Like Tree1Likes
Old 10-19-2011, 10:34 PM   #4276
hacker's Avatar
Trader Rating: 140 (100%+)
PS you can use a stanley knife/blade and run it along the inside edge and it will lift off quite easily. But then you need to leave the seals off, as the seal will most likely deform after you have removed it. And it will most likely touch the inner race now, making the bearing worst off then what you started with.
hacker is offline   Reply With Quote
Old 10-19-2011, 10:51 PM   #4277
Odin544's Avatar
Trader Rating: 93 (100%+)
Originally Posted by hanzo3 View Post
How do you get the rubber seal out of some of the smaller bearings without destroying them? They are so thin. Anyone have a link for cheap bearing replacements? Which bearings need cleaning the most?
http://www.avidrc.com/flexkit/?kit=341&kitname=TC6
Odin544 is offline   Reply With Quote
Old 10-20-2011, 04:48 AM   #4278
Default Steering knuckles
Hi,
I've heard that some people have their steering knuckles flipped or reversed?
What are the benefits and do you need to place the ballstuds on top rather the underneath the knuckles?
thx!
zzztech is offline   Reply With Quote
Old 10-20-2011, 05:13 AM   #4279
cwoods34's Avatar
Originally Posted by Odin544 View Post
Avid all the way. You can do the flex kit, or if they are out of a certain type just order plain metal shielded of each size at $1 a piece. Smooth as Paula Dean's butter.
If you flip the steering knuckle, you almost always flip the ballstud also. This is to adjust bump steer! Turn the wheels and compress the suspension, and notice how as the tire rises it may turn back "out" due to the pull on the steering link. Flipping knuckles and/or shimming the ballstud can correct excessive bumpsteer.
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 10-20-2011, 06:55 AM   #4280
Thx! I put the ball stud on top then. Do I still need to put the 1mm blue shim under the stud?
Cheers!
Old 10-20-2011, 07:18 AM   #4281
hacker's Avatar
isn't flipping the uprights for the 6 degree caster blocks only?
Old 10-20-2011, 08:14 AM   #4282
racing_jason's Avatar
They flip the blocks over (the way they were ran on the TC5) when they are running the 6 degree caster blocks and they run the caster blocks the way the kit comes when running 4 degrees or less caster.
Jason
Thank you to my sponsors-
Team Associated-Reedy-ProLine-B&B Hobbies Racing
racing_jason is offline   Reply With Quote
Old 10-20-2011, 09:33 AM   #4283
Send a message via AIM to Jonesy112
Cheers!
Im running mine with the 6 degree castor blocks, black ballstuds with a 1mm blue shim under the ball stud on the steering arm. This seems to be where its happiest in bump steer land
Michael Jones
RC America - X-Ray - Team EA Motorsports - RockStar Paint - Apex RC Proshop - ProOne Tires
Jonesy112 is offline   Reply With Quote
Old 10-20-2011, 03:16 PM   #4284
cwoods34's Avatar
Also consider the front arm mounts. On my mod car I have 3A front/0B back for the front arms with 6* caster blocks. So, due to the angle of the front arms I actually have about 5* caster, which means I might need a different amount of shims compared to flat arms with 6*..... keep that in mind!
Old 10-20-2011, 03:54 PM   #4285
geeunit1014's Avatar
Its for any C-Hub. The car drives much smoother with the knuckles flipped
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 10-21-2011, 12:49 AM   #4286
Trader Rating: 27 (100%+)
Question for for the guys who run their shocks with the 1mm hole in the cap - how do you build your shocks? I'm having a hard time getting the shocks to have the same rebound with the caps drilled. I'm running on a high traction indoor asphalt track (West Coast Raceway) and I'd like to make sure my shocks are performing to their best potential. I know Rick and Steve do very well with their TC6's at WCRC, I'm trying to get my setup that good!
B5 | B5M | TC6.2
Hobbywing | Savox | Airtronics
RC.Jon22 is offline   Reply With Quote
Old 10-21-2011, 01:17 AM   #4287
The Evicerator
I'm pretty sure Rick builds his shocks differently than I do from what I gather from the last time I talked with him about it... but I think his method might be a little easier than mine.
Generally, fill the shock up with oil with the piston fully extended and ensure that there aren't any air bubbles in the shock... a shock pump is very good for ensuring that you've got as much air out of the shock as possible.
Next, take the bladder and place it on top of the shock and gently press it down so that it seats into the shock... usually I make sure that there's enough oil that durring this step extra oil is displaced by the bladder.
Next, take the plastic shock cap and place it ontop of the bladder... be careful because it's pretty easy to move the bladder around by accident.
Next, carefully slide the aluminum cap over the plastic cap and the bladder and slowly screw the cap down until it's tightened completely.
This should be the easiest way to build your shocks with consistant rebound.
I generally build my shocks in a similar fashion except that before I place the bladder on top of the shock I push the shock shaft up into the shock a bit... with the way these shocks are you can't push it up all the way, so I recommend pushing it up so that there's 3 mm between the shock body and the eyelet... the rest of the proceedure is then the same!
Hope this helps!
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- P1 BRAND -- TUNING HAUS -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 10-21-2011, 01:59 AM   #4288
Hope this helps!
Steve, that helps a lot. Thanks for clearing this up for me. Seeing you and Rick dominate the Tuesday night racing has inspired me to practice with my TC6!
B5 | B5M | TC6.2
Old 10-21-2011, 06:01 AM   #4289
Hope this helps!
You can also try pulling the shock shaft out after installing the bladder, this will help seat the bladder.
Josh Hohnstein is offline   Reply With Quote
Old 10-21-2011, 10:50 AM   #4290
What front hexes fit the TC6? Im looking for offset hexes to space the front wheels a bit.... Id prefer not to use the 1mm disc spacers.
I see that some of the factory guys are using what appears to be some sort of black plastic hex on the front. Anyone know what part this is?
JamesL_71 is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28961 07-11-2017 01:29 PM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
