Old 07-27-2011, 10:53 PM   #3331
mkennedy's Avatar
Trader Rating: 26 (100%+)
Send a message via Yahoo to mkennedy
unscrew the shock ends to get the droop
Mike Kennedy
AKA - Airtronics - F1RCLab - Thunder Power - JGO Paintz - Dialed Inc. - CompetitionX.com
mkennedy is offline   Reply With Quote
Old 07-28-2011, 03:18 AM   #3332
Originally Posted by nicorozog View Post
Also i have a few questions:
1. Has anyone tried the Diff T-Nut - Minilocknut, with the diff thrust bolt, of the AE B4 Buggy?. Ive Heard that it would be a good option when you damage the stock Mini-Locknut trying thighten the screw for the spool....
2. Which are the "ball ends" that i should use to get 5mm of rear droop?
Thanks a lot from Bogota!
1. It's a direct fit and it's resistent.
2. The stock ones should be ok. Use 63,7 mm of shock lenght as Keven Hebert said.
Hope this help.
Team AME/ORCA
https://www.facebook.com/strawberryrcdesigns
http://www.strawberryrcdesigns.pt/
jorgesimes is offline   Reply With Quote
Old 07-28-2011, 10:10 AM   #3333
roger999's Avatar
Guys, how often should lube ball diff? after few runs diff pulley is worn out!!!
r o g e r g r a f i x . c o m
facebook.com/rogergrafix
roger999 is offline   Reply With Quote
Old 07-28-2011, 10:21 AM   #3334
After every cleaning of diff, you can feel the "grit" when you turn it by hand, I clean it after every day of full race competition.
If your diff pulley is damaged after a few runs, check that you are not getting small stones in it (on dirty track or car parks it is the worst)
Make sure that the belt seats flat and you have both side of diff excentrics on same groove.
That your belt is not too tight also.
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 07-28-2011, 10:48 AM   #3335
roger999's Avatar
Thats probably it, i think the track was too dirty to race on that for two practice days. My fault. Thanks!
Old 07-28-2011, 11:24 AM   #3336
We get a lot of "burned" rubber and oil left on track by IC cars also, it gets into the diff gear/belt grooves and upset your belt by becoming tighter, you need to remove the deposit with a small pointy knife. this you should check too.
Old 07-28-2011, 12:37 PM   #3337
roger999's Avatar
yes that i know, but pulley was damaged inside where the balls are... Looks like balls made holes bigger and with worn plastic... Hope you understand it hard to explain and have no macro in my phone to make some pics.
Old 07-28-2011, 01:42 PM   #3338
Hi roger,
Well to get your diff that damaged, it has to be extremely dirty or just too loose, which is the probable reason.
When you hold one wheel and the spur gear (not diff gear it too awkward to reach) together with one hand, try to turn the other wheel, if it turns, you need to tighten your diff until the wheel does not turn anymore (not too much either or you will flatten the balls on pads or groove the pads too much) in general the manual setup is good with new balls and pads, run a few times and recheck the diff. all settings are small increments at the time, not full turns
It is important to get the diff right, especially with spool on front.
Old 07-28-2011, 10:43 PM   #3339
roger999's Avatar
yeah there is to 1/8 turn out. Try to do like is in manual. B4 was probably more... But inside was enough lube after runs... So i don't think so it was too loose. Have no experience with that so next time try to do it like in manual.
Old 07-29-2011, 03:18 AM   #3340
Make sure you reach the point as explain above where your diff does not slip but it is not overtight either and you will be fine, the diff has heated up and the balls melted the plastic more than likely.
Old 07-29-2011, 06:18 AM   #3341
roger999's Avatar
yeah but the question is: how can i find that point?
Old 07-29-2011, 06:45 AM   #3342
Stick 2 hex drivers in the outdrives to stop them rotating and try to rotate the diff pulley with your other hand. If you can move the pulley the diff is too loose.
You'll also hear if it's too loose on the track. Stand near the car and launch with full throttle. If the diff is too loose the car will make a slight noise as the rear diff slips. It's hard to describe the noise. It's not the same noise as a pinion/spur slipping but it definitely sounds like something slipping in the drive train.
spongerX is offline   Reply With Quote
Old 07-29-2011, 07:57 AM   #3343
roger999's Avatar
so that spool should be impossible to move by hand or just very hard to do it? Because on the manual is after tight it full, turn it back 1/8 of turn...?
Old 07-29-2011, 09:03 AM   #3344
Donn's Avatar
I have used the off road t-nut in mine since I built it, and works great. Part number 6575, gets you the t-nut, cover and diff bolt.
Donn is offline   Reply With Quote
Old 07-29-2011, 09:56 AM   #3345
Chaz955i's Avatar
Correct, the slipper spool should be really tough to turn, it really isn't designed to move except for hitting something where there is some give as compared to a traditional spool. I tigtened the bolt until the spring bottomed out and left it. It was easy to feel when the tension ramped up.
The rear diff I built to Associated's instructions. Seemed tight to me but just backing off the tension a hair resulted in slip. There seems to be a very fine range of adjustment vs. the diffs in the Corally Phi which I ran previouly. So far still running on the initial build and the diff is like butter. I run indoor carpet so I'm not dealing with the amount of debris the outdoor people have to deal with.
Also, I've had no issue with the stock t-nut. I just made sure the lock nut was all the way into the well before I tried to thread in the diff bolt.
Good luck. The TC6 is a great car.
At The Gate Bizzos
Chaz955i is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 07:34 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28937 01-14-2017 07:26 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 12:42 PM
SEO by vBSEO 3.5.0
