Old 05-31-2011, 09:25 PM   #2761
Verndog's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Brian McGreevy View Post
Just got mine today, they look great! Can't wait to give it a go.
Originally Posted by mkennedy View Post
got mine today too...they really look great and installed like butter!!! great job kevin!!!!!
Now... go try to knock them loose guys...I dare you.
You wont...you should have seen my more poor car after I thrashed it testing...pulled a Speedmind thru the hex, then finally broke a servo saver...about the only spare I didn't have...but I do now. I have video of much of this, one day I'll post on my site. The TC6 CAN take an intentional beating, I'll say that. Now time to race a few weekends .
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 05-31-2011, 09:29 PM   #2762
YoDog's Avatar
Trader Rating: 25 (100%+)
Originally Posted by dmatter View Post
Anybody have any spur gear suggestions? I dont like it when my my gears dont line up. Makes them wear funny or not so funny.
You will just have to look for an offset spur gear or grind the flat on the motor shaft a little further in so you can slip the pinion on a little more.
xray makes offset spurs but they are a bit expensive.
YoDog is offline   Reply With Quote
Old 05-31-2011, 09:41 PM   #2763
Trader Rating: 77 (100%+)
I use Precision and Xray spurs and they line up fine.
goin2drt is offline   Reply With Quote
Old 05-31-2011, 10:04 PM   #2764
dont suppose you will be selling thing to us lot over in New Zealand anytime soon will you ?
Ed
Edwin Pibal is offline   Reply With Quote
Old 05-31-2011, 10:08 PM   #2765
Trader Rating: 19 (100%+)
Does anyone know the bearing sizes on the TC6? I'm about the place an order with Avid RC to replace all my existing bearings and I just want to confirm. TIA
zake540 is offline   Reply With Quote
Old 05-31-2011, 10:09 PM   #2766
Verndog's Avatar
Ed
Actually we shipped quite a bit there in the past. Pretty sure it's comparable to UK for shipping. Check the site tomorrow and New Zealand should be added.
---Team Hoarders---
Old 06-01-2011, 05:46 AM   #2767
dmatter's Avatar
Interesting...My PRS gears are off. Pinion either off the flat or rubbing the belt. Looks like I will be grinding motor shafts
dmatter is offline   Reply With Quote
Old 06-01-2011, 08:08 AM   #2768
Warren Weaver's Avatar
Trader Rating: 43 (100%+)
if you are running a d3 you do have to grind the rotor shaft i used a diamond cutter for the dremel and it worked awesome just be careful it will take a lot of material off fast.
R1 WURKS-AWESOMATIX USA-LRP-TQ WIRE-PROTOTYPE RACING-MCFACTORY MOTORSPORTS-SWEEP RACING-TXDSKINGRAPHIX-HOBMAX-THE RUG-TEAM EZDUZIT
R.I.P. MY FRIEND JDUB MISSED BUT NEVER FORGOTTEN
Warren Weaver is offline   Reply With Quote
Old 06-01-2011, 09:27 AM   #2769
hacker's Avatar
Trader Rating: 140 (100%+)
I'm loving this car, best car I have had to date, and I also have a t3 2011. Next time out will try a yokomo gear diff.
one question, I usually use a speed 6 body, but used an ltc-r and found to be understeering. How is this possible, I thought the ltc-r were suppose to be more aggressive than the speed6. Bit confused.
hacker is offline   Reply With Quote
Old 06-01-2011, 09:35 AM   #2770
geeunit1014's Avatar
The LTC is more aggressive on entry, but does not roll in the middle of the corner like the Mazda because it is much lower. It also depends where you mounted the body. I normally ran my 6's as far forward as I could for more steering, you may want to that, especially if you are pushing in high speed corners. You could also try a regular weight body instead of a light weight for more steering.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 06-01-2011, 10:05 AM   #2771
Send a message via AIM to Jonesy112
i just got an order from them a few days ago.
The axle bearings are 6x10x3, and the bearings for the diff outdrives are 10x15x4
Michael Jones
RC America - X-Ray - Team EA Motorsports - RockStar Paint - Apex RC Proshop - ProOne Tires
Jonesy112 is offline   Reply With Quote
Old 06-01-2011, 12:25 PM   #2772
hi , another daft question, has anyone gone from the t3 2011 and got on with the tc6 better?
the reason im asking the t3 2011 is such a twitchy car to drive is the tc6 more smoother on the steering ?
thanks ....
stcc ssb tires, ko ,gm motors, demon products lipos, hobbywing speedo
mwoods is offline   Reply With Quote
Old 06-01-2011, 02:02 PM   #2773
bshookup's Avatar
Trader Rating: 18 (100%+)
thanks ....
The T3 2011 is a great car, and I bet you could make it work for you and be fast with it. I had a T3 2010 that I ran back to back several times with my TC6 on carpet and asphalt, and with the setups I had, the TC6 was less twitchy. I wouldn't be able to say that the TC6 was any faster for me, but it was super smooth and easy to drive and it is the one on my pit table right now.
TOP RACING: www.top-racing.jp/
TEAM POWERS: www.teampowersusa.net/
bshookup is offline   Reply With Quote
Old 06-01-2011, 02:22 PM   #2774
im already fast with it just want something that is more easyer to drive and smooth also want a change after being with xray for the last two years...
Old 06-01-2011, 02:36 PM   #2775
burgboyz's Avatar
Trader Rating: 70 (100%+)
Default Dial-A-Grip
Kevin,
I received my first generation set yesterday and installed easily!
Even without driving the car yet, the pins are locked down noticeably tighter with no/0/zip/nada/zilch/ slop.
I will be at our track next Tuesday and report back in. Although I am sure we all know what the results will be.
Sweet solution for a nagging problem!
Got Droop???
Speed Passion....Speed Power....Serpent America/Desoto Racing.
burgboyz is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 07:34 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28937 01-14-2017 07:26 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 12:42 PM
SEO by vBSEO 3.5.0
