Old 06-17-2011, 09:34 AM   #2941
artwork's Avatar
Trader Rating: 54 (100%+)
I have been working pretty hard on a setup for the TC6 that works well on Med/High bite carpet. The major change I was trying to get in the car was a bit less stuck on the track. I think I have found a really good setup that I wanted to share. Please let me know if you have any questions...
http://linewerx.com/Linewerx/Racing_...rrc6202011.pdf
Car is very easy to drive and seems to rotate very well. I still think there is some room for improvement, but it is moving in the right direction.
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 06-17-2011, 12:32 PM   #2942
Asharus's Avatar
Trader Rating: 42 (100%+)
Originally Posted by Buckaroo View Post
For those of you having trouble mounting certain bodies with the stock front posts, AE PN# 4535 is a little taller, and solves all of your problems, especially those related to most of the VTA/RCGT bodies.
Click here
Has anyone tried this pre-painted RCGT body on their TC6? HPI says it's got precut holes for the body posts and antenna. I'm wondering if it lines up with the T6.
http://www.hpiracing.com/products/en/7712/
Angelo Padilla
Team Ballz Racin | PCR Bodies | Island Raceway & Hobby | Gilligan's Raceway
Asharus is offline   Reply With Quote
Old 06-17-2011, 05:52 PM   #2943
Potoczak's Avatar
Trader Rating: 107 (100%+)
What setup do you guys recommend i go with. I run on a med/high bite asphalt outdoor track. Tight and technical also.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 06-17-2011, 07:02 PM   #2944
venom54's Avatar
Default TC6 set up
Try the set up attached below. Rock solid and predictable easy drive.
http://www.rabhobbies.com.au/PDF/Nigel George TC6 setup.pdf
Cheers
Ren
Play hard but be nice to your parents!
VBC RACING|ASSOCIATED|XRAY|TEAM POWERS|THUNDER TIGER|HOBBYWING|HPI|WTF FANS|ORION AND MORE IN STORE.
145 COMO PARADE EAST 3195 PARKDALE VICTORIA AUSTRALIA.
venom54 is offline   Reply With Quote
Old 06-17-2011, 08:50 PM   #2945
Verndog's Avatar
Trader Rating: 16 (100%+)
Cheers
Ren
Hey Ren...that looks pretty close to where I'm at with a few minor exceptions. I have a question on the ride height, was that a fairly bumpy track or was he trying to put a little more weight forward with the 5.5mm front and 6.5mm rear? Don't often see that tall in the rear is why I ask.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 06-17-2011, 09:55 PM   #2946
venom54's Avatar
Bumpy straight on track so needed the height.
Cheers
Ren
Old 06-18-2011, 02:12 AM   #2947
bshookup's Avatar
Trader Rating: 18 (100%+)
I would not assume that the body holes would match up with a TC6 unless it was explicitly noted. It looks like the body holes were made to fit the list of HPI cars listed in the link you posted above, and thes HPI cars more than likely have different body post locations from a TC6. You of course can always drill your own holes to make it fit your TC6
TOP RACING: www.top-racing.jp/
TEAM POWERS: www.teampowersusa.net/
bshookup is offline   Reply With Quote
Old 06-18-2011, 10:02 AM   #2948
Asharus's Avatar
Thanks, I'd rather get an unpainted one and make my own holes then.
Angelo Padilla
Old 06-18-2011, 10:08 AM   #2949
My tc6 tweaks seriously what should i do?
Molala4 is offline   Reply With Quote
Old 06-18-2011, 10:41 AM   #2950
ahpeq_ong's Avatar
Originally Posted by Rick Hohwart View Post
There is nothing wrong with two hole pistons.
sorry for silly question...
what is the diff between 2 hole and 3 hole pistons...?
ahpeq_ong is offline   Reply With Quote
Old 06-18-2011, 08:18 PM   #2951
artwork's Avatar
Two hole pistons only have two holes which based on their size will make the shock feel a bit thicker. Adding an additional hole will help to move through the oil a bit easier which in turn makes the shock feel like you are running thinner oil. All of this however can be adjusted based on the size of the holes. AE offers four different options in pistons...
1) #1 Piston with two 1.40mm holes
2) #2 Piston with two 1.32mm holes
3) #3 piston with two 1.19mm holes
4) Blank pistons with no holes (so that you can drill your own)
I typically run and like the feel of three hole pistons, so I run #3 with an extra 1.5mm hole drilled in it.
I have tried the Losi pistons, but usually end up with the AE pistons back in. Simply the shock was designed around the AE piston shape and I think the Losi pistons create a different feel with additional blow by around the outer edge. All of the is very hard to feel on the track, but on the bench I can tell. I would think it would take a very good driver on a very consistent surface to honestly feel the differences between #1 and #2 pistons with the same oil.
Old 06-19-2011, 08:36 AM   #2952
Trader Rating: 77 (100%+)
Default Dial-a-grip
VERNDOG RULES!!!!
Ran the dial-a-grip for the first time. Those things rock. No slop after running all day. Hit a few boards, broke a c-hub and nothing. Those things rule, if nothing else just to not have to tighten the stock ones after every run was worth it.
goin2drt is offline   Reply With Quote
Old 06-19-2011, 09:58 AM   #2953
Default Turnbuckles
I need some replacement turnbuckles. Amain does not have them, any ideas?
Old 06-19-2011, 11:30 AM   #2954
bhambrent's Avatar
Originally Posted by goin2drt View Post
VERNDOG RULES!!!!
I have too 2nd that.
Also like how fast you can try new block setup with dial-a-grip.
Great job VERNDOG,
bw
bhambrent is offline   Reply With Quote
Old 06-19-2011, 12:12 PM   #2955
Send a message via AIM to Jonesy112
I blieve all of the turnbuckles are sizes they already manufactured for other cars. If you just measure the total length of them and them search for the associated turnbuckles that length, you should be good.
I would check my manual and give you the lengths needed, but I am on vacation and dont have my rc stuff with me.
Michael Jones
RC America - X-Ray - Team EA Motorsports - RockStar Paint - Apex RC Proshop - ProOne Tires
Jonesy112 is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 07:34 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28937 01-14-2017 07:26 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 12:42 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
SEO by vBSEO 3.5.0
