Team Associated TC6 Thread
#2821
it s tweaked without any screw and parts. I just received my tc6 4 hours ago
#2822
From there, I'd try the place you bought it from and see if they will send you the chassis only and you can build some while you wait.
#2823
I just received my tc6 kit today but i have a little problem with my lowerdeck...
It s a lot tweaked When put my fingers on the front of the lowerdeck, the rear up 2 mm
Tested on a glass, my smokem 416 fx don't have any tweak on it...
This was without any parts fixed on the lowerdeck for both.
Can i do ? warantly ? is it right to have this tweak without parts ?
#2824
ok thanks
#2825
OK,.. now I am little bit confused.
It seems that tqrcracing is the only site claims Spec R gear diff for BD5 can be used for TC6.
Went to check with some LHS, they have no clue about this.
In order to used a Spec R gear diff (meant for BD5) in TC6, do we need an modification?? Can we do it with the original uj???
Please advise.
Please advise.
Spec-R Yokomo Gear Diff out drive is a little bit tight.
For TC5/TC6, Sand off CVD(Universal) ends to make the room.
My local customers are using Spec R Yokomo Gear Diff in TC6.
Thanks.
#2826
Curious what they are saying about the SpecR universals? I tried a set and 1 of the 2 was badly bound up at full tilt (the reason I bought them) so I took them apart and found both had bent pins that appeared to be too soft and quite a bit of slop in hole size. I put Xray pins into them and decided to leave those as 008 backups and use the Cyclone HVT in the TC6.
#2827
I had the same issue with the universals pins. I went to a machine shop supply store and bought drill blanks the proper size and cut them to fit. Much stronger and a better fit, of course I still do the shrink wrap deal to finish it off.
And btw your dial a grip looks very slick.
#2828
BTW...thank you.
#2829
This was done on a set of SpecR universals, and I actually only ran the shrink without the set screw, I beleive the setscrew is the cause for the pin issues and also a bit of a bind issue in some cases, not a perfect machine job so the pin can't float in the cutout like it should. Plus the set screws almost seem soft and strip out too easy. With the right shrink wrap like what used to come with the LOSI lcd rebuild kits not using the set screw should be no problem, although I haven't run this in a mod motor application, so I can't say that throwing the pin isn't a possibility, but i doubt it.
#2830
Don't let yourself confuse. This guy is just advertising his stuff without using his brain...
We have indoor rc track & hobby shop in chino CA.
Spec R Gear Diffs and Universals are in stock.
Click Here to see Spec R products.
Click Here to visit the parts store
Please visit www.tqrcracing.com for more information.
#2831
i just got a tc6 today to run in a vta class. does anyone know where i can find a starting setup for this? looked on ae website and tried the search here but didnt get anywhere
#2835
I use the yokomo BD5 spec r gear diff. on my tc6 with the stock universals. Just like spring71 said you just have to file down the ball part of the universal in order to get them to fit. If you want proof I can take a pic for you.
