Like Tree1Likes
Old 06-30-2011, 01:43 PM   #3076
Buckaroo's Avatar
Originally Posted by Johncho View Post
Your links aren't working????
Seem to work just fine for me.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 06-30-2011, 02:02 PM   #3077
HB Moose's Avatar
Guess I'm running my front belt too loose. I noticed I've worn off the left side of the teeth edge the motor shaft. Is there a standard way to figure out loose enough but not too loose?
Bruce "Moose" Riedinger
HB Moose is offline   Reply With Quote
Old 06-30-2011, 02:26 PM   #3078
wtcc's Avatar
If you lift the belt in the middle between the pulleys it should move around 5mm up.
wtcc is offline   Reply With Quote
Old 06-30-2011, 06:41 PM   #3079
Your right now they work ???? maybe it was my computer.
Johncho is offline   Reply With Quote
Old 06-30-2011, 07:35 PM   #3080
artwork's Avatar
Trader Rating: 59 (100%+)
Probably hitting the pinion or pinion set screw...check to make sure it is all the way in towards the motor
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 07-01-2011, 04:28 AM   #3081
swimbikerun's Avatar
Trader Rating: 100 (100%+)
Does anyone have a picture of the Associated TC6 Ballast Weight (Part 31296)? I see it is available but none of the online retailers have a picture or description of it. Thanks.
-Xray T4 '16/Xray X12 '16
-2010 Cincinnati Beer Mile Champion
swimbikerun is offline   Reply With Quote
Old 07-01-2011, 09:35 AM   #3082
http://teamassociated.com/factorytea...details/31296/
Here it is.
Old 07-01-2011, 09:49 AM   #3083
35$ for some ballast weights?
I'll stick to automotive tire balancing lead weights
Fastfreddy74 is offline   Reply With Quote
Old 07-01-2011, 09:55 AM   #3084
Verndog's Avatar
Trader Rating: 16 (100%+)
I was looking forward to balancing my TC6 with some cool new design weights...got all done and it was spot on with NOTHING! I was pretty shocked, and if someone needs all that weight I'd say you really just need a heavier battery that will give more punch at the end of the race (or move the battery as that makes a big difference!).
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 07-01-2011, 10:01 AM   #3085
I think even xray is cheaper than that, and corally...... tape weight it is.
Support those that support us
http://ActivRC.com http://TeamPowersUSA.net http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 07-01-2011, 10:29 AM   #3086
http://www.rcplanet.com/Associated_B...p/asc31296.htm
$27.95 and xray weight in def not cheaper. The associated stuff adds up to 60grams
20 grams from xray is $21 dollars at amain. For 60 grams that would be $63 Associated stuff sounds like a bargain
http://www.amainhobbies.com/product_...ight-2011-Spec
Team Associated, Reedy, Tekin, Futaba, Putnam, Protoform, BSR, SXT, Reflex Racing, McPappy Racing, TQ Wire, Swifty Designs
Jeff Cuffs is offline   Reply With Quote
Old 07-01-2011, 10:44 AM   #3087
Buckaroo's Avatar
...and NONE of it is any more effective than a $5 strip of stick on wheel weights.
Tom Keith
Old 07-01-2011, 11:17 AM   #3088
roger999's Avatar
Default gear mesh
cant set motor properly is little bit not straight... can fill it on gear mesh... that is normal? or motor mount is not in line...? or problem is in spur...?
facebook.com/rogergrafix
roger999 is offline   Reply With Quote
Old 07-01-2011, 11:21 AM   #3089
Trader Rating: 25 (100%+)
Your car looks alot more professional and clean with the Associated weights, not a tire on a car in the parking lot
My car balances perfect with the Associated weights
matt rem is offline   Reply With Quote
Old 07-01-2011, 04:19 PM   #3090
wtcc's Avatar
I prefer tire balancing weights, too. Got them for free and because of their size 5 or 10 gr. you can place them everywhere in the car. Would prefer running without them but rules say 1400gr. and the allowed electronics are that light, that my 5400 50C battery has to much weight on its side. So I carry always around 100gr. extra weight in my car...
By the way only HB bodies are allowed. Mazda works fine, but looks boring. Today I tried to convert it into a BMW 320 TC in the WTCC Tom Coronel style:
This is the real one:
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28961 07-11-2017 01:29 PM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
