Like Tree1Likes
Old 10-06-2011, 07:42 AM   #4051
Super Moderator
Marcos.J's Avatar
Trader Rating: 150 (100%+)
Originally Posted by Chaz955i View Post
You are welcome I believe when Associated first released the car they marketed the benefit to current TC5 drivers that most if not all of the suspension carried over to the TC6.
Thanks because I have a box full of spares lol
Old 10-06-2011, 10:20 AM   #4052
justchris's Avatar
Hi everyone
Is this the gear diff to get.
http://www.ebay.co.uk/itm/Spec-R-Gea...item3f0ea08f64
Thanks in advance. (was not sure if there was a revised model)
TC6 Savox ] TC6.1 Sanwa ]
XL 5.9 Optifuel] M11X 2.4G ] 6000 IP lipo
justchris is offline   Reply With Quote
Old 10-06-2011, 11:36 AM   #4053
geeunit1014's Avatar
Originally Posted by goin2drt View Post
Can someone explain what the characteristic changes are in a gear diff with regards to different weight oils? What is the difference between "diff" oil vs "shock" oil. I see people using both. Lastly what weight is recommended for high bite indoor asphalt 17.5 NT
"Diff" oil and "Shock" oil are the same in that they are both silicon oil, just shock oil tends to have much lighter weights (Diff oil typically only goes down to 1000cst, shock oils down to 200cst or thinner). I would start with AE 80wt (1000cst), I really liked this on our high bite indoor track.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 10-06-2011, 02:05 PM   #4054
cwoods34's Avatar
Thicker oil in the rear seems to help the car rotate more as traction comes up. I also like 70-80wt shock oil for high grip! For low traction I like to start with 30wt shock oil until bite comes up.
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 10-06-2011, 02:41 PM   #4055
I run mainly 50w on medium grip tarmac outdoor
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 10-06-2011, 03:51 PM   #4056
About oils.
Shock oil is like "slick fluid".
Gear oil is like "glue fluid, it glued or made more sticky fingers" when you
put it on skin.
Anyway, if y are hardcore y can use shock oil in gear diff but it can "quickly" go away ;-)
I just prefer 800cst diff oil (sticky fluid) then 800cst shock.
But all thing depend on what driver need.
Regards!
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 10-06-2011, 04:11 PM   #4057
Trader Rating: 18 (100%+)
ok so i got my gear diff today. gonna be running on an indoor medium bite carpet track. 17.5 blinky, foam tire. should i run in front or run it in the rear? i see people doing either way and just not really sure, i am use to running spool up front and ball in rear.
Air Support for Team CPAURL
Team Powers
CKHobby.com
byohnd is offline   Reply With Quote
Old 10-06-2011, 04:36 PM   #4058
wingracer's Avatar
Trader Rating: 22 (100%+)
I would stick with the ball in rear, gear up front with something really heavy in it like 200k-500k diff fluid or cleaning putty.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 10-06-2011, 04:40 PM   #4059
Buckaroo's Avatar
Just be aware that a gear diff in the rear gives a LOT of rotation compared to a ball diff, even filled with shock oil as light as 15 weight.
On carpet, most other brands that have had gear diffs for a while have already found out that it's too much for most carpet set ups, and run ball diff rear/putty gear front.
Guess the learning curve amongst the Associated crowd isn't going to take known principles and performance trends into account.
....and the geargasms continue!
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 10-06-2011, 05:00 PM   #4060
If your running 15wt shock oil in the diff, thats probably why. Thicker oil is gives a more stable feeling... I absolutely love the gear diff in the rear on carpet for this car. My 416, not so much, but this car makes a LOT of traction and drives very well with a gear diff
Mike Gee
Old 10-06-2011, 05:02 PM   #4061
KHoff7's Avatar
Thats because the 416 not so much anything.
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 10-06-2011, 05:47 PM   #4062
bagged69chevy's Avatar
Trader Rating: 19 (100%+)
I got my gear diff today, and my bone blades are WAY to tight in the outdrives..
should i sand the outdrives or attempt to bend them open a little?
my stock outdrives are measuring .143 and the type r outdrives are .137-.139
and believe it or not, that take the fitment from perfect, to binding up tight..
Nick George
www.localrcracing.com
bagged69chevy is offline   Reply With Quote
Old 10-06-2011, 05:52 PM   #4063
Buckaroo's Avatar
ALWAYS sand/grind the cheapest part. That said, sand the bone blades a little.
I'm anxious to see what the IIC and Snowbirds brings in terms of high traction carpet set ups from the Team. I note that for asphalt in the rear 30wt - 50wt is common, as is eraser putty in the front, putting the TC6 right in line performance and set up wise with all the other TC gear diffs out there.
Tom Keith
Old 10-06-2011, 05:54 PM   #4064
FastPete's Avatar
Trader Rating: 44 (100%+)
Sand the plastic blades takes 2 minutes.
Authorized Dealer for /Agama / Tekno / Team Associated / Schelle / Hobbywing / PT Racing Shock & Diff oil / Serpent / Tekin / JConcepts / AKA / Proline / Savox / M2C / Picco / www.fiercercsolutions.com Like us on facebook www.facebook.com/FierceRCSolutions
FastPete is offline   Reply With Quote
Old 10-06-2011, 06:33 PM   #4065
cwoods34's Avatar
I prefer to not use a ball diff in the rear cuz it slips.......
I've never used "diff" oil (always shock) and never had leak issues.
Perhaps sometimes things are made more complicated then necessary
I also want to see some super high bite setups with gear diffs.
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28947 03-17-2017 11:30 AM
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 06:34 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
