Like Tree1Likes
Old 07-09-2011, 02:59 PM   #3166
bvoltz's Avatar
Trader Rating: 44 (100%+)
Originally Posted by olly986 View Post
I did not cut the balls like Rick mentionned but bought some collar with a grub screw and fitted one on each inside of bulkhead like explain.
The play is way to high and does upset your set up.
Just make sure that there is a bit of play not to lock the sway bar (antiroll bar)
I forgot to mention in my explanation to remove the shock absorbers, but Rick corrected this in his. (and I did too)
I can take a pic if needed of my car.
That would be great... I use my Hudy setup and set the car on the 0 blocks. I would also say to anyone, make very sure that you arms move freely, I had one side with a very slight bind, just needed to give a touch with a reaming tool or drill bit to make sure that the arms moved freely.
What I do is set my car on the hudy station, like I'm going to set the droop, and with a caliper I raise the one side watching the other until it moves, then do the same to the other side, until I get the same reading on the calipers for both sides.
The turning the car upside down as described by Rick is something I will give a try, it sounds very interesting and simpler.
My order on the setup is:
After checking the car for any tweak (does it sit flat on the board? If not get the tweak out.)
1. Droop
2. Sway bar setup
Attached the shocks
3. Camber
4. Toe
Load the car to race weight
Put on the tires
5. set ride height
Install the front bumper (I remove the front bumper to set the ride Height).
bvoltz is offline   Reply With Quote
Old 07-09-2011, 03:21 PM   #3167
Here are my babies:
Uploaded with ImageShack.us
And the collars front and rear
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 07-09-2011, 03:43 PM   #3168
bvoltz's Avatar
I did the same thing... Place collars on the bar just like you.
Old 07-09-2011, 03:56 PM   #3169
if others want to do this, make sure the collars are not too wide, it just fits with the diff gear and you do not want them touching.
Old 07-09-2011, 04:48 PM   #3170
mr fit's Avatar
I'm looking for a gear diff. The only one I see that may be compatible is the yokomo bd5 gear diff from spec-r. Would this work for both front and rear using the stock axles.
marc davila aka... marc ups.... drive it like you stole it.
mr fit is offline   Reply With Quote
Old 07-09-2011, 08:37 PM   #3171
pcar951's Avatar
Trader Rating: 19 (100%+)
Yup, minor mods required. Take about 1mm off the long side diff housing bearing shoulder to fit the diff between the TC6 bulkeheads, dremel the outdrive cups to fit the larger drive shafts and voila. About 10 minutes for the whole process. Or... wait for the AE version, it's gonna be great!
pcar951 is offline   Reply With Quote
Old 07-09-2011, 09:57 PM   #3172
mr fit's Avatar
I think I'd rather wait for the proper one to fit. I don't like making modifications and then it won't come out right. That sounds like too much work.
Old 07-09-2011, 11:56 PM   #3173
JayBee's Avatar
Trader Rating: 31 (100%+)
Yeah, I just modded my first one for the rear, but I modded the dogbone. It fits really well but my issue is the blades. They spread in the outdrive when power is applied. I've tried the Yoke blades and Associated ones and they both do it. Just wondering what to try next.....
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 07-10-2011, 12:44 AM   #3174
piper48
Guest
Posts: n/a
Jaybee, put a silvercan in...problem solved.
Old 07-10-2011, 02:30 AM   #3175
I am fitting a Sakura zero gear diff to mine, waiting on 40t gear to arrive, have made this changes so far, sounds a bit much but it fits nicely.
Changed plastic gears with xRay NT1 metal ones
Changed outdrives with short Kyosho RRR V1, Sakura's are too small.
Use the supplied ball bearings, they are plenty shims in Sakura's set to fit the width, the kit is cheap, I had the Kyosho outdrive and I bought the NT1 gears.
The gear is on the way and should land this week, so as soon as it arrive I will finish it and try it.
Mr Fit: You can fit front and/or rear as they are the same size.
Old 07-10-2011, 05:14 AM   #3176
my car runs ok on throttle, but it pushes a lot off throttle, is kick up the answer? my car is currently running zero kickup and silve spring in the front....
Molala4 is offline   Reply With Quote
Old 07-10-2011, 05:26 AM   #3177
Shock oil? rear spring? caster blocks? toe?
Old 07-10-2011, 06:44 AM   #3178
pcar951's Avatar
Yokomo blades are soft, some BD5 guys are running "white blades". Read back a few pages in the BD5 thread, not sure who makes them but, I guess they're lasting a lot longer.
Old 07-10-2011, 06:52 AM   #3179
pcar951's Avatar
Kick up could help but, 1st maybe try:
- more rear droop
- softer front spring
- lighter shock oil
Make sure there's nothing binding in the suspension/steering.
Old 07-10-2011, 07:18 AM   #3180
Redrill by dremel only diff outdrives!
I made that AE axle fit outdrives and there is no problems with blades
Don't cutt ae dog bone, it is wrong! Pin from dogbone will go off
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28961 07-11-2017 01:29 PM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
