybar setup.
Even more interesting, is it appears he was using the SpecR gear diff in front while using the AE gear diff in back.....
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28947 03-17-2017 11:30 AM
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 06:34 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
