Like Tree1Likes
Old 09-24-2011, 10:18 AM   #3946
ghiro's Avatar
Send a message via Skype™ to ghiro
Tired of waiting for the Factory team gear diff i bought a Spec-R diff today.
One question for the "gear diff guys". What kind of oil gives you best results in the rear/front end with mod motors? ( i use a 5.5T)
Anyone can give a feedback on this diff's?
Capricorn TE01-Associated RC10R5.1-Atomic VM2-Serpent Cobra811 BE-Honcho-Losi MRC/RcBros-SandScorcher-MERV
DJI' F550-HubsanX4-Toy'sPort Zorro
ghiro is offline   Reply With Quote
Old 09-24-2011, 10:27 AM   #3947
Trader Rating: 77 (100%+)
Is that new spec-r a direct fit or do you still need to modify things?
goin2drt is offline   Reply With Quote
Old 09-24-2011, 10:33 AM   #3948
ghiro's Avatar
direct fit:
http://www.spec-r.com/default/index....roducts_id=240
Old 09-24-2011, 10:39 AM   #3949
light at rear around 50w and cleaning putty up front or heavy oil
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 09-24-2011, 10:55 AM   #3950
Originally Posted by bunny32 View Post
ok yes i have the manual for the car but i working off one of the setup sheets i have so im setting the car like that and it says for the rear a-arm to use a 2mm on the front and a 3mm shim on the rear a-arm but i was thinking how do they get a 2.5 toe on the rear if there setting r wrong.
olly thanks for u help mate
I am talking about rear setup only:
I have 2x2 on each side of rear arm and 1x1 on front arm, this give me 3 deg, if you want 2.5, use 2x2 a rear and 1x1.5 on front.
is this clearer?
Old 09-24-2011, 11:05 AM   #3951
CristianTabush's Avatar
Originally Posted by JamesL_71 View Post
It makes perfect sense if the AE ball diff is indeed slipping... Is this a known problem/issue? Or is it just a consequence of the design of this type of ball differential(ie: diff with a single adjustment for action and slip)?
Back 10-15 yrs ago, I used to race 1/10th 235mm gas on-road(BMT, Serpent Impact, Picco Integra, etc). The ball diffs we used had adjustments for both the slip and actual differential action. So you could adjust the diff quite loose without inducing any slip. Granted, the diffs were rather large and heavy.... but they were works of art when you assembled and set them correctly.
All ball diffs slip just a bit since what is locking is the balls onto the diff plates. Even if it is for less than a tenth of a second, they will slip as it tries to engage. The design is great for the AE ball diffs. They have always been the best in the market IMO. Gear diffs just work better 99% of the time.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is online now   Reply With Quote
Old 09-24-2011, 12:34 PM   #3952
ghiro's Avatar
Thanks, apreciated.
Old 09-24-2011, 03:09 PM   #3953
Buckaroo's Avatar
Don't be afraid to go super light on the rear oil. 15W is the magic in the Photon, and the Xray guys like it light, too.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 09-24-2011, 03:38 PM   #3954
spring71's Avatar
Smile
New Spec-R TC6 Gear Diffs are in stock.
Click Here to check out
FYI, Thanks.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
http://www.tqrcracing.com
tq@tqrcracing.com
spring71 is offline   Reply With Quote
Old 09-25-2011, 01:46 AM   #3955
is this clearer?
olly thank you for helping me to good mate
bunny32 is offline   Reply With Quote
Old 09-25-2011, 02:21 AM   #3956
Big Features's Avatar
The teeth in the photon gear are smaller then the specR gears. The same oil will have different effects on handling.
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix
Big Features is offline   Reply With Quote
Old 09-25-2011, 04:43 AM   #3957
Buckaroo's Avatar
That would be true for the Upro piece of junk, but most Photon users long ago started running a true Yokomo BD5 gear diff or the SpecR BD5 diff, initially in the front, then later in the rear as well. Same internal gear set and same 40T pulley as this new diff from SpecR, just a slightly modified housing so it's a drop in fit. In fact, it used to be common practice to mod the SpecR BD5 diff for the TC6 by shaving the outer housing where the bearing rides to get a proper fit. With this new diff a drop in, should be no worries.
Therefore it stands to reason that there's no good reason NOT to try going as light in oil as has been successful in other cars out there in anyone's testing. Gear diffs have been around for a long time. Seems like this sudden resurgance is caused more by the availability of good cheap ones than anything else.
Don't get me wrong, I have and run gear diffs, depending on conditions and set up, but a gear diff is NOT a cure-all for everything. It simply has different properties, and requires a different approach to set up and tuning and is not the magic win, front and/or rear. In fact, I have found that my my modified SpecR with white gears runs smoother than my true Yokomo diff, and is more consistent. I prefered running the gear diff outside. Will have to reasses for carpet season.
Now back to your regularly scheduled program: Let the gear-gasms continue!
Tom Keith
Old 09-25-2011, 11:43 AM   #3958
Suspended
Trader Rating: 86 (100%+)
any setup for carpet medium traction for 17.5 blinky?
littlealex is offline   Reply With Quote
Old 09-25-2011, 12:49 PM   #3959
cwoods34's Avatar
I don't have a sheet filled out but here's the gist of it.
FRONT
0b-1b
14.5 Reflex spring/40wt/Reflex piston
Gear diff w/500k
Reflex camber mount - long link, 1mm on each black ballstud
1.5 mm droop, 5mm height, 1* toe out
6* caster, 1.5* camber
REAR
1b-1b
12.5 Reflex spring/40wt/Reflex piston
Gear diff w/AE 60 shock oil
Reflex camber mount - short link, 1mm inside 3 mm outside black ballstud
2mm droop, 5mm height, 3* toe in
2* camber
On Sweep 32s. The other adjustments you can make regarding track size and layout, but that should be a good start. Slipper spool/ball diff also works well enough to start with this setup. I also ran only 4 screws on upper deck - car NEVER got loose.
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 09-25-2011, 04:39 PM   #3960
FastPete's Avatar
Trader Rating: 44 (100%+)
Used the new SpecR TC6 diff today from RSD and doesnt leak one drop! 45W oil.
Alittle light sanding on the back of gears, per the instructions, and RSD orange oring. Butter smooth. Its a great product.
Authorized Dealer for /Agama / Tekno / Team Associated / Schelle / Hobbywing / PT Racing Shock & Diff oil / Serpent / Tekin / JConcepts / AKA / Proline / Savox / M2C / Picco / www.fiercercsolutions.com Like us on facebook www.facebook.com/FierceRCSolutions
FastPete is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28961 07-11-2017 01:29 PM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
