Like Tree1Likes
Old 06-23-2011, 03:06 AM   #3001
Potoczak's Avatar
Trader Rating: 111 (100%+)
Originally Posted by spring71 View Post
Using Spec-R Yokomo BD5 Gear Diff for TC5/TC6.
It fits, but the CVD and out drive is tight.
Need to sand off CVD ends a little bit to make room for out drive.
Click here for more information.
FYI.
What's a good starting point for oil in the gear diff?? Running the car on a tight technical outdoor asphalt track. Medium to high grip.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 06-23-2011, 03:07 AM   #3002
Hello there
I am looking at fitting a Sakura diff gear in my TC6, the parts are on the way, will let you know how I got on as soon as it is in.
olly986 is offline   Reply With Quote
Old 06-23-2011, 03:37 AM   #3003
wtcc's Avatar
Originally Posted by cyrrus View Post
Hey guys thanks for the info.
well looks like I will be going with this ride very soon as long as my finacial advisor is okay with the purchase(aka the wife) lol
my next question is is there any info on building the perfect car,
from the time I opean the box to the momment i place her on the track.
I would also like to find a decent ashpalt stock set up too. to use as reference.
The given manual is the way to build the car. If you have problems with building just check this thread around page 40 and up. We all started building our cars from november 2010 and later. There are a lot informations. If you own a TC5 you already know how to treat a TC. The TC6 is not much different. For setups check the AE website. The things Keven Herbert did to his car work in most cases. One or two pages ago someone posted an asphalt setup which seems to work good.
wtcc is offline   Reply With Quote
Old 06-23-2011, 03:52 AM   #3004
thanks for the reply
i will start and read every thing i can prior to by build
cyrrus is offline   Reply With Quote
Old 06-23-2011, 06:51 AM   #3005
Potoczak's Avatar
Where is the best place to buy the Yokomo diff??
Pete Potoczak
Old 06-23-2011, 07:56 AM   #3006
Rick Hohwart's Avatar
Originally Posted by KHoff7 View Post
Might they be available before paved nats at the end of July?
I hope so but I am not optimistic. Sorry!
Originally Posted by Potoczak View Post
Hi Rick, are the Yokomo diffs a direct drop in or do you have to modify parts??
There are two diffs for the Yokomo BD5 that work in the TC6, one from Yokomo and one from Spec-R. I can't say for certain that the same modification is required for each but it should be.
First, the Spec-R diff is slightly too wide which means you will need to modify the main diff bearing holder so that the diff will fit. There should be a description of this mod in the Keven Hebert/TC6 question forum. You can also turn the diff in a lathe and remove material where the main bearings ride. I don't even think the need a lathe. If you can spin the diff (drill press or dremel?) you can sand the material away. You don't have to remove much.
Second, the drive cup is too small for the AE bone. Some people modify the dog bone or you can grind the cup (this is better). It does not take much to make the bone fit.
Originally Posted by Verndog View Post
Great news! Are they going to be setup to run blades or raw bones??
Blades.
Rick Hohwart is offline   Reply With Quote
Old 06-23-2011, 08:42 AM   #3007
Yes you can also changed the dog bones for yoks, but then you need to change the bearings in hub and have different hex holders (Xray works fine apparently)
the SpecR is deeper in outdrives than the original yoks.
So any ideas on releasing date for AE gear diff? I can wait until end of August for mine, the season restart in September.
Old 06-23-2011, 10:01 AM   #3008
hey guys just curious. since i've been in Pan car mode since last August.
What is the benefits of running a gear diff compared to a regular rear diff.
Old 06-23-2011, 10:38 AM   #3009
Verndog's Avatar
Trader Rating: 16 (100%+)
They say....quicker acceleration out of the corners, easier / more tuning options with oil weight or putty or owl feathers or what you want to put in it, and less maintenance / longer lasting then ball diff. Also when used in front more turn in as you have slight diff action but similar to spool while on power.
Dont know from experiance yet, these are things being said from others.
Read up here for more info.
GEAR diff or BALL diff ?
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 06-24-2011, 07:47 AM   #3010
But then on slippery track a ball diff could be better...more options to tune.
So far the ball diff works great with the spool on front.
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
Old 06-24-2011, 11:14 AM   #3011
Big Features's Avatar
I've personally found that the gear diffs are better and more consistent in super stock and modified. In stock and even super stock, the ball diffs are lighter and smooth after many runs. Front diff offers more initial turn in, but that can be solved with simple tuning.
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix
Big Features is offline   Reply With Quote
Old 06-24-2011, 12:36 PM   #3012
burgboyz's Avatar
Trader Rating: 70 (100%+)
Verndog said... owl feathers
Got Droop???
Speed Passion....Speed Power....Serpent America/Desoto Racing.
burgboyz is offline   Reply With Quote
Old 06-24-2011, 01:52 PM   #3013
YoDog's Avatar
Trader Rating: 26 (100%+)
If anyone is particular about the finish of their Yokomo or SpecR out drives, I will be happy to turn them on our lathe for about $5 per pair plus shipping. I can also turn your diff housings to free them up between the bulkheads.
I have good feedback here and make many custom parts for other cars. Some for the TC6 soon, as this is my ride of choice right now.
PM me for more info.
YoDog is offline   Reply With Quote
Old 06-24-2011, 02:04 PM   #3014
wtcc's Avatar
After my positive experience with his dial-a-grip I am willing to try that, too
Old 06-24-2011, 02:04 PM   #3015
JayBee's Avatar
Trader Rating: 31 (100%+)
I'm very interested in these gear diffs, which one takes less 'Macgyvering' to make fit our cars?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28962 Today 04:05 PM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
