Like Tree1Likes
Old 07-25-2011, 08:08 AM   #3316
artwork's Avatar
Trader Rating: 59 (100%+)
Originally Posted by littlealex View Post
can anyone tell me when should i use hard arms and when to use regular arms?
i drive on outdoor asphalt 10.5t motor
Usually when the grip is really high some team drivers use the hard parts. The regular parts tend to flex more which can provide more grip. Sometimes when the weather is really hot hard plastics can be a good choice as they will not be affected by the heat as the regular parts. I almost always run the regular parts, but have tried hard parts and cannot feel too much of a difference.
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 07-25-2011, 10:04 AM   #3317
midse's Avatar
Default asc31550
Hi guys - I just built a tc6 but don't know what the four blue alloy m3 locknuts are used for - p/n asc 31550 - anyone know what they are for??
midse is offline   Reply With Quote
Old 07-25-2011, 10:07 AM   #3318
tr1kstanc3's Avatar
Trader Rating: 18 (100%+)
You can use them to mount the camber links directly to the shocktowers themselves instead of the bearing caps.
tr1kstanc3 is offline   Reply With Quote
Old 07-25-2011, 10:23 AM   #3319
midse's Avatar
Sorry i don't understand how - can someone post pics?
Old 07-25-2011, 10:29 AM   #3320
midse's Avatar
Cancel that - I got it now - Instructions could be better - Haven't built a kit for about 20 years
Old 07-25-2011, 10:32 AM   #3321
bvoltz's Avatar
Trader Rating: 44 (100%+)
You have 6 holes just to the outside of the bulkheads, if you mount here, you want to use the locking nuts, but in the kit, are camber links that are to long for this, would need to purchase the shorter camber links. Hope this helps...
bvoltz is offline   Reply With Quote
Old 07-25-2011, 05:39 PM   #3322
sandsurfer's Avatar
Trader Rating: 20 (100%+)
Send a message via Skype™ to sandsurfer
+1 on better instructions. SC10 2wd, SC10 4wd good, TC6 not so good.
sandsurfer is offline   Reply With Quote
Old 07-27-2011, 11:32 AM   #3323
Suspended
Trader Rating: 86 (100%+)
how do you guys mod the yokomo spec r gear diff to fit our car?
littlealex is offline   Reply With Quote
Old 07-27-2011, 12:04 PM   #3324
geeunit1014's Avatar
You need to dremel one side of the case so the bearing sits further in, and you need to dremel the dogbones so they fit in the outdrives.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 07-27-2011, 12:41 PM   #3325
twk-b's Avatar
Send a message via MSN to twk-b
anyone have details for where they strapped down the various tc6 ballist kit? I just picked mine up from the hobby shop and havent taken a good look at it yet but was wondering if someone had the break down of what they put where to get it balanced...
ty
-b
twk-b is offline   Reply With Quote
Old 07-27-2011, 12:45 PM   #3326
ty
-b
It will depends on your equipment, but generaly behind or on front of battery.
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 07-27-2011, 01:41 PM   #3327
Trader Rating: 77 (100%+)
Originally Posted by VAzRACER View Post
The Reflex Racing RSD pistons are 1,1,1.5. They are a direct fit for the TC6.
Just ordered some up. Hope they ship quickly.
goin2drt is offline   Reply With Quote
Old 07-27-2011, 03:47 PM   #3328
YoDog's Avatar
Trader Rating: 26 (100%+)
If anyone want's their Spec-R diff modified to fit the TC6, I will provide the service to do the machining on my lathe. Ship to me with a prepaid padded envelope or return shipping label for a flat rate USPS box and I will professionally machine the parts to fit correctly instead of butchering the components with a Dremel.
I will only charge $10 for the machining service, satisfaction guaranteed!
PM me with any questions.
YoDog is offline   Reply With Quote
Old 07-27-2011, 05:13 PM   #3329
nicorozog's Avatar
Send a message via MSN to nicorozog Send a message via Skype™ to nicorozog
eyy if anyone needs a parking lot setup, this would be a good point to start.
Also i have a few questions:
1. Has anyone tried the Diff T-Nut - Minilocknut, with the diff thrust bolt, of the AE B4 Buggy?. I´ve Heard that it would be a good option when you damage the stock Mini-Locknut trying thighten the screw for the spool....
2. Which are the "ball ends" that i should use to get 5mm of rear droop?
Thanks a lot from Bogota!
nicorozog is offline   Reply With Quote
Old 07-27-2011, 09:14 PM   #3330
ty
-b
I needed 20g on electronics side (low profile servo, spektrum micro rx, SXX TC spec, X12 6.5, no motor fan or heatsink, reedy 5500 pack). With a standard size servo, a heavier esc or a fan/heatsink on the motor, you will probably need 5-10g on batt side.
Mike Gee
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28961 07-11-2017 01:29 PM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
