Like Tree1Likes
Old 08-01-2011, 04:52 AM   #3376
roger999's Avatar
Originally Posted by Chaz955i View Post
Double check that you have it set correctly. Using the kit set-up my belts weren't close to being too tight.
hm i have checked it few times and looks like is ok... But for me is tight. I mean have no experience with electric in nitro is simpler that's why asking... How to check it?
facebook.com/rogergrafix
roger999 is offline   Reply With Quote
Old 08-01-2011, 04:58 AM   #3377
not much difference from a nitro to electric belt, the idea (like the diff really) is to reach that point where the belt is loose enough without jumping or turning.
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 08-01-2011, 06:24 AM   #3378
Rick Hohwart's Avatar
I usually don't have problems with chassis tweak. To check tweak it must be done on blocks placed on a perfectly flat and clean surface. The blocks must be placed where there are no screw heads as well. Always check with no motor or battery installed. Playing with the order in which the screws are tightened can help. Also make sure the servo is flush with or slightly above the chassis.
Originally Posted by StickyFingaz View Post
Would putting a thicker oil in my gear diff help with my car's high speed push? Currently have AE 40wt in my car, as per Hebert's and Hohwart's suggestion at the Reedy.
Thicker oil will give more on power steering. At least this is what I have found typically my setups understeer according to other team drivers that try them.
Rick Hohwart is offline   Reply With Quote
Old 08-01-2011, 06:44 AM   #3379
Redwood's Avatar
Does anyone know the exact height difference between a black ballstud and a silver ballstud? The reason I ask is because some setups ask for a silver in front for the outer camber link but the silver is too long and rubs on the driveshaft.
I assume it is less than 0.5mm or I can't think why people don't use a black with a shim.
Thanks,
Neal
Redwood is offline   Reply With Quote
Old 08-01-2011, 07:04 AM   #3380
roger999's Avatar
Originally Posted by olly986 View Post
When you pull the long one out in the middle section it should move 5mm up, for the rear push in between the gears it should go down 2/3mm.
Thanks, long one moves 5 mm now and is on manual settings, rear moves 2.5 mm and had to loose it one teeth.
Old 08-01-2011, 07:45 AM   #3381
artwork's Avatar
Trader Rating: 56 (100%+)
Nice work this past weekend at Paved Nats...looks like your cars were working really well!
I would love to see the final setups you guys were running!
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 08-01-2011, 07:53 AM   #3382
JRXS_chris's Avatar
Thanks,
Neal
0.75mm I think. The main difference is the length of the thread however. The silver one has a longer thread.
JRXS_chris is offline   Reply With Quote
Old 08-01-2011, 07:56 AM   #3383
Buckaroo's Avatar
Not certain of the exact measurement, but a black ballstud with a 1mm shim is about the same, so that seems correct.
Both "silver"(tall) and "black"(short) ball studs are available in a variety of thread lengths.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 08-01-2011, 08:56 AM   #3384
Redwood's Avatar
Cheers guys, i will try a black ballstud with a 1mm shim since I have no short silvers, and I dont want to dremel them all down.
Thanks,
Neal
Old 08-01-2011, 10:45 AM   #3385
Thanks! The cars were very good in all three classes. The plan is to have setups for the winning 17.5 and 13.5 cars and my mod car by tomorrow afternoon.
Old 08-01-2011, 01:56 PM   #3386
Hello Rick
Are you not running 10.5t class in US at all?
Old 08-01-2011, 02:08 PM   #3387
artwork's Avatar
Hello Rick
Olly-
10.5 motors were moved under modified a few years back here in the US. Not very many people run it these days, mostly 13.5 and 17.5 motors outside of Modified.
Old 08-01-2011, 02:33 PM   #3388
ok thanks, I see there is also some movement on the 13.5t here in Europe, but nothing in 17.5t, here our std class is still 10.5t for the moment.
As a matter, do you see much difference between the 10.5t and 13.5t with variable timing, or are you using blinky only in 13.5t and 17.5t?
Old 08-01-2011, 08:16 PM   #3389
trytowin's Avatar
I run a TC6 in Vintage Trans Am but, I am suffering from a lack of steering, full left to full right. With the wider wheels/tires required for VTA, the inside of the front wheels will rub where the shock mounts to the A-arm. Need to move the shocks to the inside mount (on the A-arm). Wondering how this will affect handling, and what can be done to compensate? Thanks for any info.
I'm just here to discharge my battery.
trytowin is offline   Reply With Quote
Old 08-01-2011, 08:38 PM   #3390
YoDog's Avatar
Trader Rating: 26 (100%+)
Is it that the rims are too wide or the offset is wrong for the car? If it's the offset, you can use wheel spacers or find hex adapters that have additional offset.
YoDog is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28952 05-01-2017 04:47 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
