Like Tree1Likes
Old 11-18-2011, 04:01 AM   #4606
Originally Posted by dennisV View Post
Where did you order them?
Mb Models Leeds Uk
http://www.rccarshop.co.uk
tc3nitro is offline   Reply With Quote
Old 11-18-2011, 07:52 AM   #4607
SkarTisu's Avatar
Send a message via AIM to SkarTisu Send a message via Yahoo to SkarTisu
Originally Posted by BSchorr View Post
The new ride completed!
Looks good, Ben! Do you have any shorter screws to use for the servo mounts? I still owe you my setup from last weekend too.
Marshall Skare
Team Associated - Reedy Powered - JConcepts - LiveRC.com
SkarTisu is offline   Reply With Quote
Old 11-18-2011, 09:23 AM   #4608
YoDog's Avatar
Trader Rating: 26 (100%+)
Car looks great! I thought I'd mention that if you intend to run mod (didn't notice what motor you have installed), you may want to mount your speedo with the solder posts facing outward as I had consistent thermal issues with my RS Pro in the orientation you have yours now. The posts act as the only heatsink for the Tekins.
This is how I had mine at first before experimenting with other positions and eventually found that having the posts outward made all the difference.
YoDog is offline   Reply With Quote
Old 11-18-2011, 10:40 AM   #4609
A couple questions I was hoping yall could help me with:
1) How does running the rear-toe hubs differ vs running all your toe inboard?
Ie: If you were running 0* rear hubs and 3* of toe-in on the arm mounts... How would the car change if you went to 1* rear hubs and 2* of toe-in on the arm mounts?
2) How much dual rate are you guys running on your radio on carpet vs asphalt?
At a local carpet race this past weekend, I was using 80% dual rate. At 90% or above, the car was simply too difficult to drive. However, I usually keep the radio @ 100% dual rate at all the asphalt races Ive been to.
How are you guys running your dual rate on these different surfaces?
JamesL_71 is offline   Reply With Quote
Old 11-18-2011, 04:37 PM   #4610
geeunit1014's Avatar
Toe inboard will give more forward bite, hub toe will free it up a little
At a standard asphalt track and on carpet, I have been using full lock. The only place I havent used full lock was the Hobbytown USA in Frederick ("The Coliseum") where its indoor asphalt with astronomical grip.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 11-18-2011, 07:43 PM   #4611
epowr_Racing's Avatar
Default My new TC-6
just wanted to share with you guys , build ,fresh and new, still waiting on the diffs, before i take it to the track,
Team Associated TC6 Thread-img00403-20111118-2334.jpg   Team Associated TC6 Thread-img00404-20111118-2334.jpg   Team Associated TC6 Thread-img00405-20111118-2335.jpg
Think, Feel, Operate: Control The Power Of Dreams...
Serpent 966TE,.21 Flash Novarossi, AE TC-6 ,17.5 R Speedpassion, Xray NT1 2011 Spec, .12 Novarossi, Ko Propo radio & Servos
epowr_Racing is offline   Reply With Quote
Old 11-18-2011, 08:23 PM   #4612
hanzo3's Avatar
Trader Rating: 55 (100%+)
any differences between Spec R and associated gear diffs?
Chris • TRF419 • TA05V2 •
TQ RC Racing • Powered by teeth
hanzo3 is offline   Reply With Quote
Old 11-19-2011, 12:00 AM   #4613
Geberit's Avatar
Levanen is testing new suspension arms for the TC6 at the ATS race in Tokyo. The results at the moment are very promising
http://ats.redrc.net/
http://www.myrcm.ch/de/ets/20111118_...odi/index.html
Modified Controlled Practice – Top 10
1. Juho Levanen – Team Associated – 16.240
2. Naoto Matsukura – Yokomo – 16.248
3. Alexander Hagberg – Xray – 16.272
4. Ronald Völker – Yokomo – 16.272
5. Akio Sobue – Tamiya – 16.488
6. Lucas Urbain – Yokomo – 16.514
7. E.C Kim – Kyosho – 16.590
8. Shin Adachi – Kyosho – 16.661
9. Martin Hudy – Xray – 16.727
10.Ivan Laptev – Awesonatix – 16.763
Geberit is offline   Reply With Quote
Old 11-19-2011, 07:35 AM   #4614
Thanks.
But are you referring to actual steering throw(ie: end point adjustment)? Or the dual rate "curve"?
Old 11-19-2011, 11:05 AM   #4615
BSchorr's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to BSchorr Send a message via Yahoo to BSchorr Send a message via Skype™ to BSchorr
Im going to keep them on there for the simple reason, that they are Orion servo screws. They are the best! I may shorten the top ones..
Get me that setup!
Also... question about these PPD billets...
1. The washer to the right represents the same number of washers that is used in the front part of the hinge pin... for these Dial a Grips.. its that so the mounts dont bind on the bulkheads... or is that a width setting?
2. Is the thickness of these mounts the same as the stock plastic ones? So if we wanted to follow a Pro's setup as far as tire width and over all toe in the rear.. would it be the same?
3. 2.7mm of toe shims equals what on this AE car?
TLR ~ MaClan ~ Hobbywing ~ Futaba ~ Proline ~ Werks Racing ~ Genesis R/C Products ~ Mr. Scrubbles ~ First Premier Satellites
BSchorr is offline   Reply With Quote
Old 11-19-2011, 11:32 AM   #4616
Get me that setup!
2.7mm is well...2.7mm, the AE plastic are 1-1.5-and 2mm
Did you go on the dial a grip posts?
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 11-19-2011, 12:12 PM   #4617
I dont know about the Dial-a-Grips... but the kit wheelbase/toe spacers(the horseshoe looking ones) are 1, 1.5, and 2 degrees. Not millimeters.
They actually measure out to .85mm, 1.30mm, and 1.70mm.
Old 11-19-2011, 12:17 PM   #4618
BSchorr's Avatar
Thats the info I need! Thanks!
Old 11-19-2011, 01:18 PM   #4619
Really!! never mesured mine, my understanding was that they were in mm, still, no combination of these makes 2.7mm, then you have to think that there is a shim on the front of arm mount too.
But, why don't you use the original shim rather than the round metal ones?
Old 11-19-2011, 01:44 PM   #4620
The blue metal ones(RC12R5 bulkhead shims) are what I use. I use them because they provide much more accurate toe settings. When you tighten down the arm mount screws with the plastic horseshoes, you can tell that there is a fair amount of give in the spacer. And it shoes on the setup station. I had up to .5 degrees difference in rear toe with the plastic pieces. With the metal bulkhead shims, the toe matches up exactly side to side. And there is no give in the spacer... you tighten them down and that is that.
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28970 09-28-2017 07:28 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
