Old 07-03-2011, 07:50 AM   #3106
Originally Posted by Bobert Ross View Post
I was looking for parts on the tc6 list on tqrcracing and they have the 46mm tamiya shaft in the list..does this fit? I was wondering if anyone has found any other bones to work?
Tamiya (53724)
TB Evo IV 46mm Swing Shaft - Lightweight (Blue)
TOP racing used to produce carbide steel pins set for tc5 which u can use on tc6. i am using them. they are rigid, fit and smooth. u may need to contact a model shop from hong kong thought....
Molala4 is offline   Reply With Quote
Old 07-03-2011, 06:26 PM   #3107
RAL
RAL's Avatar
Trader Rating: 59 (100%+)
Anyone know what Yokomo springs Juho Levanen ran at the Reedy this year?
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 07-04-2011, 01:31 AM   #3108
pink/blue
thilo-alexander is offline   Reply With Quote
Old 07-04-2011, 02:36 AM   #3109
RAL
RAL's Avatar
Originally Posted by thilo-alexander View Post
pink/blue
Danke
Old 07-04-2011, 02:44 AM   #3110
Any updates on how far away a associated made gear diff is???
Lionel S is offline   Reply With Quote
Old 07-04-2011, 04:32 AM   #3111
decibels's Avatar
it will probably be aafter the event that you need it
Team Wave Speedies
Thunder power lipo's
flying fox rc
!!And an idiot with a controller!!
decibels is offline   Reply With Quote
Old 07-04-2011, 08:51 AM   #3112
Buckaroo's Avatar
Anyone have any suggestions on base set up for a 17.5 blinky RCGT on a 150x60 smooth, soda prepped asphalt track? Traction is medium, and tires are limited to HPI X patterns.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 07-04-2011, 09:15 AM   #3113
FastPete's Avatar
Trader Rating: 44 (100%+)
What a great car! Bought it on Friday and was racing on sunday! No issues, easy build. Never drove a 1/10 scale car before. Box stock setup, but the rear toe set to 2.5.
Qualify 5th in the A and finished 5th! Cant believe how this car is stuck. Outdoor high bite track. Only issue was a traction roll and a heard hit to the wall. Bent the left rear bolt for lower hinge pin! My fault.
Lots of great info on this thread thanks!
Authorized Dealer for /Agama / Tekno / Team Associated / Schelle / Hobbywing / PT Racing Shock & Diff oil / Serpent / Tekin / JConcepts / AKA / Proline / Savox / M2C / Picco / www.fiercercsolutions.com Like us on facebook www.facebook.com/FierceRCSolutions
FastPete is offline   Reply With Quote
Old 07-04-2011, 09:30 AM   #3114
Verndog's Avatar
Trader Rating: 16 (100%+)
I'm fairly close to this setup and like it (but still evolving). I must say the TC6 is pretty darn good with a large variety of setup changes, more so then the TC5. Many of the setups are geared more toward high bite which we see more med around here. For me this seems a bit better for that. For springs you may want to start with silver / silver since it calls for HPI springs. Really good aftermarket springs are the Reflex springs.
http://www.teamassociated.com/pdf/ca...ftr_6-2011.pdf
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 07-04-2011, 10:21 AM   #3115
Buckaroo's Avatar
Thanks, Verndog. I'm looking to slap a set of your Dial A Grips on the car soon, too!
Tom Keith
Old 07-04-2011, 02:20 PM   #3116
muststopcrashin's Avatar
Originally Posted by Verndog View Post
Not sure where your question is but these are the basics. Put them on just like the AE blocks, only while tightening the main block screw into bulkhead you need to hold the block down to rest on the top set screw to locate. After tightening there should be tension on the top 1.5mm driver screw. Then lock the pin set screw againt hinge pins and drive like mad.
thanks Verndog, thats helped, is the standard setting ie as shipped on num 2 blocks same as the a3 setting ?
sorry im crap with new stuff but want to get your product at its best
MUST STOP CRASHING!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
RC10(1990),FT TC3,FT TC4,TC5,TC6
muststopcrashin is offline   Reply With Quote
Old 07-04-2011, 02:27 PM   #3117
Verndog's Avatar
There are 2 ways to get to the A3 block setting. 1 is with the 0 block in the B hole and turn the top locating screw 1 full turn CCW (unscrew). This makes the 0 block longer by .020 which is just where the A3 block puts it.
2nd way is obviously using the PPD 2 block in the A hole and shorten the block all the way --turn CW 1 1/2 turns (screw in till full stop on main screw).
I advise to download or bookmark this and print it. Then lay out your AE blocks in line 0-3 and see the progressive height difference. Once you view this and the blocks it makes much more sense.
http://www.ppdbillet.com/TC6-LOCK-BLOCK-NET2.pdf
---Team Hoarders---
Old 07-04-2011, 02:47 PM   #3118
thanks that's grate, i think i got it now, they do look cool on the car , i'll show em off at the weekend.
thanks again for the help
Old 07-04-2011, 04:18 PM   #3119
Verndog's Avatar
Default Useful Block Height Info
I've looked for this and not found it so I took some measurements from the chassis and blocks and figured I'd post these arm mount block heights for the TC6.
Beginning with B mount values and numbers are +/- off the B0 block location. For less confusion and the fact the B0 block is close to center of travel, I started there. + is higher roll center (arm is further up from chassis) and - is the opposite direction (arm is closer to to chassis). All numbers are in inches, for mm multiply x 25.4
AE TC6 Block Heights
B0 = 0 (NOMINAL)
B1 = +.050
B2 = +.080
B3 = +.115
A0 = -.136 (impossible though as mount wont fit)
A1 = -.086
A2 = -.056
A3 = -.021
---Team Hoarders---
Old 07-04-2011, 08:41 PM   #3120
FastPete's Avatar
Does someone know the part number of the blue aluminum spacers to use instead of the plastic ones between the rear lower hinge pin mounts?
Thank You
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 07:34 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28937 01-14-2017 07:26 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 12:42 PM
SEO by vBSEO 3.5.0
