Like Tree1Likes
Old 09-25-2011, 06:30 PM   #3961
Can anyone see any potential problems using the new "xray style" ballcups on my TC5? The original ones are getting sloppy and I really like the captured ball design for ease of adjustability...
anthonyscardina is online now   Reply With Quote
Old 09-26-2011, 12:05 PM   #3962
HB Moose's Avatar
What's the current timeline on the production Team Associated gear diff? A while back they were hoping to have it available next week at the IIC for us privateers.
Bruce "Moose" Riedinger
HB Moose is offline   Reply With Quote
Old 09-26-2011, 01:59 PM   #3963
Buckaroo's Avatar
As long as they fit, don't rub and don't bind, I see no issues.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 09-26-2011, 03:05 PM   #3964
Default oill diff yokomo
Using the TC6 Yokomo diff oil which is recommended to use, I got the 10,000 and 50,000. will be what looks good?
zaranza is offline   Reply With Quote
Old 09-26-2011, 03:54 PM   #3965
hope you intend to fit this diff on front !! for rear it is nearer to AE 50wt
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 09-26-2011, 09:38 PM   #3966
Suspended
Trader Rating: 86 (100%+)
Originally Posted by cwoods34 View Post
I don't have a sheet filled out but here's the gist of it.
FRONT
0b-1b
14.5 Reflex spring/40wt/Reflex piston
Gear diff w/500k
Reflex camber mount - long link, 1mm on each black ballstud
1.5 mm droop, 5mm height, 1* toe out
6* caster, 1.5* camber
REAR
1b-1b
12.5 Reflex spring/40wt/Reflex piston
Gear diff w/AE 60 shock oil
Reflex camber mount - short link, 1mm inside 3 mm outside black ballstud
2mm droop, 5mm height, 3* toe in
2* camber
On Sweep 32s. The other adjustments you can make regarding track size and layout, but that should be a good start. Slipper spool/ball diff also works well enough to start with this setup. I also ran only 4 screws on upper deck - car NEVER got loose.
thanks for the setup, does the rsd camber mount make big difference?
what about ae springs vs rsd springs?
i plan to get gear diff in rear, rsd bladder and pistons, maybe rsd springs
littlealex is offline   Reply With Quote
Old 09-27-2011, 05:26 AM   #3967
Trader Rating: 77 (100%+)
Got tired of waiting. Spec-R now makes one with no modifications. I bought that. We will see how she goes this weekend.
goin2drt is offline   Reply With Quote
Old 09-27-2011, 09:14 AM   #3968
geeunit1014's Avatar
The RSD mount gives you the option to raise or lower the inner link location.. Raising it will give the front a little more roll which is very useful for making the car more stable in higher bite. The RSD short location is also a little longer than the holes on the shock tower, so its an in between option.
The RSD springs have options in between the AE springs, and on carpet I notice they drive more progressively than the AE springs, which drive more directly (responsive). On my car for carpet blinky right now I like RSD 15.5's on the front, and AE silvers on the rear. This combo give a car that is responsive and planted without being tippy. AE springs F/R makes the car more tippy, and RSD springs F/R made the back of the car more vague (ie not as direct, not as hooked up).
This is what ive been running, its been awesome for me
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 09-27-2011, 09:48 AM   #3969
roger999's Avatar
I got my Spec R as well, should have it tomorrow, and now wonder what oil i supposed to use? Shock oil Associated 40 wt will do?
r o g e r g r a f i x . c o m
facebook.com/rogergrafix
roger999 is offline   Reply With Quote
Old 09-27-2011, 10:13 AM   #3970
cwoods34's Avatar
Basically everything he said. The car just feels like a better machine. Takes the TC6 from "not bad" to "top contender"!
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 09-28-2011, 09:11 AM   #3971
I destroyed my TC6 yesterday club racing
Holy cow. Lost control after a long straight coming into the sweeper. Hit the board rear end first. I didn't think I hit that hard but when I started taking it apart I destroyed.
Chassis - rear bulkhead screw ripped right out
Rear bulkhead bent
Hinge pins
Top deck broke in 2
Motor fan destroyed
and various other little parts.
$130 in parts. That blows. Oh well I have certainly crashed plenty and nothing has ever happened. I must have just hit it perfect.
It was sure fun watching Kevin Hebert, Rick H and Bob S. race. Those guys make the TC6 look so sweet.
Old 09-28-2011, 09:15 AM   #3972
Asharus's Avatar
Trader Rating: 42 (100%+)
Ouch! I just got mine and haven't run it yet but I did notice that the rear end is pretty much unprotected.
Angelo Padilla
Team Ballz Racin | PCR Bodies | Island Raceway & Hobby | Gilligan's Raceway
Asharus is offline   Reply With Quote
Old 09-28-2011, 10:46 AM   #3973
Trader Rating: 19 (100%+)
Rear bulkhead bent
Hinge pins
Top deck broke in 2
Motor fan destroyed
Sorry to hear. I have had equal opportunity to demolition my car but it has been a tank.
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 09-28-2011, 12:28 PM   #3974
HB Moose's Avatar
Rear bulkhead bent
Hinge pins
Top deck broke in 2
Motor fan destroyed
Let me guess where.......Hmm, Kevin, Rich and Bob....That makes in in SoCal. Tuesday Night and the track ate your car... That sounds like only one track I know.
Old 09-28-2011, 05:45 PM   #3975
cwoods34's Avatar
Rear bulkhead bent
Hinge pins
Top deck broke in 2
Motor fan destroyed
I literally replaced my top deck, fan, and numerous screws today, too. Got rear-ended entering the sweeper (mod cars).......
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28952 05-01-2017 04:47 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
