Like Tree1Likes
Old 06-04-2011, 08:48 PM   #2806
Jochim_18's Avatar
Last weeks REEDY race after every run I re-tighten the screws cause they keep backing out. Luckily I kept my eye on them cause it did backed out half ways during controlled practice this is on running open MOD.
Originally Posted by burgboyz View Post
On carpet, the "0" and "1"s move a bunch! Noticeable handling difference in a 6 minute run. I thought it was just my rusty driving technique at first and wrote it off for a couple of months. Then frustration crept in with the nagging movement issue.
For a test I rolled around the track at 1/2 throttle for 15 laps and checked them and they were loose!!!
I'm sold on the Dial-a-Grip!!
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 06-05-2011, 03:49 PM   #2807
woozer71's Avatar
Trader Rating: 23 (96%+)
Running the TC6 on the weekend I could not get out of the corners without doing a 360 Spin. I am running a ball diff at the moment. I had about 4 blokes go over the car and changed it a bit but it was still spinning coming out of the corners. Also the drivetrain is very tight after freeing everything up. Could I get some ideas on what could be my problems.
Fraser Coast RC Car Club/FCRCCC
VBC D06 / Xray T4 2013
Yokomo BMax2 ver 2 - Tamiya F104 x1
Sanwa MT-4
woozer71 is offline   Reply With Quote
Old 06-05-2011, 04:07 PM   #2808
Trader Rating: 77 (100%+)
Check your shocks. Mine was doing the same and it turned out the screw holding the piston on came lose.
goin2drt is offline   Reply With Quote
Old 06-05-2011, 05:35 PM   #2809
Big Features's Avatar
Please post or PM me your setup.
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix
Big Features is offline   Reply With Quote
Old 06-05-2011, 06:28 PM   #2810
hacker's Avatar
Trader Rating: 140 (100%+)
tweak and droop settings are very important. I built a 2nd tc6 and the 1st run was like what you are experiencing. Car was tweaked from the get go, which made it impossible to setup droop correctly.
hacker is offline   Reply With Quote
Old 06-05-2011, 09:35 PM   #2811
spring71's Avatar
Smile
We have indoor rc track & hobby shop in chino CA.
Spec R Gear Diffs and Universals are in stock.
Click Here to see Spec R products.
Click Here to visit the parts store
Please visit www.tqrcracing.com for more information.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
http://www.tqrcracing.com
tq@tqrcracing.com
spring71 is offline   Reply With Quote
Old 06-05-2011, 10:27 PM   #2812
Geberit's Avatar
How do the Universals fit the TC6?
L.
Geberit is offline   Reply With Quote
Old 06-06-2011, 05:29 AM   #2813
Trader Rating: 32 (100%+)
OK,.. now I am little bit confused.
It seems that tqrcracing is the only site claims Spec R gear diff for BD5 can be used for TC6.
Went to check with some LHS, they have no clue about this.
In order to used a Spec R gear diff (meant for BD5) in TC6, do we need an modification?? Can we do it with the original uj???
Please advise.
hobbs is offline   Reply With Quote
Old 06-06-2011, 06:14 AM   #2814
turbodog's Avatar
if the drivetrain is tight, I'm guessing you have a CVD axle bound up or a bad bearing somewhere.
Troy Schafer
turbodog is offline   Reply With Quote
Old 06-06-2011, 06:22 AM   #2815
koopesv's Avatar
Trader Rating: 18 (95%+)
Did you try to turn down your steering trim, that could be a problem. Over steering will cause spin outs. Also look in to the Spec R gear diff its awsome all you need is a few shims and its good to go.
Durango - Speed Passion - Trinity
Gforce Hobbies Raceway
Urban Heat Racing
koopesv is offline   Reply With Quote
Old 06-06-2011, 06:42 AM   #2816
I just received my tc6 kit today but i have a little problem with my lowerdeck...
It s a lot tweaked When put my fingers on the front of the lowerdeck, the rear up 2 mm
Tested on a glass, my smokem 416 fx don't have any tweak on it...
This was without any parts fixed on the lowerdeck for both.
Can i do ? warantly ? is it right to have this tweak without parts ?
Manson is offline   Reply With Quote
Old 06-06-2011, 07:12 AM   #2817
Xpress's Avatar
Please advise.
I believe you need to open up the inside dia of the outdrive or remove material from the end of the bone to get the axles to fit.
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 06-06-2011, 07:40 AM   #2818
Jochim_18's Avatar
I'm using the Yokomo ger diff and my friend is using Spec-R gear diff all you have to do is just shave off some material inside the outdrive to make room for the CVD end that's all..
Old 06-06-2011, 07:45 AM   #2819
Jochim_18's Avatar
Chassis is not tweaked if you use the screws that have numbers on it they are not flushed on the bottom of the chassis that's why use the screws that don't have the numbering on it.
Old 06-06-2011, 07:46 AM   #2820
Verndog's Avatar
Trader Rating: 16 (100%+)
First if you used the stock kit screws they will sit below chassis and make it appear tweaked. Remove and replace, then check the front bumper plastic bracket, that sits a bit low also. If it still rocks then start loosening things up beginning with motor mounts, then top deck and check if it goes back to flat. I really doubt any RC company would take the kit back over this unless the chassis is clearly warped in a free state (nothing screwed to it). I haven't heard of that happening. Good Luck.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28952 05-01-2017 04:47 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
