Like Tree1Likes
Old 08-01-2011, 09:01 PM   #3391
big al's Avatar
Originally Posted by YoDog View Post
Is it that the rims are too wide or the offset is wrong for the car? If it's the offset, you can use wheel spacers or find hex adapters that have additional offset.
You have to be careful with those spacers. They will numb the front end if too many are used. Never more than 1mm total has been my experience.
big al is offline   Reply With Quote
Old 08-02-2011, 12:20 AM   #3392
wtcc's Avatar
Originally Posted by trytowin View Post
I run a TC6 in Vintage Trans Am but, I am suffering from a lack of steering, full left to full right. With the wider wheels/tires required for VTA, the inside of the front wheels will rub where the shock mounts to the A-arm. Need to move the shocks to the inside mount (on the A-arm). Wondering how this will affect handling, and what can be done to compensate? Thanks for any info.
It will affect the wheel rate. In overall it will soften the damping in front. Means it will feel as if you are using a slightly softer spring in front which should give a little more grip feel. Second thing is that the amount of suspension travel changes. Third the shock now has a more upright position which in comparison to a more inclined shock means that it is less progressive. Additionally the shaft speed will vary less with suspension travel. This will feel as if you use a shockpiston with slightly smaller holes.
I am using the inner mount too to have more amount of negative suspension travel and it works very well for me --> increased steering.
wtcc is offline   Reply With Quote
Old 08-02-2011, 01:55 PM   #3393
Suspended
Trader Rating: 86 (100%+)
i m new to tc6. how do you tie the battery on chassis? also how do you guys build shocks such as shock length, rebound.
littlealex is offline   Reply With Quote
Old 08-02-2011, 02:01 PM   #3394
wtcc's Avatar
Battery: the stock brace + tape works very well. Some guys here use velcro.
Shocks: Rebound like it is mentioned in the setup sheets. The shock length was mentioned some pages ago and some 20-30 pages ago... just can't remember. Maybe you will find faster.
Old 08-02-2011, 05:08 PM   #3395
Suspended
i go back from this page to 189 and only found 63.7mm shock length suggested by keven
anyone else have good tip for shock build?
Old 08-02-2011, 05:44 PM   #3396
big al's Avatar
Gentlemen, what is the smallest spur you have used on your tc6? I currently have a 66t and I am looking into my options.
Old 08-02-2011, 07:06 PM   #3397
trytowin's Avatar
69t is the smallest I've used (48 pitch, right?)
I'm just here to discharge my battery.
trytowin is offline   Reply With Quote
Old 08-02-2011, 07:09 PM   #3398
trytowin's Avatar
Thanks for the info reguarding moving front shocks to the inner place on the A-arms. Follow up question: Should I move the upper mount also? Currently it is at the stock setting, from the instruction manual. Thanks again.
Old 08-02-2011, 07:38 PM   #3399
Wow a 66!!! ive never used anything smaller then an 88!!
Little John is offline   Reply With Quote
Old 08-02-2011, 11:59 PM   #3400
wtcc's Avatar
Moving the upper mount has a less influence. Here it comes to what kind of setup you like. Having the front shocks upright and rear shocks inclined makes your car more responsive and agile in front while the rear will follow good. Having the front shocks inclined and the rear ones upright will give you understeer.
That is the theory, in the end you have to test it on track.
Got a 72t spur for 17,5t blinky installed and thought it is way small...
Old 08-03-2011, 05:24 AM   #3401
Any news on an Associated gear diff??..is it in the works or??
XPRESS| SMOKEM | MUCHMORE
Lionel S is offline   Reply With Quote
Old 08-03-2011, 05:43 AM   #3402
xtrememadness's Avatar
Send a message via AIM to xtrememadness
I spoke to keven hebert at the nats last weekend! He was running them in his car as was rick howart! They said the diff will be for sale in about a month!
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 08-03-2011, 05:47 AM   #3403
... Finally!!
Old 08-03-2011, 05:58 AM   #3404
You must have, kit spur is 87t
Here is my Sakura diff conversion, working fine, no leakage, no hacking or sanding either.
Uploaded with ImageShack.us
You can see in red the heatshrink to protect outdrives instead of blades.
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 08-03-2011, 10:22 AM   #3405
roger999's Avatar
yeah racing make velcro tape for tc6. you can buy it on rcmart
facebook.com/rogergrafix
roger999 is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28964 09-01-2017 06:44 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
