Like Tree1Likes
Old 06-08-2011, 03:34 AM   #2851
Trader Rating: 76 (100%+)
I finally got around to starting my build last night, and so far I am missing two screws, two spacers, and I had to ream out the arms a little to be free on the pins. I hope this isn't a sign of things to come.
MUDVAYNE is offline   Reply With Quote
Old 06-08-2011, 03:37 AM   #2852
Trader Rating: 23 (100%+)
If the screws you are missing are for the body mounts, you will find them in a later bag.. Or so i found with mine..
ox
Rotax125 is offline   Reply With Quote
Old 06-08-2011, 03:56 AM   #2853
I was missing (3) M3x6 button head screws and (2) M3x14. (2) M3x12 screws were in my kit isntead of the missing M3x14 I needed. I had spares from running my TC5 so used those. I thought I needed to ream my arms until I rolled the hinge pins on a flat surface and saw they were slightly bent. Rolled some hinge pins from my TC5r that were never used on the same flat surface and they rolled true.
I think with the TC6 AE expects the purchaser to already be an AE racer or at least have been in the hobby for a while to have all the spare bits and pieces needed to finish the car.
spongerX is offline   Reply With Quote
Old 06-08-2011, 10:18 AM   #2854
I slighty reem them out by hand with a small drill bit. I did it just enough so that the arms start to move freely. I guess I will find out more when I continue on tonight.
Old 06-08-2011, 06:03 PM   #2855
It seems like the more time I spend building this kit the worse it gets, and right now I feel like I'm in the middle of next week. I have tried to build the cva's but had to resort to leaving the set screw out. And now on the fourth and last one (of course, its always the last one), even with the set screw out it still binds terrably. This after not having 4 screws and having issues building the shocks, I must say I'm not really impressed with the TC6 so far.
Old 06-08-2011, 06:08 PM   #2856
Chaz955i's Avatar
Set screw can be a bear if you are putting it in last. Try putting the set screw in the dogbone first just enough so you can still get the pin through. You should be fine then.
At The Gate Bizzos
Chaz955i is offline   Reply With Quote
Old 06-08-2011, 06:12 PM   #2857
I think its more of a quality issue than anything else. The cva's are alot more free without the setscrew, and even with the setscrew out of the fourth, it still is binding really bad. I even tried to file it down, and it still didn't help.
Old 06-08-2011, 07:02 PM   #2858
Chaz955i's Avatar
I had one CVA that took a bit of work to get smooth. Ended up just running the set screw until it bottomed on the pin but no more pressure. Since I'm using threadlock it didn't need to be cranked down. CVA freed right up. I almost think the set screw was distorting the pin but have no real data to support that. In all honesty that was the trickiest part of the build. Guess I got lucky with a good kit. Either way there shouldn't be that much disparity from one kit to the next. Good luck. When they are right they are a great car.
At The Gate Bizzos
Old 06-08-2011, 07:20 PM   #2859
Put the set screw most of the way in when building the CVAs. Put the pin in and then tighten it. If left too far out during assembly it's not possible to get things together I've found.
I've never had binding from the set screw with all the TC5/TC6 CVAs I've built but where I have found binding is in the slot that's cut in the bone that the pin rotates around. I don't have a picture of it but just run a finger lightly over the ball part of the bone before assembling since it's not accessible after it's put together and near the end of it you might find some slightly raised metal around the edges of the slot. Cleaning up with a dremel grinding wheel or file should take car of that binding. 1 of my CVAs in my TC6 was pretty bad with the rough metal but tidying up the ball end of the bone around the slot with a dremel took care of that.
Old 06-08-2011, 07:21 PM   #2860
Verndog's Avatar
Trader Rating: 16 (100%+)
Sometimes you need to just keep moving forward and making progress and make a mental note to come back to something. In the case of 1 sticky CVA, put it on back, it likely will free up and you'll never notice it. Hang in there, possibly you got a Friday kit...it will be worth it once you hit the track. Also... I agree with deburring the slot being a possible cause.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 06-09-2011, 04:45 AM   #2861
ahpeq_ong's Avatar
looks like tc6 got lots of complain...
tweak problem, bulkhead material problem and cva..
now i really need to think twice...
is this problem happen to everyone..?
ahpeq_ong is offline   Reply With Quote
Old 06-09-2011, 04:47 AM   #2862
Chaz955i's Avatar
No issues with my kit.
At The Gate Bizzos
Old 06-09-2011, 04:51 AM   #2863
Haven't had any issue with mine...
Fastfreddy74 is offline   Reply With Quote
Old 06-09-2011, 05:06 AM   #2864
ahpeq_ong's Avatar
maybe 2 out of 10 got few problem...
but i heard ae customer support is damn good and fast...
Old 06-09-2011, 05:49 AM   #2865
mine is faultless since the beginning.
Team AME/ORCA
https://www.facebook.com/strawberryrcdesigns
http://www.strawberryrcdesigns.pt/
jorgesimes is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28952 05-01-2017 04:47 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
