Like Tree1Likes
Old 11-21-2011, 01:42 PM   #4651
Any pic of the new parts
f1o7x9 is offline   Reply With Quote
Old 11-21-2011, 01:45 PM   #4652
jvroffroadrc's Avatar
I saw a email from some one from HRP i think that said the TC6.1 was ready for release now. Not much info on what all was new in the kit just new diff for sure but it looked nice, you can cont on rc10 having pics and info on there site this week.
jvroffroadrc is offline   Reply With Quote
Old 11-21-2011, 02:10 PM   #4653
ASC30107 TC6.1 FACTORY TEAM SEDAN KIT
Serzoni is online now   Reply With Quote
Old 11-21-2011, 02:22 PM   #4654
I'm interested in the changes they made to the car other than on the pictures. Can't image what they would improve, the car is quite good out of the box. I can image they add the gear diff default now.
株式会社 ヨコモ
dennisV is offline   Reply With Quote
Old 11-21-2011, 04:12 PM   #4655
rangerjkb's Avatar
Trader Rating: 36 (100%+)
Send a message via MSN to rangerjkb
TC6.1 is listed, but no specifics or detailed pics. Cant wait to see what changes are in store for us.
Jason Burks
Murfdogg Products~Psycho Cells Racing~Hal's Hobby Warehouse~Avid RC~Kal-Gard~VP Powermaster
rangerjkb is offline   Reply With Quote
Old 11-21-2011, 04:25 PM   #4656
Rick Hohwart's Avatar
Detailed information will be posted tomorrow on the AE website.
Rick Hohwart is offline   Reply With Quote
Old 11-21-2011, 04:26 PM   #4657
Logi Maker's Avatar
Trader Rating: 49 (100%+)
From the HRP site..
I have heard the new diff and spool but am hoping for some new CVAs.. Maybe it will come with everything Reflex Racing has to offer..
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\Schelle
Logi Maker is offline   Reply With Quote
Old 11-21-2011, 09:38 PM   #4658
hanzo3's Avatar
Trader Rating: 55 (100%+)
How do you guys secure the sway bars? The bar is too loose. What part number to secure it? This is a pic from speedtech.
Chris • TRF419 • TA05V2 •
TQ RC Racing • Powered by teeth
hanzo3 is offline   Reply With Quote
Old 11-21-2011, 09:58 PM   #4659
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
Wishes-
  • Double Bellcrank
  • Gear Diff (plural?)
  • Spool
  • More Flex
  • Suspension Block Fix
  • Suspension Pieces from Ats
Can't decide what car for next year. Have not raced in a while, so I'm still going to suck (Worse). Associated is cheap, at least. But Yokomo and Serpent are so pretty. (Have to look good carbon side up, 3 laps down.)
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 11-21-2011, 10:07 PM   #4660
corallyman's Avatar
Trader Rating: 98 (100%+)
Is the info up yet Rick.....it's tomorrow already, on the East Coast.
Good to see they are using your paint scheme this time.
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 11-21-2011, 11:16 PM   #4661
Hey do they make a read gear diff for the tc5
sczrface85 is offline   Reply With Quote
Old 11-22-2011, 12:44 AM   #4662
Trader Rating: 32 (100%+)
#30107 — TC6.1 Factory Team Kit
1:10 Scale 4WD Electric On Road Competition Touring Car Kit
The RC10TC6.1 Factory Team kit is the next evolutionary step in touring car design from Team Associated. Building on the successfully proven TC6, the designers behind the doors of Area 51 added even more features, making the TC6.1 easier to tune and drive.
The TC6.1 narrow chassis has been designed around current brushless motor systems and LiPo batteries, optimizing weight distribution for superior handling. To further enhance handling performance, the TC6.1 has received updated suspension arms for increased stiffness and strength. These new suspension arms feature finer shock adjustments to help get the TC6.1 totally dialed in.
New caster blocks and rear hubs found in the TC6.1 feature integrated inserts for caster and rear-toe angle adjustments. Now you can change these angles by merely changing the inserts and not the whole assemblies, making the TC6.1 even quicker and easier to tune to the track conditions.
The TC6.1 features the new H.D.R.C. (High Definition Roll Control) system, taking anti-roll bar technology to the next level. The H.D.R.C. is built on a solid aluminum center member that rolls on a bearing surface. Roll stiffness is controlled and adjusted by the two wires that mount into the sides of the aluminum center member and link to the suspension arms. By removing the torsional flex with the aluminum center member, a higher definition of roll control is achieved with the different wire options.
New for the TC6.1 is the lightweight rear gear differential that provides maximum performance and low maintenance. The front spool now features replaceable composite outdrives that still retain the low friction, free movement performance of the CVA blades, while being much more economical to replace after a hard impact. Symmetrical blue aluminum bulkheads and cross-compatibility with TC6 chassis components also help make the TC6.1 more economical to run.
The TC6.1 comes equipped with the Factory Team VCS3 shock package that features hard-anodized threaded shock bodies with bottom-loaded seals. The VCS3 shocks are super smooth and have an increased stroke for more up-travel at the wheels, all adding up to more consistent overall traction.
Multi-position steering system with additional Ackermann options and an improved steering input rate gives the TC6.1 more consistent handling. Blue titanium turnbuckles come with new ballcup eyelets for easier access to the ball studs.
These are only a few of the many refinements that you will find in the RC10TC6.1 Factory Team kit - making it yet another Champion by Design!
TC6.1 Factory Team Kit Features:
- Updated suspension arms for increased stiffness and strength, as well as finer shock adjustments
- Hubs and caster blocks use integrated inserts for adjustable caster and toe angles
- H.D.R.C. (High Definition Roll Control) system
- Lightweight rear gear diff for maximum performance and minimal maintenance
- Front spool with replaceable composite outdrives
- Offset arm mounts help increase durability and minimize shims between mount and bulkhead
- Ultra-narrow chassis layout optimized for Lithium Batteries and Brushless Motors
- Symmetrical bulkhead layout minimizes spare part cost
- Multi-position steering system to fine-tune Ackermann/steering rates
- VCS3 Shock with hard-anodized threaded shock bodies
- Titanium turnbuckles with new ballcup eyelets for easy access
to ball stud
- 16 precision ball bearings
- Cross-compatibility with TC6 chassis components
Specifications
Power Source: Electric
Terrain: On-Road
Body Style: Touring Car
Scale Size: 1:10 Scale
Assembly Level: Kit
Length: TBC
Width: TBC
Wheelbase: TBC
Weight: TBC
Internal Gear Ratio: TBC
Drive: 4WD
Required to Complete
1:10 scale electric motor
1:10 scale electronic speed control (ESC)
7.4V LiPo, 6.0V LiFe
Battery charger
Radio and steering servo
1:10 scale (190mm) Lexan® touring car body
Spray paint for body
1:10 scale rubber or foam touring car tires
hobbs is offline   Reply With Quote
Old 11-22-2011, 12:56 AM   #4663
scoyle's Avatar
I take it that the parts will all be available to update the current car - I take it that the new parts are the new plastics (arms/hubs etc.) and the gear diff. Interested in the new roll bar system and hope it all fits my current investment (considering I have a brand new TC6 still in a box for outdoors!)
scoyle is offline   Reply With Quote
Old 11-22-2011, 12:56 AM   #4664
hacker's Avatar
Trader Rating: 140 (100%+)
They copied the Durango 2wd awesome adjustability setup.
Put me down for 1, or 2. Haha
hacker is offline   Reply With Quote
Old 11-22-2011, 02:10 AM   #4665
Geberit's Avatar
Got a brand new TC6 this week
What exactly do I need now to upgrade it to TC6.1????
Now the AE TC6 will come out as the most expensive car I could get
And I wanted to start the new season with a up to date car not an old version ...
This is just a disappointment ...
Geberit is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28952 05-01-2017 04:47 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
