Like Tree1Likes
Old 11-13-2011, 03:12 PM   #4531
Originally Posted by wcalaker View Post
Thanks Olly. i will probably change them around when i install the electrics.
I must say i love how the car feels compared to my TC5. Definitely a lot less slop with the new turnbuckles. Shocks are awesome..not sure how much the Reflex parts helped but they are silky smooth. Cant wait to get it on the track.
I go to a place that has medium bite carpet. I started off with Olly Jefferies' (not sure if you are the same Olly, im assuming)setup on the Assoc website. That looks like it will get me close.
Thx
Drew
Good hope you enjoy your racing, and no, I am not the same Olly, my fingers are a little bit stiffer
Did you drill a 1mm hole in top of shock too? Reflex springs feel really smooth alright, I use Losi pistons in mine.
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 11-13-2011, 05:56 PM   #4532
brian cox's Avatar
Trader Rating: 53 (100%+)
is anyone running gear diffs front and rear in the tc6? if so what weight oils...I run on a medium bite carpet track and was curious what a gear diff up front vs..spool would do---seems like I get a lot of chatter at full lock with the spool, hoping to take some of that away
Team Orion---Bradley Fine Line Design---AKA
brian cox is offline   Reply With Quote
Old 11-13-2011, 06:28 PM   #4533
cwoods34's Avatar
I am. 500k in the front, 80wt AE shock oil rear (or 1000cst)...... As long as you prep the tires right and have a good setup, it makes the car MUCH easier to drive, especially in lower grip conditions.
Very smooth in the sweeper. I even run 6* caster blocks and loads of steering, and the car stays planted.
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 11-13-2011, 08:02 PM   #4534
Trader Rating: 77 (100%+)
Originally Posted by pcar951 View Post
Be sure to blue loctite the threads on the servo saver spring nut or it'll back off. Just happened to me on my blinky car last night...straight into the wall in the sweeper.
So pretty funny. I was reading all these posts about the servo saver. Thought you all were crazy as I have been driving my TC6 for almost a year and never had the issue.
Guess what? Today the nut came off, lost my steering and wham-o hello boards.
Blue loctite the screw.
goin2drt is offline   Reply With Quote
Old 11-13-2011, 08:44 PM   #4535
Default Timezone GP
Update TC6 wins in Mod sedan and 17.5
hickwheeler is offline   Reply With Quote
Old 11-14-2011, 12:43 AM   #4536
cocojam's Avatar
Trader Rating: 47 (100%+)
Hi. Thinking of upgrading from ball to the AE gear diffs once I find it in the online hobbyshops in HK. Is it also advisable to change the stock slipper spool of the TC6 to a gear diff as well? If yes, how will it improve the handling of the TC6? TIA
SJF01 - F103RM - F104Pro - 3rF109 - TB EvoV
Wild Willy 1 - Road Wizard - Can-Am Lola
Dynamic 1500 - Wilga 2000 - Zephyr V70 - FMS FW190 - TWM Skylink
TWM Katana - Zeta Horten BV38 - Freewing Pandora
cocojam is offline   Reply With Quote
Old 11-14-2011, 05:16 AM   #4537
cwoods34's Avatar
SWEET.
I'd be curious to see the 17.5 setup!!!
Old 11-14-2011, 05:21 AM   #4538
And story what was changed due racing event on tc6/modified winner :-)
Tires, setup, changes to made it better.
Regards and good luck!
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 11-14-2011, 07:58 AM   #4539
Asharus's Avatar
Trader Rating: 42 (100%+)
speaking of screws... do you guys use a longer screw for the rear arm mounts on the rear bulkhead? the manual calls for 14mm for all arm mounts, but the rear in particular usually has 4 deg total in spacers and the the screw has less threads screwed into the bulkhead. i'm afraid that it will strip if someone rear ends me hard enough.
Angelo Padilla
Team Ballz Racin | PCR Bodies | Island Raceway & Hobby | Gilligan's Raceway
Asharus is offline   Reply With Quote
Old 11-14-2011, 08:09 AM   #4540
Just use longer ones, they should go little more then bulkhead, I have cut long screws and my go off 1mm.
They are fine when use with hex 2.5mm
Regards!
Michal Abramowicz
Old 11-14-2011, 08:09 AM   #4541
Buckaroo's Avatar
Yes. It's common practice to replace ALL of the mount hanger screws so that they go all the way through the bulkhead. I prefer long enough to have about 1mm of protrusion. Use the ProTek brand of high strength screws from Amain, they're the same as the Associated high quality screws at less than 1/2 the price.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 11-14-2011, 08:24 AM   #4542
Asharus's Avatar
Thanks guys. I'm about to place an order, are the protek 16mm long enough or should I go with the 18mm? The 18mm does not come as a button head, only caphead.
Angelo Padilla
Old 11-14-2011, 10:32 AM   #4543
Asharus's Avatar
Originally Posted by YoDog View Post
5) some motors have an issue where the flat spot on the shaft doesn't extend far enough toward the motor bearing which can cause a poor alignment with the spur gear. D3 motors are like this. You will have to grind, file or machine the flat to about 1mm from the bearing face in order to have enough movement.
Originally Posted by JamesL_71 View Post
Ditto this.
If you are not so inclined to dremel/machine your rotor shaft... The combination of the Xray 64p offset spurs and a pinion with a short body(such as the Robinson and RW 64p pinions) will work as well on the Epic/Trinity motors.
Does the Revtech 17.5 have this same problem?
Angelo Padilla
Old 11-14-2011, 11:20 AM   #4544
mtbboy's Avatar
Absolutely drilled the boards a few times this weekend.
Not sure what people are talking about when they say this car is not durable.?
Handling is disturbingly good ,fast and consistent. .3-.4 variance in several heats.
Where's that gear diff Baby?!
Dave.
Team Associated Reedy factory team driver.
B5M Factory lite $ B44.3 Factory $ TC6.2 $ RC12R 5.1
Reedy 410 Speedos $ Reedy Mach Series motors
204 Raceway Winnipeg 1/10-1/8 Offroad. Owner.
mtbboy is offline   Reply With Quote
Old 11-14-2011, 12:04 PM   #4545
wtcc's Avatar
Heard from an insider that they arrive in Germany this week. So must be in the U.S. sooner or later...
wtcc is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28952 05-01-2017 04:47 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
