Team Associated TC6 Thread
#2881
Tonight I got as far as installing diffs and shock towers. Missing two more screws, and if that wasn't bad enough, I checked the tweak after installing the topdeck and tightning the screws on a flat surface, the front of the chassis has a millimeter and a half bow in the front. Looks like I will be calling associated again tomorrow. Very dissapointing build to this point.
#2883
#2885
I am just trying to cover my bases in the hopes that someone can help me out of this mess.
#2886
Mudvayne you sound like your a keen model builder and have a great
eye to find what is needed to make the TC6 a better kit. yours will be the flatest, straightest, smoothest car on the track!
Man I have to come and watch you, you must never crash!
maybe lighten up on the negetive stuff on the TC6, I have one and love
mine it had some small issues in the build but I managed them and kept on going. still a great car. Verndog saw the issue that we all noticed and fixed
it. Many thanks Verndog for that you did a great job.
Just Drive the car you'll like it or you wouldnt have bought it.
#2887
#2888
Ok then as long as I'm helping we're moving in the right direction!
Getting you to the track and having a great time with the TC6 is
all that's important. So if you have found some screws to fill the
short fall and have left the tightening of those screw till the car
is near ready for set up and you have rung AE to replace the parts
you unhappy with, and Im very sure they can help you out there.
then your good to go. Correct!
Then slap some electronics in that baby put a body on it and hit
the track and enjoy the great product that AE make for the price
they make it for.
they make it for.
#2889
Its ppl like you with the negative attitude towards things that ppl in the hobby listen to..... You can not expect everything to be completely perfect with every kit as they makes 1000's of them..... If you have been in the hobby for the time you say you have you would have cried on more than one occasion cause something didnt go your own way... I dont care who you are there is no need to call anyone any names and put them down..... The tc6 is the best kit I have built to date the only thing I had missing was thrust washers for the diffs so I didnt whine or bitch I just bought new thrust washers off of ebay and it was all done...
Enough said and I think u get the hint..... No matter how many posts you have on this site or what it says under your screen name on rctech you are just one other person just like anyone else period.....
I have been involved in this hobby since 1989, and I have built a few models in my time. I don't expect everything to perfect, but I expect it to be right, especially when I spend over $400. At the very least it should have all the parts. But hey, thanks for your smartass attitude, its a great help!
#2891
can i use trf shocks on tc6??
#2892
#2893
yes you can but i feel they would be a waste of money. they wont perform any better than the tc6 units. the new shocks when built correctly are just as smooth as tamiya trf. if you already have em you can use em but i would save them for the tamiya car as i dont think there would be any benefit on the tc6
#2894
#2895
Lastly on the top deck tweak, you are dealing with a 2mm narrow chassis that works awesome after you get it right, but time must be taken to find the proper tightening sequence and make sure things are in the proper position. I just saw this the other day as I was in a hurry putting back together and found tweak, loosened it up, went in proper sequence while clamping flat and problem solved. No manufacturer is going to be able to solve that for you, a calm clear head and a little time to learn the chassis will though.
