Team Associated TC6 Thread >
Like Tree20Likes
Old 06-24-2011, 02:21 PM
  #3016
Originally Posted by JayBee
I'm very interested in these gear diffs, which one takes less 'Macgyvering' to make fit our cars?
Both about the same as far as macgyvering. The yokomo is a better gear diff as far as leaking but you have to run the car a bit wider so the bones dont bottom out on the yok..
Jeff Cuffs is offline
Old 06-24-2011, 04:27 PM
  #3017
JayBee's Avatar
Trader Rating: 31 (100%+)
So with the Yoke geardiffs, I am still using the TC6 axles/dogbones/blades correct?
JayBee is offline
Old 06-24-2011, 05:06 PM
  #3018
Hebiki's Avatar
Trader Rating: 26 (100%+)
thats good for at least two tenths.
Hebiki is offline
Old 06-24-2011, 05:09 PM
  #3019
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
with modification to fit...yes
OVA is offline
Old 06-24-2011, 05:37 PM
  #3020
yes
Old 06-24-2011, 05:43 PM
  #3021
Potoczak's Avatar
Trader Rating: 120 (100%+)
Where is the best place to get the yok diff ?
Potoczak is offline
Old 06-24-2011, 06:02 PM
  #3022
Trader Rating: 25 (100%+)
Driftspeed.com, they carry Yokomo in the USA
matt rem is offline
Old 06-24-2011, 06:07 PM
  #3023
JayBee's Avatar
I just ordered 2 from rcmarket
JayBee is offline
Old 06-24-2011, 07:25 PM
  #3024
Jorge T's Avatar
Trader Rating: 14 (100%+)
to make the yok diff work with the tc6 driveshafts you have to drill out the yok out drives to make them fit. to avoid the hastle, order a set of 44 mm yok cvds, bearings and hex drives. it will cost more, but work right.
Jorge T is offline
Old 06-24-2011, 07:34 PM
  #3025
Verndog's Avatar
Trader Rating: 16 (100%+)
One of the main reasons I opted to wait on the AE diff. You start boring out the hard coating from the diffs, and they last about 1/2 as long like the old TC5 anodized (not hard coated) outdrives that lasted about 30 runs then toss.
Verndog is offline
Old 06-25-2011, 12:47 AM
  #3026
is the front slip spool supposed to be locked MAX tight?
i am having the problem of inconsistent cornering and i am thinking that the spool maybe the culprit...coz i can rotate the front tires in opposite directions pretty easily.....
Molala4 is offline
Old 06-25-2011, 02:52 AM
  #3027
wtcc's Avatar
Yes, the Slipper Spool has to be tight. If you grab both front tires you have to use some strength to turn them in the opposite direction.
wtcc is offline
Old 06-25-2011, 03:14 AM
  #3028
The AE when they come out !!
olly986 is offline
Old 06-25-2011, 03:59 AM
  #3029
Make sure the slipper spool is built right. If you're coming from a TC5r those instructions did not use thrust balls between the thrust washers but the TC6 do use the thrust balls. I always found my TC5r slipper spool to work better with the thrust balls for some reason.
If your slipper spool is built right but keeps loosening up change the bolt and nut. Re-assemble with a dab of thread lock on the end of the thrust bolt and wait a bit for the thread lock to set.
When built properly it should be quite hard to get the front wheels to rotate independently and it should stay that way in a race.
spongerX is offline
Old 06-25-2011, 06:56 AM
  #3030
Or fully locked with wet and dry pads made instead of original white pads like some racers use.
olly986 is offline
