Old 09-15-2011, 08:10 AM   #3781
Originally Posted by AM03GT View Post
Bumpsteer is the amount your wheels "turn" when the suspension compresses and extends. Take your car at rest with the wheels lined up and slowly push down on the front end. As the suspension compresses observe your wheels and watch them angle in/out while compressing. This is bumpsteer.
black+0 on a setup sheet means the driver is using an associated black ballstud with no washer/spacers beneath it on the steering knuckle.
Usually you want to adjust the height of your steering link to have zero bumpsteer.
so on the steering knuckle where the two holes are a & b hole underneath there is a ballstud is where u do or dont put a washer.
what do u mean adjust the height on the steering link to have zero bumpsteer thanks mate for helping me
bunny32 is offline   Reply With Quote
Old 09-15-2011, 11:31 AM   #3782
Originally Posted by NPETRO View Post
Rumor has is that AE is coming out with a gear diff., any idea as to when it will be released??
Well there is also a gear diff version kit to come out apparently, diff to be release pretty soon now.
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 09-15-2011, 01:04 PM   #3783
i will have to order the gear diff as i have no luck with ball diffs...some of my issues with them are self inflicted as i tend to overpower all of my rc's and drive them accordingly....
beaven is offline   Reply With Quote
Old 09-15-2011, 02:11 PM   #3784
Buckaroo's Avatar
A gear diff is not a "cure all" if your ball diff assembly and tuning skills or maintenance routine are not up to par. They handle differently on the track, and come with their own set of set up issues, tuning options, and maintenance problems.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 09-15-2011, 02:13 PM   #3785
Asharus's Avatar
Trader Rating: 42 (100%+)
Being an onroad noob, I still don't grasp the idea why gear diffs are preferred. As an offroader, I prefer the ball diffs in 2WD applications.
Angelo Padilla
Team Ballz Racin | PCR Bodies | Island Raceway & Hobby | Gilligan's Raceway
Asharus is offline   Reply With Quote
Old 09-15-2011, 03:10 PM   #3786
Default Gear diff release
This is a quote from rick (We are pushing for the IIC/early October.) I found it a couple of pages back hope this helps.
Little John is offline   Reply With Quote
Old 09-15-2011, 03:39 PM   #3787
maybe i should be more specific, i guess the issues i have had with the ball diff in my blitz ese have made me leery of them. i actually have not had any issues with the one in my tc6 and i run a more powerful motor then most because i bash on parking lots.....
Old 09-15-2011, 04:17 PM   #3788
Do you guys know if the new kit is going to have other different parts or only the gear diff ?
f1o7x9 is offline   Reply With Quote
Old 09-15-2011, 06:33 PM   #3789
Odin544's Avatar
Trader Rating: 93 (100%+)
New kit? No new kit has been mentioned other than the fact that one is on the designers desks. Thats not surprising though. They are always working on new designs. When a new model is released they are already looking at what to do next.
I wouldnt expect a new kit for at least another year or more.
Odin544 is offline   Reply With Quote
Old 09-15-2011, 09:16 PM   #3790
Suspended
Default Sorry if it is a repeat
I am sure this has been covered, but I never have luck with the searches. I am looking for a good starting setup for 17.5 NB on carpet. It is a medium grip, new last year CRC carpet. The only carpet setups I am seeming to find is for Mod. Hopefully it will carry over to IIC too.
Thanks for any help in advance.
tutankhamen is offline   Reply With Quote
Old 09-15-2011, 11:17 PM   #3791
Suspended
Trader Rating: 86 (100%+)
did anyone tried RSD TC6/AE 10mm Machined Delrin Piston (1.0,1.0,1.5mm)?
does it worth $8 for 4 pistons?
littlealex is offline   Reply With Quote
Old 09-16-2011, 12:56 AM   #3792
Trader Rating: 23 (100%+)
Have you tried the downloads on the AE web site.. Im sure ive seen one for 17.5T.
ox
Rotax125 is offline   Reply With Quote
Old 09-16-2011, 05:11 AM   #3793
Anyone have any trouble with the turnbuckle eyelet on the front camber link rubbing on rim if using more than 1mm shim with long ballstud? Noticed on some setup they run 2mm with long ballstud on the caster block but i tried it and the rim hits the eyelet when turned. Is there a way to fix this?
JohnJoe is offline   Reply With Quote
Old 09-16-2011, 05:23 AM   #3794
Hi John, do you use the 6 caster blocks?
Team AME/ORCA
https://www.facebook.com/strawberryrcdesigns
http://www.strawberryrcdesigns.pt/
jorgesimes is offline   Reply With Quote
Old 09-16-2011, 05:26 AM   #3795
sandsurfer's Avatar
Trader Rating: 20 (100%+)
Send a message via Skype™ to sandsurfer
I'm running 2mm on outer ball and have not noticed eyelet rubbing on the wheel. I will double check to see if i'm using a long ballstud when I get home. Though, I do believe it is really close. Maybe your ballstud pulled out a little. I know I did have to get the 10mm thread length ballstud because when I initially used 2mm washer I had the stock ballstud pull out of the caster block.
sandsurfer is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 07:34 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28937 01-14-2017 07:26 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 12:42 PM
SEO by vBSEO 3.5.0
