Old 11-10-2011, 01:53 PM   #4501
I have a setup/preference question for you guys...
Looking over the AE website, it appears as though ~90% of the published setups are using the "rearward" battery mounting position.
What do you guys prefer? Have you done any back to back testing w/ the battery in the front/rearward positions?
If you can, include what your local track is like... asphalt, carpet, traction level, etc.
JamesL_71 is offline   Reply With Quote
Old 11-10-2011, 02:02 PM   #4502
wtcc's Avatar
I always use the backward position as it is the only way to balance the tireload symmetrical with the motor as second heaviest part so far back in the chassis. I also have the connectors facing towards the front to achieve nice balance. I use this setup for carpet and asphalt.
By the way: I read in a thread about chassis flex and am now wondering if anybody is cutting his topdeck. I heard of someone narrowing his lower deck behind the droop screws. he seems pretty happy with this change...
wtcc is offline   Reply With Quote
Old 11-10-2011, 03:18 PM   #4503
Send a message via AIM to Jonesy112
I havent cut the top deck, but I have cut the rear shock tower in the middle help the rear get a bit more flex. I am quite happy with it for our club racing, as we have little grip down to the track getting changed weekly and oval racing happening 2 days a week. However, when I go to the big races i need to put the standard rear shock tower back on it. It produces too much rear grip and make the car push on a high grip track
Michael Jones
RC America - X-Ray - Team EA Motorsports - RockStar Paint - Apex RC Proshop - ProOne Tires
Jonesy112 is offline   Reply With Quote
Old 11-10-2011, 05:58 PM   #4504
cwoods34's Avatar
I have butchered my chassis and upper deck, and it is dialed on low/medium bite carpet. Ill post pics this weekend when I get a chance.
I always like a rear-weight bias because it seems to keep the back a bit more stuck, which means I can dial more steering in.
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 11-11-2011, 05:18 AM   #4505
I run stock. Have not modified my (carbon) parts yet. I find that the car has more than enough grip on the track where i run.
株式会社 ヨコモ
dennisV is offline   Reply With Quote
Old 11-11-2011, 12:57 PM   #4506
wtcc's Avatar
Thanks guys! I am looking forward on some pictures to see how you tuned your chassis!
Old 11-11-2011, 01:16 PM   #4507
LMRacing's Avatar
Trader Rating: 27 (100%+)
I run the forward position on the battery but I do that because I like having as much weight as forward as possible. We've got some 180* switchbacks at our local carpet track and a 180* turn instead of a sweeper at the end of the straight section at our local Asphault track so I want the back end to rotate as easily as possible
LMRacing is offline   Reply With Quote
Old 11-11-2011, 04:22 PM   #4508
epowr_Racing's Avatar
Default pinion Gear issues
Hi guys maybe someone can help, i just done building my new TC-6 kit,
but im having trouble with the pinion gear /spur ,
im running the Stock 87T spur and a robinson 34T pinion, can't get it to mesh,pionion seems to be way to big to fit , now both are 48 pitch ,what am i doing wrong ? do i need a adjustable motor mont or there's a trick to get it to fit ?
Think, Feel, Operate: Control The Power Of Dreams...
Serpent 966TE,.21 Flash Novarossi, AE TC-6 ,17.5 R Speedpassion, Xray NT1 2011 Spec, .12 Novarossi, Ko Propo radio & Servos
epowr_Racing is offline   Reply With Quote
Old 11-11-2011, 04:49 PM   #4509
you probably need to get the 80t spur gear, 34t is very big, you just cannot fit anysize spur/pinion, you are limited to the space of the motor mount,
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 11-11-2011, 05:22 PM   #4510
Thanks ,
well guess ill just order one , any news on the new diff from Ae anyone knows,
Old 11-12-2011, 12:03 AM   #4511
ScottyTC4NZ's Avatar
Send a message via MSN to ScottyTC4NZ
Default Just Brought New Kit
Hi Guys
Just upgraded from TC4 Factory Team to a TC6
Very Nice kit
Just wondering if anyone else was missing parts when you got yours?
I am missing C-Clip that you use on the servo saver shaft, does anyone know what size it is?
Next Question is does anyone put C.A. Glue around the edges of the Carbon before you use it?
will post some pictures when i finish it.
Jamie Scott
Onroad Race Director
O.R.C.C.C
Titan ARC R10 2013 / Blitz / Sweep / Team Titan
Titan ARC R10 Upgrade / Blitz / Sweep / Team Titan
ScottyTC4NZ is offline   Reply With Quote
Old 11-12-2011, 12:18 AM   #4512
bhambrent's Avatar
Originally Posted by ScottyTC4NZ View Post
Hi Guys
Very Nice kit
Check again I found mine in an there bag. I don't recall which one.
bhambrent is offline   Reply With Quote
Old 11-12-2011, 12:22 AM   #4513
pcar951's Avatar
Trader Rating: 19 (100%+)
yup, it's in there in another bag.
pcar951 is offline   Reply With Quote
Old 11-12-2011, 12:48 AM   #4514
YoDog's Avatar
Trader Rating: 25 (100%+)
I found that it's best to open all the bags and sort out all the parts and hardware because the packaging isn't always intuitive. I found that all the parts are in the kit just not always where you think it should be. The preferred screws for the chassis are actually planned for other locations on the car but they fit better for chassis plate instead.
Read back a bunch of pages and you will see the discussion regarding the great screw debate.
YoDog is offline   Reply With Quote
Old 11-12-2011, 12:53 AM   #4515
Hi Guys
I'm a dumb -ass
Found it hiding inthe chassis bag,
So any tips anyone wants to share
Jamie Scott
O.R.C.C.C
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 07:34 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28937 01-14-2017 07:26 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 12:42 PM
SEO by vBSEO 3.5.0
