Like Tree1Likes
Old 05-12-2011, 03:55 PM   #2551
Big Features's Avatar
I would ask one of your teammates before posting on here.
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix
Big Features is offline   Reply With Quote
Old 05-12-2011, 03:58 PM   #2552
Rdog's Avatar
Trader Rating: 83 (100%+)
Originally Posted by Rdog View Post
Hey guys what is invloved in getting a gear diff in the tc6 i ve heard its a yokamo gear diff b ut what mods if any need to be done? Thanks guys
Can anyone tell me?
Rdog is offline   Reply With Quote
Old 05-12-2011, 04:01 PM   #2553
Can anyone tell me?
You can use the Spec R BD5 40T diff. You will need to ream the out drives. I used a 6.5 chucking reamer with a hand drill. Also you will need to clearance the case as the bearing spacing is to wide for the bulkheads
B.JUCHA is offline   Reply With Quote
Old 05-12-2011, 04:04 PM   #2554
CristianTabush's Avatar
I personally run 650-700 cst oil, which is like 50-55wt oil. If I am on Carpet, I will got to around 800-1000. This is for 17.5 boosted, which should translate well to 13.5 and 17.5 blinky. This is with a Spec R gear diff.
When I attempted going heavier, the car had a tendency to over-rotate on throttle. The 650 wt oil allows me to be more aggressive on throttle without the rear end stepping out on me.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 05-12-2011, 05:14 PM   #2555
xtrememadness's Avatar
Send a message via AIM to xtrememadness
thanx christian! i cant wait for the reflex parts! i race with jeff cuffs at our home track and cant wait to put em to the test! thanx again
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 05-12-2011, 06:16 PM   #2556
Trader Rating: 77 (100%+)
Default Caster blocks
Dumb ?
I am installing the 6 degree caster blocks in the Hebert set up. How do I know which is the right side or the left?
goin2drt is offline   Reply With Quote
Old 05-12-2011, 06:52 PM   #2557
Originally Posted by goin2drt View Post
Dumb ?
They should be labeled with small molded-in numbers- 6L & 6R
Serzoni is offline   Reply With Quote
Old 05-12-2011, 07:05 PM   #2558
Chaz955i's Avatar
Dumb ?
If I have a hard time finding a left or right marking I run a hex wrench through the pivot pin hole with the wrench horizontal and see which way the c-hub leans. This will tell me if it is a right or left. If you have a bunch of different degree hubs mixed together this doesn't work so well.
At The Gate Bizzos
Chaz955i is offline   Reply With Quote
Old 05-12-2011, 07:33 PM   #2559
My pleasure
Old 05-12-2011, 07:41 PM   #2560
Perfect. Thanks so much. Couldn't see them on the side
Old 05-12-2011, 09:29 PM   #2561
Verndog's Avatar
Trader Rating: 16 (100%+)
Posted this in another thread but better leave here as well.
Here is what you need to convert the Hot Bodies DCJ driveshafts to fit the TC5 / TC6
Tools: Dremel with 1/8 rotary file - #40 .098 dia. drill bit - 1.5 and 2.0 mm hex drivers and wheel wrench.
Parts: Hot Bodies DCJ 67699 drive shafts - Hot Bodies HB70742 5mm wheel hex's (comes with 4 hex's, pins and screws) - CRC CLN 4741 5mm shims - stock TC6 blades - (4) 3 x 5 x 10 mm wheel bearings.
1) Drill blade pin holes out to .098 dia thru each side at a time and mount blades.
2) Remove C hubs from steering arm and take dremel and open the slot to .375 wide, this leaves .095 wall thickness on each side so watch wall on first side then open second side to keep symmetrical on C hub.
3) Insert new bearings into steering arm then mount up the C hub without the drive shaft for now. Then test fit the drive shaft by sliding thru opening into bearings, it should go thru without hitting now.
4) Mount assembly back into arms, add the new CRC shim, new HB pin (comes with hex kit) and new hex's (nice quality hex BTW), then bench test.
The Good, front drive chatter GONE very smooth, good quality parts. Driveshafts can now be removed without removing C hubs, no set screws to come apart on driveshafts.
The Bad, have to keep another bearing and spare hex size, the driveshafts are press fit pins (no set screw to rebuild), but looks like with some care and good short pin punches they could have new pins pressed in, and for now about $90.00 you have smooth driveshafts with no backups if 1 fails.
Track time will tell later if this was worth it...IMO questionable at this point...but I like for now.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 05-12-2011, 09:36 PM   #2562
johnny55's Avatar
Send a message via AIM to johnny55
Nice, keep us posted
Johnny Hernandez
Fight on!
johnny55 is offline   Reply With Quote
Old 05-13-2011, 05:00 AM   #2563
I would run start at 70-80 wt oil and go from there.
what are you guys running for oil in gear diff for 17.5 and 13.5 blinky thanx
TEAM ASSOCIATED, SMC BATTERIES, REEDY MOTORS, JACO TIRES, RADIOPOST RADIOS, LRP ELECTRONICS, PROTOFORM BODIES, MAKITA POWER TOOLS, KICKER PEFORMANCE AUDIO, KOLORS BY KROPY, MUCH-, RSD
Mike Blackstock is offline   Reply With Quote
Old 05-13-2011, 05:05 AM   #2564
Did you go faster with these put on your car? I personally have not seen a decrease in laptimes at all . I sometimes think the stock one's help the car get into the corner better were as these make the car push more on corner entry.
Old 05-13-2011, 07:18 AM   #2565
Verndog's Avatar
Jury still out on that Mike, but in all honesty I somewhat doubt it will make a very noticeable difference. I was hoping for a bit more consistency on entry and you are saying just the opposite is true. I find that odd, as how does truer running tires with less friction going into corner create more push on entry?
---Team Hoarders---
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28975 Yesterday 10:40 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
