Like Tree1Likes
Old 08-03-2011, 10:35 AM   #3406
Originally Posted by olly986 View Post
You must have, kit spur is 87t
Here is my Sakura diff conversion, working fine, no leakage, no hacking or sanding either.
You can see in red the heatshrink to protect outdrives instead of blades.
Can you still use the stock blades????
Little John is offline   Reply With Quote
Old 08-03-2011, 11:07 AM   #3407
no otherwise I would use them,I am trying Xray NT1 outdrives soon to see if TC6 blades fits, this is why I am using heatshrink, to minimise wear.
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 08-03-2011, 11:41 AM   #3408
Can a little bit of dremeling fix it???
Old 08-03-2011, 12:30 PM   #3409
The idea was NOT removing and weakening part, we ran without blades before you know.
But I have a couple of outdrives on the way and I might give it a go to fit blades instead and see if it keeps it's strengh. it does not need much to remove.
Old 08-03-2011, 12:43 PM   #3410
cwoods34's Avatar
Recently converted from XRAY
Just built one new from box, and it went together WAAAY better than I expected. Not new to TC, and the car seems plenty capable. I'll have Associated gear diffs in them soon.
What is the largest 64-pitch spur gear you can fit on a TC6? I'll be running mod occasionally.
Thanks!!!
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 08-03-2011, 12:53 PM   #3411
Thanks!!!
Ive used up to a 115t hope this helps.
Old 08-03-2011, 01:04 PM   #3412
wtcc's Avatar
Thanks!!!
Maybe this one from our friend Michael helps: http://abram.eu.org/gear_tc6.php
wtcc is offline   Reply With Quote
Old 08-03-2011, 01:27 PM   #3413
Buckaroo's Avatar
Originally Posted by littlealex View Post
i m new to tc6. how do you tie the battery on chassis?
The velcro battery strap from the TOP Photon (available from Amain, among others) works perfectly!
ETS: Dang cut n' paste, pulled the wrong quote! Thanks, Verndog!!
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 08-03-2011, 02:05 PM   #3414
Verndog's Avatar
Trader Rating: 16 (100%+)
i go back from this page to 189 and only found 63.7mm shock length suggested by keven
anyone else have good tip for shock build?
Cool...the old velcro battery strap shock rebuilding trick.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 08-03-2011, 02:18 PM   #3415
cwoods34's Avatar
Nice chart! Weird that I can get taller ratios with 48-pitch but if it works, it works! Thanks!
Old 08-03-2011, 02:37 PM   #3416
Rick Hohwart's Avatar
New TC6 setups posted.
Rick Hohwart TC6 13.5
Rick Hohwart TC6 Modified
I'll post Jeff Cuff's 17.5 setup shortly.
Rick Hohwart is offline   Reply With Quote
Old 08-03-2011, 02:40 PM   #3417
RC-ProSpeed's Avatar
Originally Posted by Little John View Post
Wow a 66!!! ive never used anything smaller then an 88!!
The smallest I know it fits and will give you a good range of option for a low FDR # are in 64P-85T & in 48P-66T
Someone ask about the larger spur that will fit on the TC6, the 64P-120T will fit with no problem; not sure what will be the max on 48P
RCRNV (www.rcrnv.com) / *Keep On-Road alive!*
- Nitro Touring - Kyosho EVO 2 WC
- Electric - TC6 (Out of the Box! No upgrades needed)
- F1 - F103RM (Out of the Box! No upgrades needed)
RC-ProSpeed is offline   Reply With Quote
Old 08-03-2011, 02:53 PM   #3418
Just bustin on you bud
J. Barton
Associated B5M
Associated RC8B3E
smokefan is offline   Reply With Quote
Old 08-03-2011, 02:54 PM   #3419
cwoods34's Avatar
It may happen to you soon, too........
Old 08-03-2011, 02:57 PM   #3420
The thought crossed my mind. But you know me I'll have to wait a couple yrs when they come out with the TC8 then I'll get a Tc6
J. Barton
Associated B5M
Associated RC8B3E
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28961 07-11-2017 01:29 PM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
