Old 05-09-2011, 10:10 PM   #2521
JayBee's Avatar
Trader Rating: 31 (100%+)
Alright guys....what front bumper are you guys using?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 05-10-2011, 01:08 AM   #2522
Trader Rating: 23 (100%+)
Mines the std one from the kit.. Yes its because the body hits the front bar so it sits forward abit to much.. Ive got it to sit right now, but it still is abit short.
ox
Rotax125 is offline   Reply With Quote
Old 05-10-2011, 01:24 AM   #2523
Rdog's Avatar
Trader Rating: 83 (100%+)
Hey guys what is invloved in getting a gear diff in the tc6 i ve heard its a yokamo gear diff b ut what mods if any need to be done? Thanks guys
Rdog is offline   Reply With Quote
Old 05-10-2011, 01:37 AM   #2524
i use the parma tc5 utlimate bumber with the guts cut out to fit the supports
its also thinner than the stock one so no need to file to down to fit the ltc-r bodies
ed
Edwin Pibal is offline   Reply With Quote
Old 05-10-2011, 03:55 AM   #2525
Originally Posted by goin2drt View Post
How do I get those blue screws? Those are sweet.
Associated as them, take a look http://www.teamassociated.com/factor.../details/6934/ there's more measures.
jorgesimes is offline   Reply With Quote
Old 05-10-2011, 01:06 PM   #2526
mickrcarver's Avatar
Trader Rating: 98 (100%+)
what are you guys finding to be a good spur/pinion combo for mod 6.5 turn brushless,and also is the diff that came with the car holding up?
www.ovrccc.com
www.speedybillsrc.com
mickrcarver is offline   Reply With Quote
Old 05-10-2011, 01:58 PM   #2527
I'm currently using a 6.5 too, as for fdr i run at about 8.2 (115/28 64dp)
Stock ball diff is really durable, i can run about 20 packs out of it before a rebuild....
Fastfreddy74 is offline   Reply With Quote
Old 05-10-2011, 02:16 PM   #2528
artwork's Avatar
Trader Rating: 54 (100%+)
The Parma T2 bumper is the best for sure...
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 05-10-2011, 03:48 PM   #2529
Thanks!!
www.ovrccc.com
Old 05-10-2011, 08:06 PM   #2530
hacker's Avatar
Trader Rating: 140 (100%+)
does the parma tc5 fit?
hacker is offline   Reply With Quote
Old 05-10-2011, 08:10 PM   #2531
tr1kstanc3's Avatar
Trader Rating: 18 (100%+)
It fits once you trim out the section for the transponder and a little bit off the side edges with a knife.
tr1kstanc3 is offline   Reply With Quote
Old 05-10-2011, 10:43 PM   #2532
On kevin H new setup he has the front arm mounts shimmed out 3.5mm and the shocks on the inside hole. What effect does this have? since i have never seen a setup with the shocks on the inside and shimmed that far. Thanks
WEEZY is offline   Reply With Quote
Old 05-11-2011, 03:58 AM   #2533
daleburr's Avatar
A wider front track should reduce the amount of steering. Looking at the rest of the setup (front springs much stiffer than rear, front oil much thicker than rear) I'm guessing that reducing steering was a priority. These settings would also help to reduce grip-roll.
The change of shock position is probably to account for the wishbones moving outwards, although I guess you really need a hole half-way between A and B to get the shocks back where they would be with a narrower track width.
I've been tempted to space the TC6 out myself (both front and rear) as it runs at about 184mm out of the box. Has anyone else tried this?
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 05-11-2011, 06:03 AM   #2534
New solid axle from Eugiene
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 05-11-2011, 06:08 AM   #2535
Geberit's Avatar
Helo,
I can't find any info about that ...
Can I use the C.V. Universal Swing Shaft (For YOKOMO BD5); Model: SPR001-BD from spec-r for my TC6?
Regards
Geberit is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 07:34 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28937 01-14-2017 07:26 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 12:42 PM
SEO by vBSEO 3.5.0
