Old 11-01-2011, 08:23 AM   #4411
mtbboy's Avatar
Who sells this diff putty and are there different viscosities/densities?
Team Associated Reedy factory team driver.
B5M Factory lite $ B44.3 Factory $ TC6.2 $ RC12R 5.1
Reedy 410 Speedos $ Reedy Mach Series motors
204 Raceway Winnipeg 1/10-1/8 Offroad. Owner.
mtbboy is offline   Reply With Quote
Old 11-01-2011, 09:52 AM   #4412
Rick Hohwart's Avatar
The putty I use is actually made for cleaning nitro cars. I use this:
Xceed Cleaning Gum
There are other companies that make the same product but I don't know if the 'viscosity' is the same.
Rick Hohwart is offline   Reply With Quote
Old 11-01-2011, 06:16 PM   #4413
I am definately a newb with puddin putty (that sounds good doesn't it) in a diff....I'm used to laying the gears in there then putting the oil in the diff. case, revolving the gears to get the oil placed, then adding more... with putty what would be the best way to pack a diff case??
I'm sure my car will handle much better with running a diff in front, with putty, besides running my spool, but I have never tried it..
NPETRO is offline   Reply With Quote
Old 11-01-2011, 06:53 PM   #4414
cwoods34's Avatar
It takes a bit more work than just filling like oil. I stretch it really thin and put pieces on the gears. Don't completely pack it tight right now. Add a dab of oil for lube, and reassemble/close the diff. Now, turn it over in your hand to work some of the putty in.
Open it back up, and add a bit more (small pieces at a time).... also add a dab of oil if needed. When it is nearly full, I like to run the car on the track for 2-3 minutes (not race speeds) to really get the putty worked in. One last time, open it up and "top it off"!
After a few good runs, if you open the diff it'll look like grey-colored slime. Color may vary slightly depending on the specific type of putty.
Hope this helps!!!
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 11-02-2011, 04:26 AM   #4415
Thanks for the tips....I will try this out this upcoming weekend to see how it works out for me.
Old 11-02-2011, 01:23 PM   #4416
Originally Posted by wtcc View Post
This is my standard setup from which I start of at any circuit. I love the car balance in fast curves and the steering when accelerating out of a corner. For this setup make sure to have perfect 25% of weight on every tire (at least perfect symmetrical)!
Ok thanks mate. Going to try this next weekend!
株式会社 ヨコモ
dennisV is offline   Reply With Quote
Old 11-02-2011, 02:56 PM   #4417
Thank you Rick for the Putty information. Easier to find that a 1 Million cst oil!!!!
But I have one question.
How do you fil the diff ?
By checking a level or a weight ? ( xx grams)
Thanks for your help.
Regards
PS: In France the TC6 is the best price/performance balance.
The 417 is sold the double price of a TC6 !!!!!
But we don't have a top pilot able to do serious training and by the way do a A main.
Good luck for the world preparation.
"I have a dream" / "Yes AE can"
fredB is offline   Reply With Quote
Old 11-02-2011, 04:03 PM   #4418
Regards
You want the diff to be completely or nearly completely full. Otherwise the gears will push it out of the say and it won't do much if anything.
Start with the empty case and large bevel gear installed and fill the bottom of the case with putty equal to the top of the bevel gear. Then insert the small gears pushing them in so that they displace as much putty as possible.Then full in all the spaces with more putty and add some oil to coat the surface of the putty.
There should at this point be enough putty so that excess will squeeze out a little when you install the other case half with bevel gear installed. I try to squeeze out as much as possible before separating the halves again. Now the bevel gear will likely be stuck in the putty (which is OK). The oil prevents the putty from sticking and you end up with a makeshift mold. Remove the excess putty (or add more) and joins the case halves again.
You should be able to close the case and you are set. If you need to remove more putty you can.
After using it once, you may need to add more putty due to voids that were not filled during the initial process.
My idea is to use weight as the measurement on a setup sheet. Or at least so that two diffs can be made equal. The putty sticks to itself so you can pretty much remove all of it from a diff and transfer it to another. I did this after messing up an outdrive.
Above is how I fill the AE diff which is very strong. The Spec-R internals are a little more fragile so more care might be required. You are better off filling these a little at a time rather than overfilling them.
I agree the TC6 is a great car. The Worlds will be a great race and we expect a good result as all of our top drivers will be racing.
Old 11-02-2011, 05:13 PM   #4419
Where are you racing Fred?
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 11-02-2011, 09:10 PM   #4420
RAL
RAL's Avatar
Trader Rating: 59 (100%+)
Team Associated has been doing an outstanding job with grassroots marketing and track support with the TC6. The price point is reasonable and has been attracting off-road racers to the on-road tracks/classes. The car has made many good drivers better on a local level and great drivers US National Champions. Kevin H, Bob S, Sean C and Rick H have really been working hard over a period of time to develop the car/setup to be competitive at a world level here in North America. Glad to see it paying off. It really must be rewarding considering the TC6 project is being driven by such a small group of dedicated people. Smart design that allows less spares to be carried in your box and more $ to be carried in your pocket. Great job AE.
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 11-03-2011, 01:23 AM   #4421
S_fender's Avatar
Hi Olly,
Fred is racing near Lyon. We are always together at the french nationals.
Sebastien.
S_fender is offline   Reply With Quote
Old 11-03-2011, 04:15 AM   #4422
The thing I like about the TC6 and Team Associated in general: they don't design new cars every year or so, they just evolve them and make them slightly better every upgrade, thus keeping the costs low for the racers and you can still keep up with your "not so upgraded" car. I'm the kind of guy that likes the way Team Associated works, I run no other brand at the moment. (Ok, I have a X-Factory X6^, but that consists of AE parts too (based on a B4).)
Can't wait to fly with the TC6 next weekend
株式会社 ヨコモ
Old 11-03-2011, 06:22 AM   #4423
Originally Posted by S_fender View Post
Hi Olly,
Sebastien.
Salut Seb
Are you staying with TC6 for next year? Were they any racing in 10.5t? I know you did mod with Patrick (my pal just bought one of his chassis) and Alexandre (I got one of his for my son) I am hoping to run some of the nats rounds next year in 10.5t if we keep that category, we will see what the FVRC will come up with for 2012.
Maybe one day we might see you in Lyon or in Toulouse?
A+
Olivier
Old 11-03-2011, 12:09 PM   #4424
Default AE Gear Diffs
Apparently these parts in in the building. They should be on their way to distributors next week
Old 11-03-2011, 12:22 PM   #4425
I like it, I like it...!!!
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 07:34 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28937 01-14-2017 07:26 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 12:42 PM
SEO by vBSEO 3.5.0
