Old 11-06-2011, 07:21 AM   #4456
I find some, but as mentioned above, the shaft is not hollow all the way, shame...
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 11-06-2011, 08:38 AM   #4457
Trader Rating: 77 (100%+)
Default Bearings
There was a post a while back to a link for a place to get a bearing set for the TC6 and I think they were pretty inexpensive. Can someone help?
goin2drt is offline   Reply With Quote
Old 11-06-2011, 09:07 AM   #4458
durtbag's Avatar
http://www.avidrc.com/flexkit/?kit=341&kitname=TC6
Just got this kit ...... great value!
AW HELL RICKEY, I WAS HIGH WHEN I SAID THAT!
durtbag is offline   Reply With Quote
Old 11-06-2011, 09:30 AM   #4459
Awesome. Thanks, that is what I was looking for. Just ordered.
Old 11-06-2011, 09:47 AM   #4460
shoe's Avatar
Default Beginner setup ?
Anyone have a beginner setup for outdoor asphalt, 21.5 and 17.5 blinky. Or should I start with the kit setup. I have RSD pistons and springs.Thanks
Mike S
shoe is offline   Reply With Quote
Old 11-06-2011, 10:36 AM   #4461
hnasdad's Avatar
Okay, finally got my TC6 on the track. The out of the box setup was outstanding for a new driver. 17.5 blinky. It was very impressive just how dialed it was. After a few races, I can see making a few adjustment's, but for right now, getting some wheeltime, and cleaning up my lines is all I think I need. Impressive! We had three new drivers in TC6's all who had never driven one before. All left the track saying how nice they were right out of the box.
If you wreck in the same spot twice, your going too fast.
Tell a man his pinion he races today, teach a man about final drive ratio and he will stop making posts about them on forum's
Sketchy Racing (SC10,B44,10L5 Oval,TC6)
hnasdad is offline   Reply With Quote
Old 11-06-2011, 11:43 AM   #4462
Go to the AE site. There will be a few to choose from there.
Old 11-06-2011, 12:35 PM   #4463
whats your track like ? ie is it techical or flowing ?
Ed
Edwin Pibal is offline   Reply With Quote
Old 11-06-2011, 08:29 PM   #4464
YoDog's Avatar
Trader Rating: 25 (100%+)
Originally Posted by olly986 View Post
To me, this is a weak point on our cars, the 2.5mm screws are of poor quality and get loose too easily (destroying you spur gear in the process, happened twice on our two cars) then if you threadlock them, it becomes a pain to remove the two of them at the same time, as you cannot remove one then the other.
Still a very tiny amount of threadlock is my answer to this so far and the change of screws to straight screw driver heads. If you do not use threadlock, check them regularly.
There are socket head cap screws available in 2.5mm and I would suggest replacing the button head screws with these as they use a 2mm hex instead of the stock 1.5mm hex. Mine came loose and even lost one during the RROC. It created a ton of confusion until I found that it was missing the next day. My RCScrewz kit had the cap heads in it from another car and haven't had a problem since, no thread locker needed.
YoDog is offline   Reply With Quote
Old 11-06-2011, 08:40 PM   #4465
YoDog's Avatar
Regarding the ceramic bearings for the TC6, AE recently released a Kit for this car and will be available this month, around the same time as the gear diff and spool. I think it was something like $80 if you want to go that route.
Old 11-07-2011, 02:37 AM   #4466
duggyload's Avatar
Default 6 deg caster blocks
What will the 6 deg caster blocks do for the steering
Can anybody explain this to me in simple terms
Thanks in advance
duggyload is offline   Reply With Quote
Old 11-07-2011, 03:06 AM   #4467
I have seen it advertise for more, like 120$
Old 11-07-2011, 05:37 AM   #4468
wtcc's Avatar
Thanks in advance
You can read about it (and all the other setup stuff) here: http://home.scarlet.be/~be067749/58/c3/index.htm
wtcc is offline   Reply With Quote
Old 11-07-2011, 07:33 AM   #4469
Very good read, what is chapter 1 and 2 about?
Old 11-07-2011, 07:56 AM   #4470
Geberit's Avatar
http://users.telenet.be/elvo/
Geberit is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 07:34 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28937 01-14-2017 07:26 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 12:42 PM
SEO by vBSEO 3.5.0
