Team Associated TC6 Thread
#3631
#3633
look at the hobbywing thread, lots there and also the HW web site.
#3634
this chart makes it out to be 3200kv
http://www.hobbypartz.com/07e-c-xerun-120a-sd.html
I ask this because I have a 3800kv in my SC10 4X4
and
I have a 2200kv in my 1/8 scale Truggy.
My 2200KV is a lot more powerful. Wouldn't 1350kv be a lil beastly for this lil ole TC6? But, I have a feeling that Turn and KV are a lil more complicated than what I am making it out to be. Go ahead boys, chop and dice the Nitro Guy/Electric NEWB
#3636
Quick question, sorry if it has been covered. I searched through the thread but couldn't find for sure confirmation.
Does the TC6 come with the "hard" suspension parts? I am going to place an order for some spares...
Also, do most non-timing 17.5 guys run 64p or 48p gears? This is specifically for outdoor/asphalt if it makes a difference.
#3637
Not sure on the pitch.
#3638
Curious how did you calculate 1350kv is approximate 10.5 turn?
and
and
#3639
Thanks bvoltz, I see you are from Elgin, Il. I was born near there, Oaklawn, Il. I will place those items in the shopping cart. I asked the local fast guy what his setup is, he said the stock set-up. I kinda don't believe him though . The track we run at don't really care whats under the hood, so a TC6 would be ran under like "1/10 sedan" I assume. Its pretty much "outlaw" class. Local fast guy suggested a 10.5 turn motor. I really want to get a Castle ESC and Motor but I don't know what the equivalent KV measured motor would be. Can you suggest something close to 10.5 turn. Thanks
#3640
64 or 48 depends on the quality of the surface. 48 for parking lot, 64 for purpose built small grain asphalt. Start around 4.0 FDR, check temps, get a fan.
#3641
You can set the gap with a piece of paper, it will create the proper gear mesh....
#3642
http://www.teamassociated.com/news/l..._TC6_Screw_Set
New aluminum screw set for the tc6 just released
#3643
and
and
http://www.rctech.net/forum/electric...onversion.html
#3645
hi
hi guys can someone help me my tc6 when i turn right it spins out but when i turn left it turns normal can someone help me thanks
