Like Tree1Likes
Old 06-25-2011, 04:43 PM   #3031
venom54's Avatar
Originally Posted by spongerX View Post
Make sure the slipper spool is built right. If you're coming from a TC5r those instructions did not use thrust balls between the thrust washers but the TC6 do use the thrust balls. I always found my TC5r slipper spool to work better with the thrust balls for some reason.
If your slipper spool is built right but keeps loosening up change the bolt and nut. Re-assemble with a dab of thread lock on the end of the thrust bolt and wait a bit for the thread lock to set.
When built properly it should be quite hard to get the front wheels to rotate independently and it should stay that way in a race.
If you still have problems with the alloy nut and kit 2.56 bolt just replace these with 2mm stainless bolt of the same or slightly longer length and M2 stainless lock nuts; M2 Stainless lock nuts fit into the plastic holder with no issue (already tried and tested). This setup holds better and is less likely to strip! Both fit the TC5 or TC6 as a better replacement.
Cheers
Ren
Play hard but be nice to your parents!
VBC RACING|ASSOCIATED|XRAY|TEAM POWERS|THUNDER TIGER|HOBBYWING|HPI|WTF FANS|ORION AND MORE IN STORE.
145 COMO PARADE EAST 3195 PARKDALE VICTORIA AUSTRALIA.
www.rabhobbies.com.au
venom54 is offline   Reply With Quote
Old 06-25-2011, 09:00 PM   #3032
thx for all the advices above! and has anyone been running front and rear ball diff with good result? if i am to run this setup should i set the front ball diff to become very tight?
Molala4 is offline   Reply With Quote
Old 06-26-2011, 11:14 AM   #3033
No ball diff fully tight, a ball diff is not made for this.
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 06-26-2011, 12:40 PM   #3034
Hi!
Ball diff set as manual said and for front put diff oil 100k from nitro onroad.
Or lower value.
It will lock your diff
I did it for test some years ago to see how it can work for me with tc5 but for me is better solid axle.
Regards!
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 06-26-2011, 02:26 PM   #3035
I can imagine thick, sticky oil all over the front of car...
A diff ball is ...well a diff ball, if you want to lock it, remove the balls!! but even this I would not recommand really, you will more than likely melt your gear if it slips a little.
The best is still a spool, not expensive piece of upgrade.
I am waiting for diff gear for the back. I do intend to try front ball diff with it too, so I will report later on I have tried it.
Old 06-26-2011, 04:54 PM   #3036
do the thickness of arm holder spacers correspondes with the thickness as shown in the manual? coz it that is the case i got no 2 degree spacers with my kit..........
Old 06-26-2011, 07:24 PM   #3037
There should be 3 thicknesses of spacers in your kit. The thickest is 2 degrees. The thinnest in my kit was in a separate bag.
spongerX is offline   Reply With Quote
Old 06-27-2011, 03:35 AM   #3038
Hi!
Hm, this oil is really thick and you don't put it too much.
Also check for: Silikonfett 15.000cps, 15g Kyosho 96504
Kyosho do very thick silicon grease
Regards!
Michal Abramowicz
Old 06-27-2011, 03:18 PM   #3039
Default Some small modZ at rear end ;)
will test it at this Saturday :-)
Michal Abramowicz
Old 06-27-2011, 04:16 PM   #3040
Trader Rating: 77 (100%+)
Default AE gear diff
When is the rumored AE gear diff coming out? I would really like to try one but I am just not wanting to modify my car to get a Yok or Spec-R to fit.
goin2drt is offline   Reply With Quote
Old 06-27-2011, 05:15 PM   #3041
Verndog's Avatar
Trader Rating: 16 (100%+)
There are many of us on that list...no official dates but best guess from reading what I can find 1-2 months likely before we'll be able to get them. Diff / spool works pretty well too, hold out for the real thing IMO.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 06-27-2011, 05:22 PM   #3042
Originally Posted by M.Abramowicz View Post
Attachment 773721
Attachment 773722
Hey what is the blue looking liner around your chassis edge???????
Johncho is offline   Reply With Quote
Old 06-27-2011, 05:34 PM   #3043
Verndog's Avatar
Please make it stop...too painful to imagine.
On the plus side....think I just found my dial-a-grip poster child.
---Team Hoarders---
Old 06-27-2011, 06:01 PM   #3044
Default What?????
Old 06-27-2011, 06:06 PM   #3045
That is exactly what I was thinking.
I am converted. Ran them again yesterday. All day long and didn't have to touch them once.
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28952 05-01-2017 04:47 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
