Like Tree1Likes
Old 07-15-2011, 11:10 PM   #3241
roger999's Avatar
Originally Posted by lostinbaja View Post
My Brother had the same problem. If the pinion was properly lined up with the spur, the grub screw on the pinion would not tighten on the flat area of the motor shaft. Naturally he didn't want to buy another motor with a longer flat machined on the shaft or locate another pinion with a different offset that might work. He brought the motor to work and machined the flat on the shaft long enough to allow the pinion grub screw to tighten on the flat.
yep, im thinking to do that, just to be sure if in the future wont have the same problems. is that shaft very hard to do it? or normal dremel would be ok?
r o g e r g r a f i x . c o m
facebook.com/rogergrafix
roger999 is offline   Reply With Quote
Old 07-16-2011, 11:08 AM   #3242
Originally Posted by Molala4 View Post
can anyone tell me the dimensions of the hubs bearings? (bearings holding CVD in read hub and steering cup) and size of diff ball?
6x10 for bearings (in mm) ref 31404
3/32" (US size) ref 6581
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 07-16-2011, 04:34 PM   #3243
Buckaroo's Avatar
I dremel mine. Works perfectly.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 07-17-2011, 01:19 AM   #3244
roger999's Avatar
Great will do thanks!
Old 07-17-2011, 11:31 AM   #3245
So I got my TC6 running, will be testing on the track to get ready for my first ever race. I'm sure I'll be breaking a few things, but currently have no spares for anything. I'm trying to keep the overall budget down a bit, so I need to be smart in what I stock up on. Does anyone have a list of recommended spares I should start picking up?
JKSullivan is offline   Reply With Quote
Old 07-17-2011, 01:40 PM   #3246
the only thing i have had issues with are the belts and pinion/spur gears due to pebbles,otherwise it has been a lot of fun to run. i however dont race on a track just in a smooth parking lot....
beaven is offline   Reply With Quote
Old 07-17-2011, 01:55 PM   #3247
You will need c-hubs, rear hubs and steering blocks. All the rest is pretty much faultless. Been running mine for almost 6 months of racing and only broke a c-hub. One advise - start slow to be fast. Good luck.
Team AME/ORCA
https://www.facebook.com/strawberryrcdesigns
http://www.strawberryrcdesigns.pt/
jorgesimes is offline   Reply With Quote
Old 07-17-2011, 02:20 PM   #3248
VAzRACER's Avatar
Trader Rating: 17 (100%+)
Get some of the dog bone blades too. They dont break or wear out often but they are cheap and worth having a few on hand. Ive seen a few TC6's at the track rip an arm off and normally one of the arm mount blocks and the shock cap break. This is rare but again they are cheap parts and worth having around. I've helped out a few people with these parts who otherwise wouldnt have been able to finish the race day.
Good luck with the car.
Reflex Racing / Psycho Cells
VAzRACER is offline   Reply With Quote
Old 07-17-2011, 02:31 PM   #3249
I always carry:
front and rear wishbones
C hub front 4 degrees (std)
long inner hinge pins
87t spur gear
long/short belts (never broke one yet, same on TC5 but it is the day you do not have it that something will happen, sods law)
diff gear (same on diff and spool)
dog bone bearings (because they are quite fragile)
spur flanged bearings, just in case and screws that fits them (because I have lost two already)
this is quite extensive but I race at league level. I actually carry more but this is a good list to start with.
Put a tiny amount of threadlock on those two spur gear screws and check them regularly.
You will probably have to invest in some shock springs depending on your track.
Enjoy racing with your new "baby"
Old 07-18-2011, 02:48 AM   #3250
P.I.M.P's Avatar
Trader Rating: 14 (100%+)
Default servo turned
Hi guys thought i would share a pic of my servo turned gives better room for electrics and plus great for moving weight forward if needed have not tested to see how the car likes it so cant say if its for the best or not.but if going on how my t3 11 felt it should be a good mod.cheers
Vbc wildfire D06
clinton livingstone
P.I.M.P is offline   Reply With Quote
Old 07-18-2011, 02:50 AM   #3251
Attachment 782864
Nice!
I did it long time ago, it works for me better then stock.
You should surprized when enter corner
Regars!
m.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 07-18-2011, 03:47 AM   #3252
What's the difference by using long or short camber link?
nicoo2k4 is offline   Reply With Quote
Old 07-18-2011, 05:24 AM   #3253
daleburr's Avatar
Attachment 782864
I'd wondered if the link would fit there on the bellcrank. Might give it a try as I'd like to separate the ESC and motor to improve cooling.
Good stuff
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 07-18-2011, 05:44 AM   #3254
Hi did you file your top deck?
What parts did you use to make the change?
and by doing this are you not by-passing the servo saver and losing the different positions for ackerman in the process?
Old 07-18-2011, 06:33 AM   #3255
The shorter the link the more camber change will have, but will not roll as easy as a longer link.
Team AME/ORCA
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28952 05-01-2017 04:47 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
