Like Tree1Likes
Old 08-24-2011, 07:54 PM   #3586
bvoltz's Avatar
Trader Rating: 44 (100%+)
Does anyone have a chart showing the range of pinions that will fit with XX Spur?
or what combination are people running with 48P to get 3.5 to 4.0 FDR?
bvoltz is offline   Reply With Quote
Old 08-25-2011, 12:04 PM   #3587
cwoods34's Avatar
This was linked to me a number of pages ago!
http://abram.eu.org/gear_tc6.php
Should help
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 08-25-2011, 04:22 PM   #3588
Verndog's Avatar
Trader Rating: 16 (100%+)
Here you go.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 08-25-2011, 07:52 PM   #3589
48p 29t pinion and 87t spur won't fit, but someone needs to determine the highest and lowest total tooth count for this car , in both 48p and 64p, to have a clue which spur/pinion combo will fit !!!!!!
bertrandsv87 is offline   Reply With Quote
Old 08-25-2011, 09:20 PM   #3590
bvoltz's Avatar
I currently have the 80 (48P) and I'm able to put on a 22 to a 35 (not 36, not enough gap), so you will need to subtract 1 from the upper limit on the 48P, i do not have 64P to test...
Hope that helps....
Also when you get up to the larger pins you will need to move the the bottom mount slot on and forget about the back mounting slot, on the motor mount. But this should not be a problem... 2 screws seems to work just fine.
Old 08-25-2011, 09:31 PM   #3591
bvoltz's Avatar
I think you will find that the 28T will work with the 87T spur.... I agree the 29T will not work, I think it is off by one on the high side....
Old 08-26-2011, 12:54 AM   #3592
Smile
According to the chart, the lowest total tooth count seems to be 92t in 48p . So the high is 115t, and the low is 92t ! So with a Robinson 49t spur and 47t pinion you get 2.08fdr !!!!Too low for 17.5 ! The best 48p spur for 17.5t/21.5t/ 25.5t would be Robinson 60t with a gearing range of 32t pinion(3.75fdr) to 47t pinion (2.55fdr) .....
Old 08-26-2011, 01:00 AM   #3593
If you only run 13.5 and 17.5 , then you're better off with a 48p 66t spur with a gearing range of 2.80fdr(47t pinion) to 5.07fdr(26t pinion).........
Old 08-26-2011, 06:50 AM   #3594
bvoltz's Avatar
But what is the biggest pinion you can run with out hitting the top deck? I currently have a 69 spur, but getting pinions over 37T is currently troubling as they are on back order. I also need to look at the clearance to see if a 41T will fit.... But I do not have one...
It would be nice if the motor mount had more movement for the motor, mainly back, but I see you will need to take some off the top deck on the outside to slide the motor back...
Old 08-26-2011, 08:02 AM   #3595
blanks596's Avatar
Trader Rating: 14 (100%+)
can anyone tell me the part number of the short rear tie rod camber links-trying this because my car does not want to rotate
Serpent/Desoto Racing
Max S
blanks596 is offline   Reply With Quote
Old 08-26-2011, 08:28 AM   #3596
Team AME/ORCA
https://www.facebook.com/strawberryrcdesigns
http://www.strawberryrcdesigns.pt/
jorgesimes is offline   Reply With Quote
Old 08-26-2011, 10:31 AM   #3597
one question to ask is what is the biggest pinion you have ever bought?
I cannot see very large ones anywhere on the net.
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 08-26-2011, 11:20 AM   #3598
Again, sorry guys , you need to change the spur for each class 17.5t (69t) , 13.5t (72t+), according to the gear chart . Robinson racing website has the new 48p(41t/43t/47t) gears ! About them fitting, that's another issue .......
Old 08-26-2011, 11:31 AM   #3599
If you want high gearing, the top deck part that gets in the way of the spur and pinion gear needs to be completely dremeled out !!!!! How that will affect the car, I don't know ......good luck.....
Old 08-26-2011, 11:46 AM   #3600
bvoltz's Avatar
PRS has a 37T, but Epic has 38T, 39T and 40T. http://www.amainhobbies.com/product_...inion-Gear-40T
Robinson has even bigger pinions available, but they do not offer a 40T which is 3.5 FDR with a 70T spur and 35T which gets you to a 4.0 FDR (which I have that pinion). Robinson offers a 39T and 41T pinion but not a 40T. Interesting....
Robinson offers a 70T Spur : http://www.amainhobbies.com/product_...-Spur-Gear-70T
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28970 09-28-2017 07:28 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
