Like Tree1Likes
Old 11-17-2011, 02:52 PM   #4591
Originally Posted by TRXRACER99 View Post
mine has about a 3mm gap
That's a big gap, mine is very close if the battery is in as far as it can, so usually I tape my cell as far out as possible to play safe.
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 11-17-2011, 03:08 PM   #4592
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
Originally Posted by olly986 View Post
Yep. it is know to happen, just contact AE for a replacement, they should do this quickly.
Originally Posted by pcar951 View Post
I had a couple of shafts bind as well. The coupler split when I threaded the set screw in the first time, caused it to bind badly, even when I took the set screw back out. Ended up replacing the coupler.
Yea I called around and no one has anything here. I'll order everything from amain. Is the ae screw kit worth it not? Is it a huge weight different? Im going to run a 340+ gram lipo so I got to cut some lard off
Going to pull an all mightier tonight and try to finish it
TRF-417, KYOSHO SCR-SP
Mr.juarez is offline   Reply With Quote
Old 11-17-2011, 03:15 PM   #4593
cwoods34's Avatar
I like the aluminum screw kit. My RevTech lipos are about 330g a piece, and even with that and 2 gear diffs I am 1395 give or take. Seems like it took about 22-25g off my car!
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 11-17-2011, 04:10 PM   #4594
Mr.juarez's Avatar
Cool deal! I think my nano techs are much heavier being a 6000 mah but I don't recall the exact amount. I'll order the screw kit next week or so. Does anyone make a ti kit?
Old 11-17-2011, 04:27 PM   #4595
cwoods34's Avatar
http://www.litemodz.com/product_info...roducts_id=408
Pricey, though.....
Old 11-17-2011, 05:50 PM   #4596
BSchorr's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to BSchorr Send a message via Yahoo to BSchorr Send a message via Skype™ to BSchorr
Soo.... I just received a TC6 with the Dial-a-grip 0's... How do I know how far to widen it in the front compared to the setups I see with the shock blocks and shims?
For this car... in the rear, regarding rear toe-in.. is it safe to say.. that if there is 3mm of washer spacers in the the rear.. then that is 3 degrees of toe-in for this car?
Because I remember with the Xray cars.. if you had a 1.5mm rear shim in the rear.. it wasnt 1.5degrees of rear toe.. it was like 2 or something... then you would add the outside hub for the final toe.
My Car...
TLR ~ MaClan ~ Hobbywing ~ Futaba ~ Proline ~ Werks Racing ~ Genesis R/C Products ~ Mr. Scrubbles ~ First Premier Satellites
BSchorr is offline   Reply With Quote
Old 11-17-2011, 07:29 PM   #4597
geeunit1014's Avatar
2.5mm of difference in shims gives 3* toe (kit setup). so every .8mm is roughly 1deg.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 11-17-2011, 07:36 PM   #4598
pcar951's Avatar
Trader Rating: 19 (100%+)
it is alway possible to drill one hole in the spur to have a wrench and screw going through
I've done this with a body reamer, it does work but I'd do 2 holes 180 degrees apart. Still don't think it'll get you to the rear motor screw though. Like other racers on here, I use the bottom hole for my blinky car, works fine.
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy | Reds Racing
pcar951 is offline   Reply With Quote
Old 11-18-2011, 12:18 AM   #4599
BSchorr's Avatar
The new ride completed!
Old 11-18-2011, 12:47 AM   #4600
If you have 3mm shim at rear/rear you should have a 0.5mm in front/rear of inboard wishbone. this will give you 3deg.
Nice setup otherwise, maybe you could invest in a smaller servo for weight, I had to put 20g weight on front/rear of cell to balance my chassis, but running 10.5t boosted I have a big fan on motor to keep everything cool.
Old 11-18-2011, 01:24 AM   #4601
Just got my Ae Tc6 gear diffs...
Man these things a good quality ! Can't wait to run them at the weekend.
For anyone building them they like a slightly lighter weight oil in them compaired to Spec-R or Yokomo.
tc3nitro is offline   Reply With Quote
Old 11-18-2011, 02:22 AM   #4602
wtcc's Avatar
Nice. Could you put one of these on your scale, please.
wtcc is offline   Reply With Quote
Old 11-18-2011, 02:51 AM   #4603
When i get home tonight i'll gladly weight them both for you.
One has putty in it and teh other contains 40wt oil.
Mark
Old 11-18-2011, 02:55 AM   #4604
Mine should be in the Mail today, got the delivery note yesterday
Excited how it will compare to the Yokomo Gear Diff
FrankH is offline   Reply With Quote
Old 11-18-2011, 03:25 AM   #4605
Where did you order them?
株式会社 ヨコモ
dennisV is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28961 07-11-2017 01:29 PM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
