Old 11-14-2011, 01:56 PM   #4546
Johnny Wishbone's Avatar
Originally Posted by Asharus View Post
Does the Revtech 17.5 have this same problem?
They use virtually the same rotor so they have the same issue. You'll have to file the flat back just a touch.......its a issue with other cars out there too. I did see some new pinions on the market that actually put the set screw hole in a couple of different places that may be the fix for this, but didn't catch the make of them.
Gary Lanzer
Team VBC HK
Team R1WURKS
Old 11-14-2011, 02:01 PM   #4547
Yes. It has a very long rotor shaft.
JamesL_71 is offline   Reply With Quote
Old 11-14-2011, 02:29 PM   #4548
ghiro's Avatar
Send a message via Skype™ to ghiro
Any feedback about the Litemods V2 VCS shafts'
Capricorn TE01-Associated RC10R5.1-Atomic VM2-Serpent Cobra811 BE-Honcho-Losi MRC/RcBros-SandScorcher-MERV
DJI' F550-HubsanX4-Toy'sPort Zorro
ghiro is offline   Reply With Quote
Old 11-14-2011, 07:08 PM   #4549
Buckaroo's Avatar
Thanks guys. I'm about to place an order, are the protek 16mm long enough or should I go with the 18mm? The 18mm does not come as a button head, only caphead.
Use the cap head screws, almost no chance of rounding out the socket head, and if you do you can always use vice grips to get the out instead of drilling the head off.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 11-14-2011, 07:11 PM   #4550
cwoods34's Avatar
EPIC pinions. I had already Dremel'd my rotor, but from the looks of it you wouldn't need to with Team Epic pinions. Plus the gold looks cool........
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 11-14-2011, 09:15 PM   #4551
BSchorr's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to BSchorr Send a message via Yahoo to BSchorr Send a message via Skype™ to BSchorr
Originally Posted by Verndog View Post
An optional shorter block that goes from AE 1 to 3 in adjustment....just released.
When would you want a lower or higher roll center when racing on carpet? And when would you know if you needed to adjust the rear or front?
Lower roll center for lower traction tracks? Higher for Higher Traction?
TLR ~ MaClan ~ Hobbywing ~ Futaba ~ Proline ~ Werks Racing ~ Genesis R/C Products ~ Mr. Scrubbles ~ First Premier Satellites
BSchorr is offline   Reply With Quote
Old 11-15-2011, 01:12 PM   #4552
Questions to top pilots....( Rick, Juho, Kevin...)
Can you please explain what ackerman are you using?
Why do you change 7B to 7A for exemple....
And what sterring stroke are you more often using in degrees ? ( 21 , 25)
Thank for your help.
Regards
fredB is offline   Reply With Quote
Old 11-15-2011, 02:13 PM   #4553
BSchorr's Avatar
^^ GOOD QUESTION!
Old 11-15-2011, 02:52 PM   #4554
SkarTisu's Avatar
Send a message via AIM to SkarTisu Send a message via Yahoo to SkarTisu
I haven't had a lot of time with mine yet, but I did discover last weekend that raising the roll center (raising the suspension arm hinge pins) on the front worked very well to cut down on traction rolling on very high bite carpet. A small adjustment (2 dot to 1 dot) made a very noticeable difference.
Marshall Skare
Team Associated - Reedy Powered - JConcepts - LiveRC.com
SkarTisu is offline   Reply With Quote
Old 11-15-2011, 02:59 PM   #4555
Asharus's Avatar
Trader Rating: 42 (100%+)
Most high grip carpet setups use the top hole on the bulkheads, I believe I'm using 0Bs all around except 1B on the front RWD mount.
Angelo Padilla
Team Ballz Racin | PCR Bodies | Island Raceway & Hobby | Gilligan's Raceway
Asharus is offline   Reply With Quote
Old 11-15-2011, 03:40 PM   #4556
SkarTisu's Avatar
That makes sense to me. I'm brand new to the rubber tire touring car game, so the learning curve is pretty steep for me right now.
Marshall Skare
Old 11-15-2011, 04:15 PM   #4557
wtcc's Avatar
Yup! I use them since more than half a year now. Full constant velocity, zero play. I am very satisfied with the quality and performance. Just one thing I don't like: In comparison to the AE axles the material is "softer" and bends or breaks if you get a strong hit on the wheel.
I needed two spare axles, just the part, not the whole CVS, since I installed them in march. Otherwise I am really impressed of the little wear of the cage and balls. Very nice.
All I wrote just counts for 9,5t and 17,5t boosted and unboosted.
wtcc is offline   Reply With Quote
Old 11-15-2011, 08:06 PM   #4558
geeunit1014's Avatar
Regards
Im not quite Keven or Rick, but this is my take on the ackerman for this car.
Moving the bellcrank forward (7c to 7b for example) will make the outside wheel turn more relative to the inside wheel (less ackerman), and have more steering (the tires scrub less). Typically you want to run the bellcrank more forward (less ackerman) for higher grip tracks, and middle/back (more ackerman) for low grip.
I normally set my steering so that the knuckles just touch the c-hub, however much throw that is. Hope that helps.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 11-16-2011, 03:26 AM   #4559
Geberit's Avatar
I think it's in stock!? Does anyone have it already?
http://www.wheelspinmodels.co.uk/i/118063/
Geberit is offline   Reply With Quote
Old 11-16-2011, 07:06 AM   #4560
No. There are no shops which have them in stock yet. You can pre-order them though. I always wait when there is some stock.
株式会社 ヨコモ
dennisV is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 07:34 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28937 01-14-2017 07:26 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 12:42 PM
SEO by vBSEO 3.5.0
