Like Tree1Likes
Old 10-25-2011, 01:58 PM   #4321
viperbill1963's Avatar
Send a message via Yahoo to viperbill1963
Wink ready to rumble
after about a 10 year absence from on-road im making a comeback so i got a tc6 and is looking for a set up for parking lot racing at my local hobby shop. any set ups is greatly appreciated
team associated RC8.2E tekin esc and motor jr z9100s servo spektrum rx
X-FACTORY X-6 square tekin esc lrp motor spektrum rx soon to be a cube
viperbill1963 is offline   Reply With Quote
Old 10-25-2011, 02:13 PM   #4322
Look at AE web site, lots there to work from
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 10-25-2011, 06:28 PM   #4323
YoDog's Avatar
Trader Rating: 26 (100%+)
Use the stock setup and run the arms as low as possible (low roll center) all the way around. Gearing will be determined by motor and size/layout of the track.
Start to raise the roll center as the grip level increases. this should get you started.
YoDog is offline   Reply With Quote
Old 10-25-2011, 06:51 PM   #4324
Timbulb's Avatar
Maybe I'm wrong but doesn't lowering the arms on the chassis actually raise the roll center?
Timbulb is offline   Reply With Quote
Old 10-25-2011, 07:07 PM   #4325
TV
Lowering the inner hinge pins lowers the roll center.
XRay | RCAmerica | AKA | FX Engines | MotivRC | P1Hobbies.com | Sidewinder | Airtronics | UpGrade RC
TV is offline   Reply With Quote
Old 10-26-2011, 05:15 AM   #4326
cwoods34's Avatar
Lowering the roll center = lowering the arm mounts = increasing the amount of roll (consider it "side bite")
You can take it to extremes, but I liked 0B all around to start with on low-bite asphalt (parking lots specifically). I also only ran about half a mm of droop until traction came up. The car won't "feel" fast but when I ran this I always had traction, which is better than getting loose all the time.
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 10-26-2011, 06:02 AM   #4327
Midnight's Avatar
Trader Rating: 85 (100%+)
Were would u start on a medium carpet track?
RC8T; Losi 2.0B; FT T4; AKA & RB
Hoffman Photography, www.carolinasrc.com
Midnight is offline   Reply With Quote
Old 10-26-2011, 07:30 AM   #4328
racing_jason's Avatar
The kit set up for medium grip carpet is always a good starting point. I also like to just take the arm positions they use for high grip carpet (like the IIC) and lower the arms with the same angles to start with.
Jason
Thank you to my sponsors-
Team Associated-Reedy-ProLine-B&B Hobbies Racing
racing_jason is offline   Reply With Quote
Old 10-26-2011, 07:49 AM   #4329
Super Moderator
Marcos.J's Avatar
Trader Rating: 166 (100%+)
Has anyone had any issues with the spec r gear diffs? The blades on my tc6 fit a littl to tight on the diff outdrives, had to file a little to free them up.
Old 10-26-2011, 09:03 AM   #4330
cwoods34's Avatar
I personally run 0B front/ 1B rear with 14.5/13.5 springs, but I like a lot of steering! 0B all around is also a decent starting spot on carpet - pretty easy to drive and usually makes enough traction. Stick with 4* caster blocks unless you like an aggressive car.
Old 10-26-2011, 09:46 AM   #4331
epowr_Racing's Avatar
Default 48 or 64 pitch
Hi guys Im new to electric just both the TC-6 , due to price and parts , been racing Nitro 1/10 and 1/8th for over 15yrs so i need a few advise as to where to start ,
looking to race 17,5 T stock class for now,
motor from Speed Passion citrix combo , dont know if im in the right direction,
track is asphalt, 124 X 70 , the kit come with a 87T 48 pitch,
just need a starting point .
thanks
Think, Feel, Operate: Control The Power Of Dreams...
Serpent 966TE,.21 Flash Novarossi, AE TC-6 ,17.5 R Speedpassion, Xray NT1 2011 Spec, .12 Novarossi, Ko Propo radio & Servos
epowr_Racing is offline   Reply With Quote
Old 10-26-2011, 09:53 AM   #4332
I had sand the plastic blades down a little bit. I just took some 400grit paper and sanded each side little by little, until they would slide into the outdrives without binding but without slop as well.
Worked fine... and they are holding up fine after two weekends of racing.
JamesL_71 is offline   Reply With Quote
Old 10-26-2011, 09:53 AM   #4333
I need some help with my spool. So I was doing 17.5 and my spool work really good now I'm going to mod and my spool gets lose all the time and I tightened it really good . I even try red threadlock. I can really use some help. thank you
f1o7x9 is offline   Reply With Quote
Old 10-26-2011, 09:54 AM   #4334
thanks
What exactly are you looking for? A starting point in regards to gearing and setup? Or a starting point in regards to what electronics/motor/ESC to buy?
Old 10-26-2011, 09:55 AM   #4335
Are you using the off-road t-nut to secure the thrust bolt?
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28952 05-01-2017 04:47 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
