Like Tree1Likes
Old 09-16-2011, 04:41 AM   #3796
AM03GT's Avatar
Originally Posted by bunny32 View Post
so on the steering knuckle where the two holes are a & b hole underneath there is a ballstud is where u do or dont put a washer.
what do u mean adjust the height on the steering link to have zero bumpsteer thanks mate for helping me
Yes under the ballstud on the steering knuckle in either hole A or B is where the washers go...
adjusting the height on the steering link i am also referencing the washers under the ballstud. You are going to want to add/remove the washers in different thicknesses until you have little to zero bumpsteer.
Associated // Reedy // Radiopost // Integy // Parma PSE
AM03GT is offline   Reply With Quote
Old 09-16-2011, 04:55 AM   #3797
Originally Posted by f1o7x9 View Post
Do you guys know if the new kit is going to have other different parts or only the gear diff ?
No new kit, mentionned that actual kit might be sold with diff gear in it only
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 09-16-2011, 04:55 AM   #3798
Big Features's Avatar
Originally Posted by Asharus View Post
Being an onroad noob, I still don't grasp the idea why gear diffs are preferred. As an offroader, I prefer the ball diffs in 2WD applications.
A gear diff will add a lot of steering and free up the car when the bite really comes up. Folks that run Mod like it becuase it not only adds steering, but is less maintenance between runs. It really has its pros and cons.
For me, I race stock. You just cant beat a buttery-smooth ball diff. The ball diffs are a bit lighter too, less rotational mass.
Mike
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix
Big Features is offline   Reply With Quote
Old 09-16-2011, 04:56 AM   #3799
Originally Posted by littlealex View Post
did anyone tried RSD TC6/AE 10mm Machined Delrin Piston (1.0,1.0,1.5mm)?
does it worth $8 for 4 pistons?
They are apparently very good and smooth, other parts from RSD looks good too for TC6, softer bladders is one for zero rebound.
Old 09-16-2011, 05:05 AM   #3800
hacker's Avatar
Trader Rating: 140 (100%+)
who else sells the reflexracing stuff?
also, when does AE's gear diff come out? I don't want to piss fart around with another yokomo diff unless I have to....
hacker is offline   Reply With Quote
Old 09-16-2011, 05:09 AM   #3801
no one has an exact date yet, RSD is sold direct as far as I know, sending stuff anywhere.
Old 09-16-2011, 05:31 AM   #3802
Originally Posted by jorgesimes View Post
Hi John, do you use the 6 caster blocks?
Yeah I am using 6 deg. Also have 10mm ballstud so it was long enough to not rip it out. It's ok when wheels are straight but if they are turned left or right they hit the outside eyelet. Its wearing the edge of eyelet. Not a big drama but thought I had something wrong , since other setups I have seen have same specs but mention nothing about that
JohnJoe is offline   Reply With Quote
Old 09-16-2011, 06:12 AM   #3803
I cut a little bit of plastic, you could do it also, works for me. Not a big drama like you said.
Team AME/ORCA
https://www.facebook.com/strawberryrcdesigns
http://www.strawberryrcdesigns.pt/
jorgesimes is offline   Reply With Quote
Old 09-16-2011, 06:26 AM   #3804
Asharus's Avatar
Trader Rating: 42 (100%+)
Originally Posted by Big Features View Post
A ball diff will add a lot of steering and free up the car when the bite really comes up. Folks that run Mod like it becuase it not only adds steering, but is less maintenance between runs. It really has its pros and cons.
Mike
Thanks for the answer, but did you mean gear diff in your first paragraph?
Angelo Padilla
Team Ballz Racin | PCR Bodies | Island Raceway & Hobby | Gilligan's Raceway
Asharus is offline   Reply With Quote
Old 09-16-2011, 06:39 AM   #3805
Suspended
Originally Posted by Rotax125 View Post
Have you tried the downloads on the AE web site.. Im sure ive seen one for 17.5T.
I have looked at them, will try again to see if maybe I missed one. Did find one for 17.5t on asphalt but not carpet.
tutankhamen is offline   Reply With Quote
Old 09-16-2011, 06:57 AM   #3806
Trader Rating: 77 (100%+)
I am sure Rick H has one and is on this forum often. You could always PM him. He and Steve have been a huge help.
goin2drt is offline   Reply With Quote
Old 09-16-2011, 07:36 AM   #3807
Buckaroo's Avatar
Yes, and yes.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 09-16-2011, 09:03 AM   #3808
turbodog's Avatar
Originally Posted by Buckaroo View Post
Yes, and yes.
While you are at it, get the spring sets and the new shock bladders too! Good stuff!
Troy Schafer
turbodog is offline   Reply With Quote
Old 09-16-2011, 09:06 AM   #3809
Chaz955i's Avatar
+1. High quality products at a very reasonable price.
At The Gate Bizzos
Chaz955i is offline   Reply With Quote
Old 09-16-2011, 09:32 AM   #3810
Rick Hohwart's Avatar
This one is Keven Hebert 17.5 from Cleveland last year:
http://www.teamassociated.com/pdf/ca...hamps_2010.PDF
The Steve Weiss WCRC Club race setup should be pretty good on carpet too. I'll start with my WCRC Club race setup at the IIC carpet race. It should be pretty good.
Rick Hohwart is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28975 10-20-2017 10:40 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
